Old Jan 11, 2003, 04:27 PM
nr5a is offline
Find More Posts by nr5a
Box Elder, SD
Joined May 2002
Why I hate Solite, count the ways
Why I hate Solite covering, Let us count the ways!
1. Some colors stick to its self sooo bad (I'm starting to hate, white!)
But it looks so darn good!
2................(your reasons.....)
This was brought on because I'm using it for the first time to cover a "Dandy". There have been a few times I was about ready to trash the stuff. hee hee
Crashin J
nr5a is offline Find More Posts by nr5a
Old Jan 11, 2003, 04:50 PM
RV-4 flyer is offline
Find More Posts by RV-4 flyer
Balls O' Wood
RV-4 flyer's Avatar
Indianapolis
Joined Nov 2001
It's light...
But the stuff tears so easily. Brand new blades only when trimming it... and sometimes it still tears.
But it's light
RV-4 flyer is offline Find More Posts by RV-4 flyer
Old Jan 11, 2003, 05:12 PM
uncled is offline
Find More Posts by uncled
Iron Mountain,MI
Joined May 2002
Re: Why I hate Solite, count the ways
Crashin J
Try sprinkling with baby powder om the glue side, wipe it lightly with a dryer sheet to get rid of static cling - - - - Amazing difference
uncled is offline Find More Posts by uncled
Old Jan 11, 2003, 05:34 PM
Kevin P is offline
Find More Posts by Kevin P
Hoosier Hobby Hangar
Kevin P's Avatar
Cicero, Indiana
Joined Oct 2002
No major complaints here. I love the stuff, just wish the white was not as translucent as it is, and that they would come out with as many colors as I want....
Crashin, what blades are you using to cut the film? Stick with it, and soon it will be the same as any other covering you have used. But WAY lighter..hehe..... Good luck with the Dandy, Im sure you are going to love her as well.
Kevin P
Kevin P is offline Find More Posts by Kevin P
Old Jan 12, 2003, 01:30 AM
nr5a is offline
Box Elder, SD
Joined May 2002
Kevin, I started off using brand new #11 exacto blade, for some reason they would rip tear cut, rip tear cut. Then for grins I tried a plain old single edge blade and it seems to work 100% better for me!
Wings, and fuselage are now covered. Tomorrow I'll see how Solite works at trim.
Crashin J
Old Jan 12, 2003, 01:37 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Check out this thread that I had started a while back strictly for helping people get used to solite and covering in general. There's lots of tips in there from other people too. It may be a long read, but hopefully it's worth it.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jan 12, 2003, 09:32 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Crashin J
I've had trouble with #11's being sharp enough, and straight Razors. If they are just a tad dull, it'll rip. After some of the tips I've seem here, I picked up some double edge razors, and broke one in half. I used a little tape to cover the backside, and they are much sharper and bendable. I rally like them for this.
Someone had mentioned, somewhere here, that you can buy #11 scalpel blades, that are better. I think they were referencing Ebay, or some medical supply place. May be worth a try.
Oh, yea, back on subject:
- Too much static
- Not opaque enough
- Not enough colors
- Too self sticky
- Hard on blades
But I still love the stuff!
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 12, 2003, 11:29 AM
Richard is offline
Find More Posts by Richard
Terre Haute, Indiana
Joined Nov 2000
What brand of double edge blade is the sharpest? I am about to use Solite for the first time on my Cutie but am almost afraid to open the roll after reading these threads. I think I will get some talcum powder. I have the Nelson lite film equivalent and directions tips say to try this. Also mentioned is the use of Aqua Net hair spray on balsa to enhance the adhesion. It is basically clear lacquer. Has anyone tried this?
Richard
Richard is offline Find More Posts by Richard
Old Jan 12, 2003, 01:00 PM
Mike Hall is offline
Find More Posts by Mike Hall
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
I love this stuff. I had not covered a plane with covering in years and the very first time i used Solite i was very happy with the results. What i do like is you can put it on and have wrinkles and when you put some heat on it there gone. I love how much this stuff shrinks out the wrinkles.
Mike Hall is offline Find More Posts by Mike Hall
Old Jan 13, 2003, 08:06 AM
Balls O' Wood
RV-4 flyer's Avatar
Indianapolis
Joined Nov 2001
The static problem hasn't counfounded me like the tearing... I've been using single edge blades -but might have to try the doubles next time.
My technique has been to cut the piece to size, use two pieces of masking tape as recommended to get the backing started off, then pull the backing off *while* spreading the covering across the surface it's going to cover. I've only had it touch itself a few times and if it doesn't contact itself too firmly it will pull apart if you're gentle.
If you try to pull the backing off up in 'midair' and *then* lay it on the surface to cover you're in trouble.
Old Jan 13, 2003, 08:58 AM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
The way i get the plastic backing off the covering is to pull and edge of the covering to stretch the plastic backing. The covering will not stretch but once the backing stretches its no problem getting the backing off.
Old Jan 13, 2003, 09:42 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
I cant complain about it. For removing the backing, I lay it on a lanolium counter top with the plastic side down and the plastic to be removed on top. Peel back a corner, and as you remove it, the static between the counter and the solite makes the solite statically stick to the counter. Keeps the sticking to itself down and you can lay what you are covering on top of it (if its flat) then lift up and edge off the counter, now if the area touching the counter is less than the are touching the part to be covered, it releases from the counter, touch it with an Iron around the edges, a little heat gun action, (I am impatient) and its done!
Just dont forget its, there and set your coffee cup on it, you have a solite covered coffee cup!
Kirby
kepople is offline Find More Posts by kepople
Old Jan 13, 2003, 10:01 AM
Mike Tully is offline
Find More Posts by Mike Tully
Methuen, MA
Joined Sep 2002
CJ - I hate covering too! It is so much fun to build up all the bones, but then comes the painful drudgery of covering.
Solite and Nelson may not be perfect, but they are the best we can get for our purposes. If you think they are flawed, just try that miserable crap from Tower called "CoverLite". Hard to use and considerably heavier to boot! You will be very happy with Solite after trying that.
I buy #11 blades by the box of 100. I make 1 to 3 passes per blade and then throw it away. I know it is wasteful, but its the only solution I've come up with after covering several dozen planes.
Mike Tully is offline Find More Posts by Mike Tully
Old Jan 13, 2003, 10:11 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I actually like the stuff. Was amazed at how easy it actually was to work with. I'm used to the heavier coverings, so I wasn't sure how this lite stuff was gonna work out. I had reservations
Like some others I've been using the snapped in half double edged razor blade trick for years. (be sure to cover the "broken" edge, I use duct tape) I covered a MM Cessna and only used one half with no tears. It is hard to cut VERY straight lines with it, so I use a single edge razor blade for that stuff. They cut great when new, but on the first tear I use the other side, then after it is done, put a big black X on it, and use for cutting balsa.
My gripe with it is removing the backing on small trim pieces. You knwo where the covering is too small for the tape to really stick enough to pull apart
Other than that, I like it and will continue to use it when ever a lite weight covering is needed.
rcav8r2 is offline Find More Posts by rcav8r2
Old Jan 13, 2003, 11:39 AM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
What covering might be a step up from Solite -weight, ease, etc ?
FlyByMike is offline Find More Posts by FlyByMike
Why I hate Comcast. A Venting daveWCO Life, The Universe, and Politics 27 Sep 27, 2004 10:27 PM
Rant. Why I hate XP in 1000 words or less. lakedude Life, The Universe, and Politics 79 Apr 25, 2004 04:55 AM
Again .... why I hate the BCS logan5 Life, The Universe, and Politics 15 Dec 08, 2003 06:50 PM
why i hate GWS RX's, and the end of a good model. Thomas Manson Parkflyers 56 Aug 27, 2003 05:45 AM
Dymond vs Supernova ? why no cell count for Dymond? rojoyinc Sport Planes 15 Aug 31, 2002 09:45 PM
