Old Apr 21, 2008, 11:02 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Looking at your work on the primed hull, it looks more like a glass hull, and not the wood creation you depict on the first page of the thread. Excellent work!!!
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Apr 22, 2008, 05:59 PM
Jay Hargest is offline
Find More Posts by Jay Hargest
jayman
Joined May 2007
I, for one, would like to see both shots of your build sequence and the final model in the water. Your build sequence is like reading a good book where you are always looking forward to the next chapter.
Regards, Jay
Jay Hargest is offline Find More Posts by Jay Hargest
Old Apr 23, 2008, 10:13 AM
bluebell is offline
Find More Posts by bluebell
CHESHIRE U/K
In my builds I do like to plate the hull, im always looking for new matierials.
This hull im going to plate it with LITHO PLATE, its a waste product of the printing industry, its a nice soft aluminium that bends and cuts very easy.
I cut the plates to size and glue them on with contact adhesive, on this model I am only going to plate from the deck to just below the water line.
I have sprayed the hull RED and fit the 4 props.
The props are from PROP SHOP in the U/K and are 30 mm , the thread is 4 BA.
bluebell is offline Find More Posts by bluebell
Old Apr 23, 2008, 11:10 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
What is the thickness of your Litho plate?
green-boat is offline Find More Posts by green-boat
Old Apr 24, 2008, 09:11 AM
bluebell is offline
CHESHIRE U/K
I would say about 1/64.
Old Apr 29, 2008, 09:38 AM
bluebell is offline
CHESHIRE U/K
When building superstructure for a sailing model you have to keep it as light as possible, when I do mine I use balsawood and cover it with litho plate.
The decks are 1/16 inch plywood.
The main stantions for the fighting tops are brass tube, this is for strength.
Old May 01, 2008, 09:47 AM
bluebell is offline
CHESHIRE U/K
The rear superstructure is built in the same manor as the forward one, the barbettes are made of plastic card.
I cut a circular disk , fit a plastic rod to it and cut some sections that I glue to it that raidiate out from the centre. Then I roll a piece around the out side and glue in place.
The next to last picture shows the camber of the deck.
Old May 01, 2008, 10:39 AM
andrewhalst is offline
Find More Posts by andrewhalst
Maltese sparrow
andrewhalst's Avatar
Leicester, UK
Bluebell,
Light and logical; I like your preparation and methods of construction of the superstructure- we can all learn from you.
I look forward to the turrets! You have tantalised us with a pic of them im place. I assume that you leave the (grey) plastic tube in place in the barbette centre as part of the structure and also pivot for the turrets?
Your incomplete barbette (slightly) resembles paddlewheels under construction in the Glyn Guest style!
andrew
(also watching whaleback)
andrewhalst is offline Find More Posts by andrewhalst
Old May 01, 2008, 10:53 AM
bluebell is offline
CHESHIRE U/K
Yes Andrew I leave the post in, I will be showing the turrets soon, thanks for the post.
Old May 04, 2008, 07:08 AM
bluebell is offline
CHESHIRE U/K
This is the start of building the guns, I first make a turret out of plastic card, I have the barrels turned ready to dry fit them so they look right.
Old May 04, 2008, 08:36 AM
bluebell is offline
CHESHIRE U/K
The photo,s have got mixed up, if you run the curser over the picture you will see the sequence 093- 102.
Old May 07, 2008, 07:56 AM
BISHBASH is offline
Find More Posts by BISHBASH
Joined May 2008
Bluebell's Iron Duke
Dear Andrew,
Marvellous work. I am hoping to start the Modelik 1:200 Iron Duke soon. You have inspired me to make it water - going. I am trying to obtain any additional plans and drawings. As you know, the Modelik instructions are in Polish. I have been unable to find any Sambrook Marine 1:192 plans on the web. I would be most grateful if you could advise where I might find such info..
Regards
Brian
BISHBASH is offline Find More Posts by BISHBASH
Old May 16, 2008, 06:38 PM
bluebell is offline
CHESHIRE U/K
Hi Guys, When the turret is complete, I make a styrene box to go round it , when secure I pore a mould resin, RTV over it, leave to set for 24 hrs.
I then take out the turret and mix and pore plaster of paris in to the mould, and leave to set, I did this for all five turrets.
Old May 16, 2008, 11:39 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Sweet
Old May 17, 2008, 12:57 AM
HorribleHarry is offline
Find More Posts by HorribleHarry
Irregular... need..fiber!
HorribleHarry's Avatar
a snazzy little suburb of L.A. called Encino
Joined Jul 2005
You're good! when will you be starting mine?
Harry
HorribleHarry is offline Find More Posts by HorribleHarry
1:96 scale GATO class CG Bob Submarines 10 Jan 09, 2009 10:14 PM
1/96 scale Torpedos Mihelich Submarines 10 Oct 04, 2005 01:02 PM
1/96 scale nuke flasks Ghost 2501 Scale Boats 2 Feb 13, 2005 02:22 PM
1/96 scale fittings Wing Zero Scale Boats 5 Nov 05, 2004 04:18 AM
