Espritmodel.com Heli Air
Old Apr 08, 2008, 05:21 PM
CHESHIRE U/K
Scratchbuilding HMS IRON DUKE 1916 1/96 SCALE
This is IRON DUKE flag ship of the British fleet 1916.
bluebell is offline Find More Posts by bluebell
Old Apr 09, 2008, 05:05 AM
CHESHIRE U/K
The first thing I do is copy the rib shapes .
Then I make enough copies to make all the ribs I need, I then cut them all out of the paper, these rib sections have been reduced in size to allow for the planking onthe outside of the hull.
Old Apr 09, 2008, 11:15 AM
Sweeper Nut
Mike McCrea's Avatar
Northridge So. Cal
Joined Apr 2007
Looking forward to following your build..Good looking ship too.
Mike McCrea is offline Find More Posts by Mike McCrea
Old Apr 11, 2008, 08:46 AM
CHESHIRE U/K
The next stage was to mark out all the rib shapes on to 1/4 inch plywood and cut them all out on my vibro saw.
Next I cut out the keel with a small section of the bow and stern in place, all the ribs were glued in place with PVA White glue.
Old Apr 12, 2008, 09:38 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Oh Boy ! this is going to be good!
I am enjoying watching the progress allready !
Keep posting the good work !
duncan
dunc2504 is offline Find More Posts by dunc2504
Old Apr 14, 2008, 07:37 AM
Maltese sparrow
andrewhalst's Avatar
Leicester, UK
Bluebell - this is magnificent! Thanks for posting your build.
Its not only an informative build of an unusual boat, but it demonstrates the steps to making something completely from scratch.
I'm sure it will inspire others to dive in and create!
andrew
andrewhalst is offline Find More Posts by andrewhalst
Old Apr 14, 2008, 09:12 AM
CHESHIRE U/K
Thanks Guys,
The next step is to cut out the deck shape, bow and stern and glue in place with white PVA glue, then putting a few weights on to hold it in position.
From the keel we start glueing on the planks, a few either side of the keel, tis stops any twisting in the hull, you can see I use pegs and drawing pins to hold the planks in place while the glue is setting, its not a job that can be rushed.
At the stern I use balsa blocks, at the bow I use filla paste to shape this section.
Joining the planks, cut them at an angle of 45 degrees with a rib under the join.
Old Apr 14, 2008, 02:00 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Now that's a whole lot of work brilliantly done. Love these old ships.
Keep at it.
Paul.
785boats is offline Find More Posts by 785boats
Old Apr 14, 2008, 04:33 PM
CHESHIRE U/K
The 5 guns were built while I was waiting for space in my workshop/drydock, a 7ft -7ins battleship was being finished, I will show the building of the guns later in the build.
Old Apr 14, 2008, 09:06 PM
Minnetonka Minnesota
Joined Aug 2007
Looks great Bluebell! The turrets look awfully good too. Great historic ship, will you have a miniature Jelicoe as well? I really like the older ships, the hulls had so much more character to them, tougher to build though thats for sure. Keep the posts coming. Cap
capricorn is offline Find More Posts by capricorn
Old Apr 16, 2008, 08:56 AM
CHESHIRE U/K
Thanks Guys.
The next stage was to cover the hull with a thin fibra glass matting and coat of resin, this stops any cracking of the balsawood and a better key to the fibra paste.
Next I covered the hull with thin layers of fibra glass paste and sanding to shape.
I then cut out the hatches and fit the combings around them, this stops water getting in to the hull.
The hull was given a coat of grey primer paint
Old Apr 16, 2008, 09:27 AM
Maltese sparrow
Leicester, UK
Bluebell - coming along very well and apparently fast
I presume the fibra glass paste is car-body (polyester) paste. It seems to sand well to a fair surface, too
andrew
Old Apr 16, 2008, 09:44 AM
CHESHIRE U/K
That is correct Andrew, the model has been built, but I thought it would help some of the newer guys to the hobby.
Old Apr 16, 2008, 10:01 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
This is fast work !!!
I expect to see the completed ship by the weekend !!
Keep it up !
Duncan.
Old Apr 16, 2008, 10:14 AM
Maltese sparrow
Leicester, UK
it does, it does!
In the back of a book titled "Battlecruisers" in our library there is a complete plan of HMS Queen Mary at about 30 inch loa. It has all the necessary lines as well as deck plans, etc.
Like Iron Dook there is little above deck level, but the hull lines are very attractive and close to flat-bottomed.
A quick hit with a photocopier would double up the frames and make a very handsome ship!
Its on the list
andrew
1:96 scale GATO class CG Bob Submarines 10 Jan 09, 2009 09:14 PM
1/96 scale Torpedos Mihelich Submarines 10 Oct 04, 2005 12:02 PM
1/96 scale nuke flasks Ghost 2501 Scale Boats 2 Feb 13, 2005 01:22 PM
1/96 scale fittings Wing Zero Scale Boats 5 Nov 05, 2004 03:18 AM
