Old May 23, 2008, 06:19 AM
6-mins is offline
Find More Posts by 6-mins
Joined Apr 2008
is this a good prop and motor to go in the guppy.
http://www.hobby-lobby.com/speed400.htm - 400speed, says it has a 2.3mm shaft diameter.
https://www.hobbycity.com/hobbycity/...peller_6x4inch - closest thing to the recomended 5X4 for the motor above, anyone know if this will fit on the shaft.
6-mins is offline Find More Posts by 6-mins
Old May 23, 2008, 11:09 AM
CANTZ506 is offline
Find More Posts by CANTZ506
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
If you read the comments below the propeller's image, (french and spanish) you find the answer: DO NOT BUY IT!
CANTZ506 is offline Find More Posts by CANTZ506
Old May 24, 2008, 01:30 AM
6-mins is offline
Joined Apr 2008
how bout this, https://www.hobbycity.com/hobbycity/...oy_hub_-_6.5x4
and what do you think of the motor?
Old May 24, 2008, 04:23 AM
CANTZ506 is offline
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Sure this 'seems' better, but I can't say nothing about quality.
But I'm not sure about its size: 6.5x4 seems too big for that motor; I'm afraid it will suffer a bit.
It's better to ask people who have already flown Guppy, or READ the whole part#1 thread!
Old May 24, 2008, 05:19 AM
mifi is offline
Find More Posts by mifi
Joined Sep 2006
For Guppy and speed 400 you should use 6 X 3 folding prop. That is the Law
mifi is offline Find More Posts by mifi
Old May 24, 2008, 02:28 PM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Compared to Garupner Cam prop, or AeroNaut folder, this HK prop is very thick. Its airfoil is very fat. So he eat a lot of power.
I saw that prop and I think is not suitable.
ultralajt is offline Find More Posts by ultralajt
Old May 24, 2008, 02:46 PM
lubak is offline
Find More Posts by lubak
lubak's Avatar
Slovenská republika, Banskobystrický kraj, Banská Bystrica
Joined Jun 2007
I changed Speed 400 motor with this Turnigy 28-26 1650Kv with 6x3 Graupner prop and 1300 mAh 3S Lipoly and Guppy now flight wonderfully
lubak is offline Find More Posts by lubak
Old May 28, 2008, 06:00 AM
ultralajt's Avatar
Joined Sep 2004
Hi all!!
I came across an idea, that would be usefull if I made another set of plans for the Guppy.
This Guppy (Mark 2 ) will incorporate all features, that were shown as good options or modifications in the past, as some builders use it while assembly their own Guppies.
Of course, the general outlook of the model will remain the same.
So the newest Guppy will have:
- better airfoil
- thin ply reinforcment members in the fuselage
- middle wing joiner (optional)
- a little bit longer nose part of the fuselage
- front end redesigned for use of brushless motors
- wing optional with or without ailerons
- ply reinforcements at wing dihedral points
- alternative way of controling tail. Pull-pull system with string.
- list of apropriate (and affordable) propulsion systems from UH http://www.hobbycity.com?cda=21131
So much for now from UL-Design Headquarters
Mitja
Old May 28, 2008, 06:20 AM
jh2rc97 is offline
Find More Posts by jh2rc97
Dallas, TX
Joined Jan 2005
100"?
Originally Posted by ultralajt
Hi all!!
- better airfoil
Mitja
jh2rc97 is offline Find More Posts by jh2rc97
Old May 28, 2008, 07:56 AM
CANTZ506 is offline
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Hi all!!
Very good!
- better airfoil Which?
- middle wing joiner (optional) Two pieces wing (hotliner), three pieces (normal)
Mitja
Before you start drawings, may I suggest a 86" wing span (2.2mt)?
Old May 28, 2008, 07:57 AM
3810 is online now
Find More Posts by 3810
3810's Avatar
Australia, VIC, Delacombe
Joined Nov 2003
Mitja,
Having built the standard Guppy,I look forward to seeing Guppy MK2
3810
3810 is online now Find More Posts by 3810
Old May 28, 2008, 01:14 PM
kr3cik is offline
Find More Posts by kr3cik
kr3cik's Avatar
Joined Feb 2007
Better airfoill...?? MU or difrent
kr3cik is offline Find More Posts by kr3cik
Old May 28, 2008, 01:40 PM
Jack Stephens is offline
Find More Posts by Jack Stephens
Gadsden RC Flyers
Jack Stephens's Avatar
Joined Aug 2004
Guppy Wingtip Suggestion
Mitja,
Since you are planning to change your Guppy plan, I would like to show you a change that I made to mine. The Guppy wingtip is a lovely design, but the detailed carving on the front portion of the wingtips (Photo 1) would have been very difficult for me to duplicate.
To make the wingtips easier for me to build, I terminated the spars and D-Box sheeting on a new tip rib, then glued the wingtip block to that. Section MM on the wing plan provides an exact pattern for new tip ribs, requiring only trimming off the ends to match up with the leading and trailing edges. Photo 2 shows the tip plan and Section MM, and Photo 3 shows the new tip rib patterns ready to cut from 1/8” balsa.
Photo 4 shows a tip rib trimmed to length and glued into place, and Photo 5 shows a wingtip block glued on. In Photo 6 the wingtips are rough shaped and rough sanded. I also moved the triangular leading edge gusset back to the spar/tip rib joint.
My version is not as strong as your wingtip design, but this change made the building task much easier for old fingers. The only additional material required was for the two new 1/8” balsa tip ribs.
For what it is worth,
Jack Stephens
Jack Stephens is offline Find More Posts by Jack Stephens
Old May 28, 2008, 03:49 PM
SuperSushi is offline
Find More Posts by SuperSushi
Bottrop, Germany
Joined May 2008
Thanks for sharing the plans and the Design for that great looking and as it seems to me also great flying plane! I want to build one for a friend of mine. He goes to india for 4 months and I plan to give him the plane when he is back arrived. He flys only foamies at the moment because his opinion is, wooden planes crash through the smallest mistake a pilot can do. I don't know if this sentence was understandable, I'm from Germany. The thing is, he would never buy or build a wooden plane and I want him to fly something 'real', so i must build one for him
My question is: How long will it take for MkII to come? If that would happen soon, of course I would build MkII then. otherwise, if it comes in 4 months, I will have to build the current version.
So long, Björn.
[edit] If there's someone from Germany here, do you know where to get that PU-glue? Never heard of it so far.
SuperSushi is offline Find More Posts by SuperSushi
Old May 29, 2008, 12:14 AM
ultralajt's Avatar
Joined Sep 2004
AAA!
What a pleasent respont to my newly idea!
Mark 2 will be the same size as original Guppy.
The larger Guppy will be of 100" or 2,54m wingspan...and it will came after Mk2.
Thanks guys for suggestions! I will use them in concern as they proved themself as worth to use.
Build Log GUPPY electric sailplane Building&flying PART 1 ultralajt Electric Sailplanes 1129 Apr 26, 2016 01:43 PM
RadicalRC Microstick Building & Flying part 2 Earthbound Parkflyers 432 Jul 18, 2008 10:01 AM
Unicorn Wing Building Process - Part 2! tim hooper Foamies (Kits) 59 Oct 27, 2005 08:41 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 12:46 PM
