Old Jun 10, 2011, 06:30 PM
eleazar_a is offline
Find More Posts by eleazar_a
eleazar_a's Avatar
Venezuela, Dto. Capital, Caracas
Joined Jun 2011
Originally Posted by ultralajt View Post
Eleleazar e I think a pretty good replacement for the carbon tube would be an aluminum or carbon arrowshaft. Look at nearby fishing/hunting/sport stores for aluminum tube arrows. Probabbly also carbon arrows could be find there.
Also some thin walled aluminum tubes used on some TV antenas sould be used.
Wish you luck in search for proper material.
Regards!
Mitja
Mitja grateful for the suggestion, I think the more accessible material is currently used aluminum antennas, ha ha ha at home since I have Directv air antenna and became part of the obsolete things in the workshop.
For now I have a fabulous performance Akrobat having, but not my style, I always declined by planners, his line and relaxed style and the Hotliner are covered with the expectations of a good day to fly.
eleazar_a is offline Find More Posts by eleazar_a
Old Jun 13, 2011, 02:55 AM
ourbluehorizon is offline
Find More Posts by ourbluehorizon
UK, Ballymena, Ballymena
Joined Aug 2008
Flew off the plan!
Video of maiden flight
http://vimeo.com/user373988/videos/s.../format:detail
boom was a recycled fishing rod
Motor is the KDA 20-22l from hobbyking
30amp esc from rc timer
9x5 graupner cam prop but will replace with 10x4
lipo 3 cell 1300 longmmax tipple from giantcod
servos 9g HXT from hobbyking
cable to elevator was a bicycle gear cable through an old sullivan
canopy home made from lemonade bottle
hotliner wing was fiberglassed
ourbluehorizon is offline Find More Posts by ourbluehorizon
Last edited by ourbluehorizon; Jun 14, 2011 at 12:55 PM. Reason: adding more detail
Old Jun 14, 2011, 02:11 PM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Well done Bob!
Thanks for descriptions and a video!
Regards!
Mitja
ultralajt is offline Find More Posts by ultralajt
Old Sep 05, 2011, 06:24 AM
sergej iv is offline
Find More Posts by sergej iv
Joined Sep 2011
Yet another Guppy is born
Hello Mitja, I have also built your Guppy. This is the 170cm Hotliner wing - option. I make some simplyfied hybrid: balsa-foam-depron. Two-part depron-wing without ribbs with balsa edges, and all surfaces are filled with 3mm depron. Fuse is partially hard foam. Full fly weight is about 470g, but I must take bigger battery for balancing more to nose. There can be lighter, but i have used full tin white painting. Thank you for plane sharing.
When I learn fly, I build one more proper Guppy.
sergej iv is offline Find More Posts by sergej iv
Old Sep 08, 2011, 09:47 AM
drstation is offline
Find More Posts by drstation
Egypt, Alexandria
Joined Sep 2011
Hi Mitja,
i'm new to the field of Rcs and i i'm trying to make a guppy plane like your
i live in Alexandia Egypt and it's very hard to get balsa wood in here so i'll make the plane with foam. "insulation foam"
the problem is the fuselage is very thin if i want to make wider say by 3 cm do i need to increase the lenth of the wings
and attaching foam wings to a foam fuselage is it safe or the plane will be torn apart with maneuvers
thanks
drstation is offline Find More Posts by drstation
Old Sep 20, 2011, 03:00 PM
jp_castanho is offline
Find More Posts by jp_castanho
Joined May 2011
Hello all...
First of all congrats to Mitja for a very nice plane... And for putting the plans and instructions online for all of us (that never did a model plane but sure would like to have a go)....
So I've started a Guppy, my first balsa model glider... Up to now I have the main parts done, I'm going slowly on trimming everything properly to get a nice fit.....
Here are some pics.....
I hope that I'll have some more pics once I progress a bit more....
jp_castanho is offline Find More Posts by jp_castanho
Old Sep 20, 2011, 10:41 PM
ultralajt's Avatar
Joined Sep 2004
Amazing workmanship for the first balsa model build!
Congratulations!!
Ragards!
mitja
Old Sep 22, 2011, 03:59 AM
Egypt, Alexandria
Joined Sep 2011
Hi Mitja,
thanks
Old Oct 11, 2011, 11:48 AM
AlfaGlider is offline
Find More Posts by AlfaGlider
South Africa
Joined Oct 2007
Guppy Family
Can't see this thread die now can we?
Here are some photos of 1.5M poly wing Guppies I built for friends, together with my 2M Guppy.
I am sure you can tell how impressed I am with the design and flying characteristics of this little glider
AlfaGlider is offline Find More Posts by AlfaGlider
Old Oct 12, 2011, 01:47 AM
Grunta5 is offline
Find More Posts by Grunta5
Who said Kiwi's can't fly!
Grunta5's Avatar
Hawkes Bay , New Zealand
Joined Feb 2008
Originally Posted by drstation View Post
Hi Mitja,
thanks
I think it would be ok without increasing the wing..
foams fairly forgiving , just dont make the maneuvers to wild , lol
Im surprised no one has answered your two questions yet, Good luck with the build and please dont forget to post some photos here for us to see..
Grant.
Grunta5 is offline Find More Posts by Grunta5
Old Oct 12, 2011, 04:21 AM
South Africa
Joined Oct 2007
Hi Mitja,
thanks
drstation
I don't think foam will be strong enough to support the "T Tail" section. You could possibly make the front section of the fuselage with foam (up to a few cm's behind the wing mount) and the rear section from a carbon fiber or aluminium tube. The "T-Tail" itself would however still need to be made of balsa. I am sure you will also have problems with the control linkages if you use a solid foam fuselage.
Tim
Old Oct 13, 2011, 02:09 AM
ultralajt's Avatar
Joined Sep 2004
AlfaGlider, nice flock of Guppies!
Please, check PM! I have a surprise for you!
Mitja
Old Dec 12, 2011, 10:22 PM
crustydms is offline
Find More Posts by crustydms
Joined Dec 2011
Is posible to use this engine in my guppy??…
http://www.hobbytech.cl/52-kit-de-tu...ra-merlin.html
And this servos ??
http://www.hobbytech.cl/packs-de-ser...-blizzard.html
paulo
crustydms is offline Find More Posts by crustydms
Old Dec 12, 2011, 10:38 PM
ultralajt's Avatar
Joined Sep 2004
And this servos ??
paulo
Your links does not direct me to items you asked for?
(Lo sentimos, la página no se encuentra disponible.)
(Hay 1 error : 01. la categoría no existe)
Mitja
Old Jan 10, 2012, 02:54 PM
supy_t is offline
Find More Posts by supy_t
Joined Apr 2011
a new Guppy is rising, in Romania.
supy_t is offline Find More Posts by supy_t
Build Log GUPPY electric sailplane Building&flying PART 1 ultralajt Electric Sailplanes 1129 Apr 26, 2016 01:43 PM
RadicalRC Microstick Building & Flying part 2 Earthbound Parkflyers 432 Jul 18, 2008 10:01 AM
Unicorn Wing Building Process - Part 2! tim hooper Foamies (Kits) 59 Oct 27, 2005 08:41 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 12:46 PM
