Old Jan 17, 2011, 03:34 AM
ultralajt is online now
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Sorry, dupicate post. Pleaase see: http://www.rcgroups.com/forums/showp...&postcount=525
ultralajt is online now Find More Posts by ultralajt
Old Jan 17, 2011, 03:36 AM
ultralajt's Avatar
Joined Sep 2004
Old Jan 17, 2011, 06:38 PM
dejfson is offline
Find More Posts by dejfson
Joined Jan 2011
Mitja,
thanks for your extensive report. It seems that one really needs a lots of practise and experience to get things flying. well, will see.
Mine fuselage can be found here:
https://belohrad.web.cern.ch/belohrad/DSC01788.JPG
i have to admit that it was quite a lot of work, and at some places it is screwed. But i take it as a tax for getting the experience.
One thing, which is not discussed much here is the covering tutorial. Especially how you and others made the covering composed of multiple colours and their combination. Is there some trick to position the stripes of foil correctly and avoid that it displaces under shrinking process?
(btw: i'm from CZ)
thanks again
d.
dejfson is offline Find More Posts by dejfson
Old Feb 22, 2011, 08:19 AM
dejfson is offline
Joined Jan 2011
Dear All,
i report partially successful maiden flight, you can see some videos here:
first start goes badly:
Guppy Flying test (0 min 22 sec)
second attempt:
Guppy Second Fly (0 min 58 sec)
Now, the thing is, I have to say that the first flight was wrong just because I did not check whether the rudder and elevator go correct direction. Rudder needed to be reversed and that's the reason why the plane fell off.
However in the second fly is visible some vertical instability I cannot explain for the moment. The CG is +- correctly setup as it should be, and the plane has tendencies to stall even in slight wind, and when running on the motor, it rises up quickly and then it stalls. So the flight is somehow waving and it takes lots of effort to keep the plane on-track.
Any ideas?
thanks
d.
Old Feb 22, 2011, 10:27 AM
Riverratss is offline
Find More Posts by Riverratss
Circa:1946
Riverratss's Avatar
Joined Jun 2008
Maiden
Mr. dejfson!
Might try a little more forward COG!
See how you like it?
Just my .02cts.
Regards!
Jimmy
Riverratss is offline Find More Posts by Riverratss
Old Feb 22, 2011, 11:12 AM
bfry is offline
Find More Posts by bfry
Joined Apr 2008
less throw on the control movement.
bfry is offline Find More Posts by bfry
Old Feb 22, 2011, 03:13 PM
Circa:1946
Riverratss's Avatar
Joined Jun 2008
Hand Launch!
Definitely concour bfry!!!!!!!!!
I like to hand launch griping the fuse below COG, & throwing out at a slight down angle!!!
Regards!
Jimmy
Old Feb 22, 2011, 04:59 PM
dejfson is offline
Joined Jan 2011
not sure what you mean by 'less throw on the control movement'. shall i just 'release' the plane from my hand and let it handle the stability itself?
Old Feb 23, 2011, 06:52 AM
n0bbyUK is offline
Find More Posts by n0bbyUK
n0bbyUK's Avatar
United Kingdom, Glos
Joined May 2009
Are the wing and tailplane set at zero degrees incidence, I.e. Are they parallel? If not and there is negative incidence then it will always want to stall as it is like having permanent up elevator applied.
When on full throttle you will either have to hold some down elevator in manually or if you have a computer tx you can mix some down in with the throttle so it climbs without stalling.
n0bbyUK is offline Find More Posts by n0bbyUK
Old Feb 23, 2011, 09:45 AM
Circa:1946
Riverratss's Avatar
Joined Jun 2008
Control Surface!
Mr. dejfson!
I think what bfry was saying is that your control surface travel is extreme!
Rudder-25MM L&R from zero measured at widest part of rudder.
Elevator-10MM U&D from zero measured at center of elevator.
Regards!
Jimmy
Old Feb 23, 2011, 10:31 AM
dejfson is offline
Joined Jan 2011
I see i see now guys.
I'll try to get it running during the week-end
Old Feb 23, 2011, 10:37 AM
bfry is offline
Joined Apr 2008
I have good luck with even a little less than the "factory" spec. on most planes.
It will help you not over control the plane. Give it a whirl.
Old Feb 27, 2011, 10:39 AM
Circa:1946
Riverratss's Avatar
Joined Jun 2008
How did it go?
Mr. dejfson!
Did you get to fly?
Regards!
Jimmy
Old Feb 27, 2011, 02:21 PM
dejfson is offline
Joined Jan 2011
Originally Posted by Riverratss View Post
Mr. dejfson!
Did you get to fly?
Regards!
Jimmy
I've tried second time. This time however:
1) i've changed CG. I found that the airplane was tail heavy, so by putting (quite a lot of) some material I've managed to get it where it was supposed to be according to planes
2) i've changed the end points to both ruder and elevator to conform with what is in the plans
... and then tried ...
It was much better that the first time, the plane stalls much less, however there is still some fancy behaviour when turning left/right. The plane has tendency to be quickly vertically, and once it is vertical (the wings are verically wrt ground), it points nose down and quickly drops. This can be avoided by not turning so aggressively, so maybe rudder trimming even more (now i'm at 30% on both end points) would help
I think however that combination of motor (XM2826) is definitely not very fancy with 6x3.5 foldable propeller (originally used with speed400 motor in drawings). Although the motor should have enough power (150W?), there is quite a lot of power lost due to mismatch with propeller, which - for this engine - should be somewhere around 7.5x4.5 or 8x5 (??).
This results in very small drag, so if the plane does not catch wind directly during hand launch, it drops to the ground almost like a stone.
And well, this is exactly what happened. So during my third or fourth fly the plane just dropped, nose down, propeller broken... have to order another one, but this time i'm rather thinking to order 8x5 foldable than original 6x3.5.....
i'm not sure whether this helps or not, but i guess this could be the way to go...
Old Feb 27, 2011, 09:45 PM
Circa:1946
Riverratss's Avatar
Joined Jun 2008
Guppy
dejfson!
I thought from the video the plane looked to be under powered.
Also tail heavy!
Keep going you will get it sorted out!
GOOD LUCK!!!!!!
Regards
Jimmy
Build Log GUPPY electric sailplane Building&flying PART 1 ultralajt Electric Sailplanes 1124 Sep 16, 2014 12:57 PM
RadicalRC Microstick Building & Flying part 2 Earthbound Parkflyers 432 Jul 18, 2008 11:01 AM
Unicorn Wing Building Process - Part 2! tim hooper Foamies (Kits) 59 Oct 27, 2005 09:41 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 07:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 01:46 PM
