Old Aug 23, 2009, 09:41 AM
diozxlive is offline
Find More Posts by diozxlive
Joined Nov 2007
how do you guys make the holes on the guppy elevators?
diozxlive is offline Find More Posts by diozxlive
Old Aug 23, 2009, 10:05 AM
Jack Stephens is offline
Find More Posts by Jack Stephens
Gadsden RC Flyers
Jack Stephens's Avatar
Joined Aug 2004
Cutting Holes
diozxlive,
This is how I cut lightening holes in all of my planes. I feel sure there are faster ways, but this way has always been my preference.
Jack Stephens
Jack Stephens is offline Find More Posts by Jack Stephens
Old Aug 23, 2009, 01:53 PM
Joined Nov 2007
Thank you Sir, but the elevators are 4mm.... it will take a lot of elbow grease tracing the circles... 14 holes...
Old Aug 23, 2009, 03:14 PM
Gadsden RC Flyers
Joined Aug 2004
diozxlive,
You call it elbow grease, I call it my hobby. Here are the tail feathers that I lightened for my Apogee Sport. 28 holes altogether.
Jack Stephens
Old Aug 24, 2009, 01:12 PM
Joined Nov 2007
...just followed your lead... for the love of the hobby. just bought a similar engineering circular template (rotring brand) so how do you cut the circle just trace around the template slowly? i find the i need to do almost 25 laps to cut a 3cm hole on a 3mm. balsa? am i doing it correctly?
Old Aug 24, 2009, 01:30 PM
Gadsden RC Flyers
Joined Aug 2004
diozxlive,
I use the template to draw the circle with a pencil. I then use the No. 11 blade to cut my way around the drawn circle freehand. I use an up and down sawing motion, working my way around the circle slowly. For thick material such as you are working with, it usually takes several passes around the circle to finish the job. Don't try to cut through in one pass.
To help ensure a cleaner cut on the back side, I watch for the first signs of the blade breaking through from the front, and finish the final few cuts from the back side. This will really help prevent tearing of the balsa.
Finish the hole with pieces of rolled sandpaper. I usually start with about 220 grit and finish with 400 grit.
Good luck,
Jack Stephens
Old Aug 26, 2009, 09:09 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Thanks Jack for helping to explain the hole making in balsa surfaces.
I use quite similar approach.
Often I use a metal tube instead of drill bit and "drill" holes trough a balsa. Beginers should try first on the scrap piece of balsa to get use to this method.
Then I widen hole diameter using sandpaper rolled in a "tube", or sandpaper wrapped around a dowel of apropriate diameter. Variying the number of sandpaper layers the size of hole is regulated...
It works for me....
Large diameter holes I usually cut with x-acto knife (a little smaller hole than needed) and then sand smooth and rounds it again with sandpaper wrapped around a round object of apropriate diameter.
Mitja
ultralajt is offline Find More Posts by ultralajt
Old Oct 26, 2009, 12:04 PM
toyheli is offline
Find More Posts by toyheli
Joined Oct 2008
Guppy wing assembly
I read the sailplane assembly manual, under the 'Wing Assembly' we were asked to cut Balsa cap strips 5x2mm, 455mm length. But the plan shows Balsa cap strip 5x2mm, 450mm length only. What is the additional 5mm for?
Also before joining the two halves of the wings, do we need to sand the wing ribs R1 to obtain a perfect V join? Can we join the wings, without sanding, at the right amount of dihedral and fill the space with 5 min epoxy?
One more question about the twist in the outer wing, what is meant by raise the TE at wing tip for about 3 to 5 mm when gluing the upper torsion box sheeting?
Does the assembly instruction meant that we keep Wing rib R5 level on the table and raise the TE wing tip by 5mm and glue the upper box torsion balsa sheet?
toyheli is offline Find More Posts by toyheli
Old Oct 27, 2009, 10:25 AM
varungarg is offline
Find More Posts by varungarg
Joined Oct 2009
How to join both the wings togther and fix the whole to the fuselage ?
Hello !!
I am plannin to make a guppy .
Is it possible to make a guppy in a month ?
How do i join the left and the right wing together and then fix it to the fuselage ?
Thank You
varungarg is offline Find More Posts by varungarg
Old Oct 27, 2009, 11:40 AM
kr3cik is offline
Find More Posts by kr3cik
kr3cik's Avatar
Joined Feb 2007
varungarg It is posible to make Guppy even in a week, or you can make it in a yare. It only depends on how many houres you will work each day.
toyheli If you cut balsa cap strip 5 mm longer you wil have posibility yo atache it to the table behind the wing and than you can sand it nicely to the rib.
With the V join you need to sand it as good as it posible. The adhesive join is stronger when betwen parts is as less glue as it is posible.
With the wing twist its like you describe. You can also use triangle stock balsa and diagonally put it under rear edge of Guppy outer wing panel. Twist is linear, from 0 at Outer wing panel root, to about 5-7mm (~0,24") at tip.
kr3cik is offline Find More Posts by kr3cik
Old Oct 29, 2009, 02:46 AM
Joined Oct 2009
Photo Instructions
Thank You !!
I would be highly obliged if someone can please help me with some photo instructions of how to join the left n the right wing n not the wing twist .
Old Nov 02, 2009, 04:13 AM
Joined Oct 2009
Speed of the Motor
Does Speed 400 means the RPM of the motor is 400 ?
what should be the RPM of the motor used in the guppy ?
Should it be brushless ?
Old Nov 02, 2009, 05:34 AM
ultralajt's Avatar
Joined Sep 2004
Originally Posted by varungarg View Post
Thank You !!
Look at those photos below.
It is not Guppy, but it is shown step by step, how to do it. (well...how I do it )
Old Nov 02, 2009, 05:39 AM
ultralajt's Avatar
Joined Sep 2004
Speed 400 is very old and obsolete motor, when nowdays highly efficient brushles motors, controllers and LiPo cells are available and are relatively cheap.
Buy an outrunner with outer diameter no larger than 27-28mm, weight of about 50-70g, folding prop with spinner , speed regulator that can handle about 18-25A with BEC that can handle 2-4 servos, and a Li-poly battery 3 cells of about 1000-1500 mAh
Mitja
Old Nov 07, 2009, 02:00 AM
Joined Oct 2009
Leading and Trailing edges ?
Thank You Mitja
I have already started making the legendary Hotliner guppy .
I am presently doing the wings .
I am cutting all the parts and not using the precut CNC parts.
In the Guppy Template there is no template mentioned about the LEADING and TRAILING spans of the wings .
Could You please attach the template if you have or i have to design it on my own (LEADING and TRAILING Edges) ?
Thank You
Varun
Build Log GUPPY electric sailplane Building&flying PART 1 ultralajt Electric Sailplanes 1129 Apr 26, 2016 01:43 PM
RadicalRC Microstick Building & Flying part 2 Earthbound Parkflyers 432 Jul 18, 2008 10:01 AM
Unicorn Wing Building Process - Part 2! tim hooper Foamies (Kits) 59 Oct 27, 2005 08:41 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 12:46 PM
