Old Apr 30, 2008, 11:00 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Originally Posted by lubak
Thank, Mitja
And video from maiden flight:
http://www.youtube.com/watch?v=w6ExGUttlyo
Excelent video, nice background music and a perfect flying.
I enjoy looking it!
"What a lucky man you are!"
Mitja
ultralajt is offline Find More Posts by ultralajt
Old May 03, 2008, 01:47 PM
LareeRudee is offline
Find More Posts by LareeRudee
Joined Sep 2004
I'm a late-comer
Is this a commercial glider? or a scratch built? source of kit or plans?
Enjoyed the recent video.
LarryR : )
LareeRudee is offline Find More Posts by LareeRudee
Old May 03, 2008, 04:11 PM
ultralajt's Avatar
Joined Sep 2004
LarryR : )
Guppy is my own design.
The main differences from other electric sailplanes of similar wing span are:
- cute design
- 95% made from wood
- unique reinforcment of rear fuselage part using carbon tube "hidden" by balsa
- low number of wing ribs (and they are made from quite thick balsa to be stiff)
- "user friendly" behaviour of the model
- ease of building
- quite well done drawings and instructions
- compheresive support here in rcgroups for all builders.
You can build Guppy from plans:
http://www.trgovinamodelar.com/Media...lans_tiled.pdf
and maybe you are interested in HOT wings with ailerons:
http://www.trgovinamodelar.com/Media...s%20krilci.pdf
and also look at assembly manual for Guppy:
http://www.polecataero.com/uploads/G...mblymanual.pdf
Or manual for HOT wing assembly:
http://www.trgovinamodelar.com/Media...er%20krila.pdf
or even order the KIT version at:
http://www.polecataero.com/products/guppy
I suggest you to take two evenings and browse trough both parts of Guppy to see more abot and find out how it is made and how it fly.
Regards!
Mitja
Old May 03, 2008, 08:22 PM
TFM70 is offline
Find More Posts by TFM70
USA, GA, Carrollton
Don't forget the great index at
http://www.rcgroups.com/forums/showt...28#post7552305
TFM70 is offline Find More Posts by TFM70
Old May 03, 2008, 10:57 PM
Joined Sep 2004
Yes, will browse the two threads
...........I suggest you to take two evenings and browse trough both parts of Guppy to see more abot and find out how it is made and how it fly.
Regards!
Mitja
Yes, I admit that I "jumped" prior to reading all that IS there already, but if I recall, it was VERY late at night [my time] and I liked it so much that I "asked before I read"..... but in your latest post, you gave lots of good "direction".
LarryR : )
Old May 04, 2008, 10:50 PM
orck is offline
Find More Posts by orck
Joined Aug 2004
there is also a European supplier from Poland http://www.e-flightrc.com/catalog/pr...roducts_id=543
I have bought the Guppy from these guys and finally after almost a year I manage to start the building (please no comments about that )
my first question is about the bottom of the fuselage, in the kit there are 3 sheets of 2mm balsa and another one sheet of 4mm, it looks like I have to glue the 3 sheets together, but what about the thickest one?
orck is offline Find More Posts by orck
Old May 04, 2008, 11:50 PM
Joined Sep 2004
Beautiful
I must say it AGAIN........... that is a BEAUTIFUL plane. Now for me, it must have TRANSPARENT covering; too beautiful to cover.
LarryR : )
Old May 05, 2008, 12:20 AM
ultralajt's Avatar
Joined Sep 2004
You should glue 3 sheets (2 mm balsa) together for the fuselage bottom. This is the only way, to get proper curvature. Glue them together and let the glue dry while clamp between two pieces of styrofoam, that are cut in proper curve shape.
Old May 06, 2008, 09:33 PM
javisuzuki is offline
Find More Posts by javisuzuki
Joined Aug 2006
An ARGENTINIA guppy!!!
Hello everybody, my name is Javier Suzuki, i`m from argentina and i would like to show to all of you my handmade GUPPY flying in Escobar Flying Field in Buenos Aires. Thanks Mitja, i`ve been following this thread and I made this exellent plane from the plans published. Actually im thinking in building a 2m guppy.
javisuzuki is offline Find More Posts by javisuzuki
Old May 07, 2008, 01:58 AM
geoffroy is offline
Find More Posts by geoffroy
Joined Apr 2008
Dear Matja,
My hotliner wing is almost finished. The assembly manual is easy to understand even if it's not in english. However, I have a question about de fixing of this wing on the fuse. Is it necessary to tune the incidence angle of the wing? Do we have to add some thickness between the trailing edge and the fuse? Or we simply screw the wing as it on the fuse?
Previously in the thread, you have written some words about a 2,5m guppy. I'm very interested by a Guppy of this size. Do you have some plans? Even if it's still an "experimental" plan, I'm interested.
more details on my website
geoffroy is offline Find More Posts by geoffroy
Old May 07, 2008, 02:00 AM
ultralajt's Avatar
Joined Sep 2004
Hi Javier!
I am happy for you! Wish you many happy flights!
If you are looking forward to build enlarged version of Guppy, there is a thread about building 2 m wingspan Guppy:
http://forum.modelarji.com/viewtopic.php?t=24837
You wil certainly dont understand the reading, but many pictures in thread tells a lot about.
Mitja
Old May 07, 2008, 04:14 PM
CANTZ506 is offline
Find More Posts by CANTZ506
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Hi Javier!
Mitja
Wonderful construction! It's a pity I can't read the text.
Interesting solution for the ailerons links; I'm only afraid about precision after long time.
CANTZ506 is offline Find More Posts by CANTZ506
Old May 08, 2008, 02:05 AM
ultralajt's Avatar
Joined Sep 2004
It is well known RDS system (Rotary Drive System) and works without slack, it has almost no friction, there are no elements outside wing contour (less parasite drag), and doesnt owerload the servo.
There is a trick to make RDS without slack.
The steel rod is captured between two plates of low friction material. These plates are separated on proper distance with two balsa stick that are slightly thicker than a rotary steel rod.
Now you squeze two plates together to contact the rod. The balsa stick are now compressed to proper height. Now drop some CA glue on outside of that balsa sticks and they instantly remain at current thickness. So, friction plates are now in just proper distance and steel rod has minimum possibleslack.
Some links to use of RDS system:
http://www.irfmachineworks.com/rds/
http://www.irfmachineworks.com/rds/article.html
Mitja
Old May 08, 2008, 08:54 AM
CANTZ506 is offline
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Mitja
Thanks for the info and the links, Mitja.
"Reading" again the post, I noticed that the two plates in contact with the rod are out of VTR (vitroplasta); initially I tought they were out of plywood.
Old May 08, 2008, 11:26 AM
orck is offline
Joined Aug 2004
(I hope this is the last quastion I am making, I feel sorry about alla these questions)
can you please give me direction on the use of urethane glue?
it is supoosed to expand so how we apply the glue? am I supposed to close the carbon with the balsa? but if the glue expands a lot I believe that it will become a mess of carbon, balsa and glue
because I dont have a clue what this glue look like (and I wont be lucky if i go to the stores asking for urethane glue) can you suggest me some brands?
Build Log GUPPY electric sailplane Building&flying PART 1 ultralajt Electric Sailplanes 1129 Apr 26, 2016 01:43 PM
RadicalRC Microstick Building & Flying part 2 Earthbound Parkflyers 432 Jul 18, 2008 10:01 AM
Unicorn Wing Building Process - Part 2! tim hooper Foamies (Kits) 59 Oct 27, 2005 08:41 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 12:46 PM
