Old Apr 05, 2008, 07:29 PM
keithn4 is offline
Find More Posts by keithn4
ireland
Joined Nov 2007
parkzone trojan t-28 esc
hey guys,
im thinkink of buyin the parkzone trojan t-28 in the next week or so. been reading a couple of threads about it for a couple of weeks, sounds like a nice bird. i also have a supercub
ive a couple of quiestions,
im gona change the esc 1st just wondering has anybody heard of these esc's and are they any gud?
Duremax 25 Amp Brushless
http://www.modelmaniacsonline.co.uk/...5337&CatID=303
TowerPro W30A Brushless Speed Controller
http://www.islandmodels.ie/component...art/Itemid,27/
TURNIGY Plush 25amp Speed Controller
has anyone any ideas, i really new to electrics,
are any of them any good?
which would ya reccomend and why?
would ya reccomend any of them?
plus do i need to get any thing else for this set-up?
thanks guys for any info,
keith
keithn4 is offline Find More Posts by keithn4
Old Apr 05, 2008, 08:27 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
I have a friend that uses the Tower Pro esc's and he claims he has not had a bad one yet and he's been using them for a while now in about 8 different planes. You are going to love the T-28, it's a great 2nd plane.
raz is offline Find More Posts by raz
Old Apr 05, 2008, 09:03 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Well, if you want a good ESC, then I recommend a Castle Creations Thunderbird 36. Castle Creations speed controlls are high quality, and work very well each time you power up. Plus I like the tone they make while arming up. The Thunderbird controllers may not have as many programming features as the Phoenix line, but they work very well.
http://www3.towerhobbies.com/cgi-bin...?&I=LXUTB1&P=7
I'd put Castle Creations above all speed controlls out there. A bit pricy, but worth every penny.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 06, 2008, 08:07 AM
keithn4 is offline
ireland
Joined Nov 2007
thanks lads for the quick reply, any ideas on the TURNIGY Plush esc?
cant wait to get my hands on the t-28, been reading sum great stuff about it
Old Apr 06, 2008, 12:55 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Keithn4....not all the issue with the T-28 is from the ESC.... the issue is that the ESC was designed to operate only 1 digital servo and PZ install 2 digital servos. Those 2 digitial and the other 2 servos are working the BEC to death...literially. I am running the EFLite 25 pro ESC on mine (still) with a EFLITe 480 (1020kv) motor. I switched out my rudder servo to a standard servo....my motor died during a flight which is why a replaced/upgraded it.
Things I would do:
1) replace rudder servo to HS65MG
2) Change battery connectors to Deans
3) Remove the ESC from the foam nad use double sided tape to mount it so its not "buried" in the foam (which holds in heat)
ATIS is offline Find More Posts by ATIS
Old Apr 06, 2008, 01:37 PM
IPFlyer is offline
Find More Posts by IPFlyer
Joined Nov 2005
Do you really need a metal gear servo??
IPFlyer is offline Find More Posts by IPFlyer
Old Apr 06, 2008, 03:45 PM
keithn4 is offline
ireland
Joined Nov 2007
Things I would do:
could ya use the HS55 servo?
what size props do ya use, would a 10x8 work? i have a few from my super cub?
Old Apr 06, 2008, 04:10 PM
IPFlyer is offline
Joined Nov 2005
The stock bird (960kv motor) comes with 9.5 x 7.5 props
Old Apr 06, 2008, 08:26 PM
ATIS is offline
Member 120mph Club
ATIS's Avatar
HS55 is too small....the HS85 or HS65 works...MG is not a requirement...
I am using the stock prop...but on the stock motor is a little weak for the claimed 960kv....when mine died during a flight I replaced it with the EFlite 480 (1020kv)...I have had great experience with that motor on APC 10x7 E and APC 11x5.5 E props (Estarter, Eflite P-47, PZ Spitfire, Typhoon 3d)
Old Apr 06, 2008, 08:32 PM
IPFlyer is offline
Joined Nov 2005
Good info - thanks!
Old Apr 06, 2008, 08:41 PM
JDOUBLEYOU is offline
Find More Posts by JDOUBLEYOU
LET'S GO PENS
JDOUBLEYOU's Avatar
Pittsburgh, PA
Joined May 2007
has anyone still had issues with the plane after they replace a digital servo or added an extra BEC? Is it a sure fix or can there still be issues?
JDOUBLEYOU is offline Find More Posts by JDOUBLEYOU
Old Apr 07, 2008, 06:11 AM
ATIS is offline
Member 120mph Club
ATIS's Avatar
I replaced the stock ESC (after it smoked with another EFlite 25) and 1 digital servo with the HS65MG and have not had an issue since... and I fly WOT the entire flight and treat her like a 3d plane... always doing loops, inverted, rolls, and combos....so I am always working the servos... and I did NOT add a BEC... the BEC is only needed if you want to keep the two digital servo in her.
Old Apr 07, 2008, 08:26 AM
IPFlyer is offline
Joined Nov 2005
I noticed Dimension Engineering's BEC do not appear suitable for the BEC change out. Any other ideas?
Old Apr 08, 2008, 05:51 AM
ATIS is offline
Member 120mph Club
ATIS's Avatar
If you are going the seperate BEC route....CC BEC towerhobbies.com
Old Apr 08, 2008, 08:43 AM
IPFlyer is offline
Joined Nov 2005
Thx! http://www.castlecreations.com/products/cc_bec.html# Note to Spektrum users; check the advisory. I like CC stuff - have lots of it.
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Help! Stop Me From Buying a Parkzone Trojan T-28! IPFlyer Foamies (Kits) 18 May 16, 2009 05:39 AM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone 480, 960kv motor for trojan t-28 la528it Aircraft - Electric - Power Systems (FS/W) 10 Apr 02, 2008 03:32 PM
Discussion Planning ahead: replacement Rx for PZ Trojan T-28 kelstertx Electric Plane Talk 2 Jan 05, 2008 11:55 AM
