Old Jan 10, 2003, 06:45 PM
sventek1 is offline
Find More Posts by sventek1
austin
Joined Jul 2001
vacuum pump from harbor freight
Any see these little red vacuum pumps for 15 bucks? Say they can pull somwhere around 25 or so inches. Says "venturi" style?
thanks
shane
sventek1 is offline Find More Posts by sventek1
Old Jan 12, 2003, 01:54 AM
ZagiArt is offline
Find More Posts by ZagiArt
Santa Paula, Ca
Joined Apr 2001
A venturi sytle of vacuum pump is not very usable for vacuum bagging. To get a Vacuum air from an air compresser is passed through a tube with a small hole in the side. The lower pressure in the tube caused by the fast moving air from the compresser will generate a vacuum, but not too much. The cost is the large volume of air required from the compresser. They are not very efficient. I'll look at the one you describe as soon as I can. Some time next week I can get by a Harbor Freight store. Happy flying!
ZagiArt is offline Find More Posts by ZagiArt
Old Jan 12, 2003, 05:37 AM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
"Venturi effect" for vacuum source...
It depends on the venturi design and the available cfm and psi available.
This technology is used to inflate the escape slides on passenger jets.
Even 2-3" Hg. is acceptable for 1#/sq.ft foam wing skinning.
A vacuum source without any mechanical positive displacement stuff has
got to some merit by virtue of it's longevity.
The way I would use this device would be to plumb the vacuum line to a
'tank' and run a line from the tank to your bag & wing setup with a valve.
Life sucks...make the best of it.
Jay.
AirBornOne is offline Find More Posts by AirBornOne
Old Jan 12, 2003, 09:24 AM
sventek1 is offline
austin
Joined Jul 2001
http://www.harborfreight.com/cpi/cta...temnumber=3952
Old Jan 14, 2003, 06:42 AM
sventek1 is offline
austin
Joined Jul 2001
here is a guy using one for bagging
http://www.rocstock.org/wizards/fiber101.vac1.html
Old Jan 17, 2003, 11:41 PM
ZagiArt is offline
Santa Paula, Ca
Joined Apr 2001
Well there you go! everybody should have a 3hp compresser with a 40 gallon tank.. I used an old compresser from a refrigerator and hooked up to the intake side. Enough vacuum for me. OOps don't get caught letting all of that Freon out though while acquiring the compresser! I got mine about 20 years ago! Happy Flying!
Sky Runner from Harbor Freight digsy Scratchbuilt Indoor and Micro Models 2 Jan 16, 2005 11:21 AM
New visor magnifying lens from Harbor Freight Jim_W Parkflyers 0 Jan 04, 2005 08:33 PM
23" span free flight from Harbor Freight. dvint Free Flight 4 Aug 29, 2003 11:55 PM
Sky Runner from Harbor Freight Greg Covey Scratchbuilt Indoor and Micro Models 69 Feb 18, 2003 10:25 AM
CNC setup for mini mill from harbor freight stealthy Life, The Universe, and Politics 0 Jan 21, 2002 02:32 AM
