This thread is privately moderated by thomer, who may elect to delete unwanted replies.
Old Apr 05, 2008, 04:39 PM
thomer is offline
Find More Posts by thomer
Trader Rating: 150
Off roading with the Fun Cub!
thomer's Avatar
CA
Joined Mar 2003
Trader Rating: 150
Sold
Clancy Aviation Big Bee Local P/U only Los Angeles, CA. *Reduced*
Clancy Aviation Big Bee ARF.
Never been flown, but needs minor work.
Needs a little work on the rudder as I took the hinges out to replace them. I also taped the ailerons to the wing so they are fixed, but this can be taken off if you so choose. The bottom of the wing needs a small patch of white monocoat where the aileron servo was cutout if you don't use the ailerons.
I'm putting this in the electrics forum because I converted it to electric. I made made a battery mount in the fuse.
I need to move this thing out. It's taking up too much room.
$90
thomer is offline Find More Posts by thomer
Old Apr 05, 2008, 05:05 PM
P-38J-Lightning is offline
Find More Posts by P-38J-Lightning
Trader Rating: 30
Team Me!
P-38J-Lightning's Avatar
AB, Canada
Joined Mar 2005
Trader Rating: 30
First in line if/when you decide to ship.
Not that it will last that long!
Joel
P-38J-Lightning is offline Find More Posts by P-38J-Lightning
Sold New Multiplex Twin Jet local p/u only Los Angeles thomer Aircraft - Electric - Airplanes (FS/W) 0 Feb 13, 2008 03:03 PM
Sold New Multiplex Twin Jet local p/u only Los Angeles thomer Aircraft - Electric - Airplanes (FS/W) 7 Jan 20, 2008 12:48 AM
Sold New Multiplex Twin Jet local p/u only Los Angeles-moved thomer Aircraft - Electric - Jets (FS/W) 0 Jan 18, 2008 01:32 PM
F/S Omei..2 flts. local p/u only mdlifcrisis Aircraft - Sailplanes (FS/W) 5 Apr 23, 2005 07:46 PM
F/S G.P. YAK 55 local p/u only mdlifcrisis Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2005 05:51 PM
