Old Apr 04, 2008, 06:53 PM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
How to make your own Hand Rails
1st : Choosing the Materials
In this case we're using copper wire (pink) and brass wire (yellow) of 1,5mm and 0,75mm. (The usual uniwire(one wire only) found in most electrical instalations)
2nd : Picking the isolator off
Any good knife will do it.
3rd : Straighting out
Straighten the most you can by hand. When done, attach one extremity to the drill and the other one to the bench lathe (or if you know you can stand it firmly, you can use a pliers, but you must hold it like a rock). Pulling the wire to the most you can, give some shots on the Drill (minimal speed) always pulling and straightning.
NOTICE : If the Drill has too many rotation/torque the wire can brake and cause serious injuries
4th : Cutting :
Equal sections, with the desired measure (respect the scale you are working on) usually a boat has hand rail height of 80 to 100 cms, depending on the boat (Don't forget to leave 3 to 4 mm of extension to fit (anchorage) the hand rails to the boat)
Take notice that most cutting pliers don't make the same cut to one extremety then it makes to the other, take advantage of this when choosing the anchorage and the soldering part.
5th : Yardstick :
Do this first to avoid later problems and repetitions
6th : Soldering :
30 or 40 Watts Soldering Iron (must be clean at all times), 60/40 Rosin Core, Deoxidizer or Soldering Paste (Greasy), Wood plate and Mould (this mould is a small wood square you glue to the wood plate to make the supports of the rail even).
The solder is taken out of the rosin core by the soldering iron in the exact quantity you need for that one joint.
When soldering, put the soldering iron on the joint and wait from 3 to 5 seconds till it melts perfectly on the joint.
Use any sharp tool at hand to hold the piece to the soldering point.
CAREFULL : With the extremly hot parts, after soldering they maintain their temperature for quite a while
With the 0,75mm brass wire, apply the rest of the accessories, but you have to do it faster to prevent the other parts from desoldering, You can also avoid this by applying a wet cotton.
Improvements :
If you have too much solder on the joints, you can get an eletrical multiwire (those with lots of small wires) and do the job. Apply some deoxidizer to the multiwire extremity, with the soldering iron give some heating to the joint you want to extract the excess, and when it's hot, apply the mutliwire and watch what happens.
Finishing :
After everything welded and done as you fill like, sand it off and wash the piece with alchool.
Note : The deoxidizer, in the long run, becomes a great oxidizer, so it's better if you clean this new piece in the end (and the tools you've just used lol)
Some Primer :
And you're done !!!!
Metatron is offline Find More Posts by Metatron
Old Apr 04, 2008, 08:19 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Excellent tutorial. Thanks!
Kmot is offline Find More Posts by Kmot
Old Apr 04, 2008, 08:31 PM
Sweeper Nut
Mike McCrea's Avatar
Northridge So. Cal
Joined Apr 2007
Wow!!!! Looks great, you make it look easy. Nice work.
Mike McCrea is offline Find More Posts by Mike McCrea
Old Apr 04, 2008, 08:40 PM
Yacht Captain
yacht boy's Avatar
Canada, BC, North Vancouver
Joined Oct 2007
Great tutorial,
Surely this is worthy of a sticky?
yacht boy is offline Find More Posts by yacht boy
Old Apr 05, 2008, 07:47 AM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
Cheers guys,
Thanks for the comments, but I don't know how to make it a sticky !? Anyone ?
Old Apr 05, 2008, 11:14 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
The 'Sticky Fairy' has to be the one to make it a sticky.
Old Apr 06, 2008, 07:24 AM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
Nothing to do then he he he
Thanks Tom.
Cheers.
Old Apr 06, 2008, 09:21 AM
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
The "Sticky Fairy"? Is this Alice in Wonderland?
Thanks for a great thread. I need to learn how to solder and ths will help a lot. Pete
norgale is offline Find More Posts by norgale
Old Apr 06, 2008, 04:30 PM
Joined Jun 2007
Metatron
Thanks I now know that there are at least two of us whose workbench looks the
same
Bob
b willow is offline Find More Posts by b willow
Old Apr 07, 2008, 12:28 PM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
Cheers guys,
Thanks for your comments.
Pete, hope this thread helps. I've put in all the steps so that even the first timer may understand it.
Bob, I'm sorry to say that you're the only one right now with a messy bench, mate.
Old Apr 07, 2008, 02:42 PM
Joined Jun 2007
Mate
You caused me to lose fate in believing that there are others like me.Don't let my
wife see this!
Bob
Old Apr 28, 2008, 10:00 PM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
Bob, you know how wives are, just give her a model boat by mother's day ...
Old Apr 29, 2008, 09:57 AM
Tieger's Avatar
Jakarta
Joined Apr 2008
Very nice discription
thank you
Andreas
Tieger is offline Find More Posts by Tieger
Old Apr 30, 2008, 07:37 AM
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
You're welcome Andreas.
Cheers.
Old May 21, 2008, 06:08 PM
Naval gazing
MA, USA
Joined May 2008
This is briliant. Answers all of the questions I was about to ask in a new posting in fact. A suggestion as an alternative to the damp cotton - if you're lucky enough to have some wet ceramic clay around, that works well too.
spacephrawg is offline Find More Posts by spacephrawg
Newbie: How to make your own battery packs? DaveyDave Batteries and Chargers 23 Sep 13, 2010 06:38 PM
Mini-HowTo How-to make your own plans ! ! ! ! ! ! ! 3dflyindan Indoor Pattern/F3P 2 Mar 13, 2006 02:29 PM
how to make your own canopy? chainick The Builders Workshop 7 Feb 13, 2005 02:52 AM
Question How to make your own JST connector ? tibofo Power Systems 1 Dec 30, 2004 05:47 AM
ParkFlyer Wall Hangers--How to Make Your Own! DavidJ Parkflyers 9 Feb 01, 2003 06:56 AM
