Old Apr 03, 2008, 09:48 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Depron Eagle
Quite a few years ago I built an Eagle Glider from polystyrene foam with brown paper covering, balsa 'body', and curled ply wing tip feathers, a flat tail and a clear perspex fin.
It was for towline/bungee launching, and was about the nearest thing you could get to bungying a propeller. Or come to that what would happen if a real Eagle got a leg caught in a bungee. As you can probably guess, it didn't fly.
So move on some probable 10 years plus and the EPP Eagle appears in the Foamie (Kits) forum. Ah! thinks I, I have some recently bought Depron.......so......
After quite a wait for calm weather and available time to match, at last I flew it this morning.
It will need the CG moving forward a little, but was quite flyable with all my down trim in, and is very stable yet quite maneuverable.
Some details -
59" span over the tip 'feathers'.
Weight 20oz with a 1700 3s lipo.
Motor 2408-21 turning an 8x4 HD prop.
Approx wing loading 4.4oz/sq.ft.
The base of the wing is 6mm depron with a balsa spar, then 3mm depron wrapped over it to form a 'section'. The fuselage, (should that be 'body'?), and tail are 6mm as well.
The wing is in two part for easy transport and rubber bands to the 'body'.
So far only one flight of about 15 minutes, powering up in a nice spiral, then just gliding around.
Here's the pictures.
eflightray is online now Find More Posts by eflightray
Old Apr 03, 2008, 09:52 AM
Hughbert is offline
Find More Posts by Hughbert
Planes are cool ;)
Hughbert's Avatar
Bath, UK
Joined Dec 2006
Nice looking 'bird' you've got there
Hugh
Hughbert is offline Find More Posts by Hughbert
Old Apr 03, 2008, 12:22 PM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Think i remember seeing the one you mentioned a few years ago, correct me if iam wrong it was featured in one of the magazines ??
Lookin good...
Dom.
domll is offline Find More Posts by domll
Old Apr 03, 2008, 12:38 PM
caeman is offline
Find More Posts by caeman
Crash Test Pilot
caeman's Avatar
Joined Aug 2007
That is one beautiful airplane you got there.
caeman is offline Find More Posts by caeman
Old Apr 03, 2008, 01:39 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Do you have any plans to post for that cool bird?
Mark
kram242 is offline Find More Posts by kram242
Old Apr 03, 2008, 01:52 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Wow....very good looking bird! I read the info on the kit eagle, but did not get one as I really enjoy building from foam. How is the glide rate? It looks like a blast to fly. Any plans or videos would be outstanding!
It has to be beautiful flying in the air.
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Apr 03, 2008, 03:40 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Sorry there are no plans, I'm a 'roughly mark out some lines on the material and start cutting and gluing' type of modeler.
I used a picture of the EPP Eagle and guessed the rest. My principle is, if 1/4" difference doesn't matter, probably 6" wont either.
Here's a crude picture, (well I did it using Paint, so don't expect much), of how I made the wing, which is about 80% of the bird.
