Joined Sep 2007
Thanks. I think u guys addressed most of the points. Innovative designs did provide some feedback, but he stopped short and only said that the higher kv motor will be more efficient. (Thanks for your input lucien, it was helpful nontheless)
There is also a balance where using a lower kv motor and a big pinion might result in not enough torque to counter fast changing loads over quick pitch changes. The motors in question are the Scorpion 2221-8 (3560kv) and the 2221-10 (3000kv). I did decide to go with the higher kv motor, not also least because its almost sold out everywhere, i guess that might suggest something about its suitability for a 450 size heli. Next question: What is the lowest headspeed i can run to maximise flighttime while still maintaining enough cyclic control do perform reasonably quick flips? i am not really at the level of hard 3D yet. I know its a personal preference and i would probably have to experiment on this. But what are you guys running out there? Thanks for all your input!!! |
Joined Sep 2007
I am now worried that these packs might not have enough discharge capability to feed a scorpion motor running 2700-3000 rpm. Should this be a concern? the LHS is advising that it will result in very hot packs if the current draw is always above 20C If this is so, it looks like i'd have to sell the batteries and move on, in which i could consider the 4S packs. (then again, i just ordered the motor )
The power draw required by the power systems is fairly constant for a given heli and head speed. The power is in Watts though, current * voltage. The heli may draw, for example, 120W in hover; on 3S, nominally 10.5 to 11V under load, this is about 11A current. With 4S at about 15.5V, it would be 8A or a little less. So going from a system driven by a 2100mAh 3S battery, you can switch to 4S 1500mAh and have the same total power capacity but at lower current, and the weight comes out pretty close.
The ProLites on my Dragonus do just fine driving it at 2800 RPM, but it's about at the top of their comfortable range. It's nowhere near 20C- I don't know where that came from -but discharging the pack repeatedly anywhere near it's rated capacity is going to wear it out quickly. |
Joined Sep 2007
Sorry if i was not clear initially. The prolites are rated 15C cont and max of 25c. (i thought it was 20)
Do you have any problems with the prolites on your dragonus (i presume its a 450 size) If it is still managable, i will just keep them rather than selling them 2nd hand at a substantial loss. |
No problem at all; they're very good batteries in my experience. Yes, the Dragonus is a 450-sized heli. I think the highest I've measured in current was 29A in full throttle, full pitch punchouts, but that is never more than a second or two.
Do please note that the numbers I quoted above were more for comparison than anything else; they're realistic, but a lot of things can change your current draw. The real test is to try flying them and measure the flight times and temps (or use an inflight logger like the EagleTree). That said, I've flown the PL2100s as high as 15-16A continuous without them heating excessively, but typical for my 450s is somewhere between 10 and 14A or so. |
I just got that same motor today. Thinking of using 12t pinion. I don't no what all the kv is all about, more rpm less torque? But i do know that the Neu, for me 1107 & 1105 didnt have enough power on 3s. Maybe it has something to do w/ my altitude of 5000ft. Using Neu 2100 packs, i only get about 8-9min on fff and some inverted 3d. Motor and batts are hardly warm. I guess its efficient at the cost of power? I also got the Medusa motor today also. We'll see how the two new motors stack up to Neu in power. Im willing to bet that the Scorpion has more torque/power because its an outrunner. |
Hey Jason you package went out yesterday. Please let me know what you think against the Neu and others.
Latest blog entry: Logo build
Joined Sep 2007
thazy let me know how the performance is with the 12 t, im still deciding on the pinion so your feedback is appreciated. My goal : longest flight time with the lowest head speed possible to do mild 3d. of course a higher headspeed is always better but i hope to achieve the long(est) flight time possible.
| Thread Tools | |
| Discussion Hi Kv or low Kv motor for pattern? | cloud-9 | Indoor Pattern/F3P | 20 | Jan 23, 2008 07:49 PM |
| Discussion Vintage thermal snifflers (varios): high battery drain or low drain? | arukum17 | Batteries and Chargers | 0 | Nov 05, 2007 05:19 AM |
| Discussion Where to buy 550 or 600 brushed High Kv Motor HELP!!! | wac | Racing Boats - Electric | 5 | Jun 13, 2007 03:26 PM |
| Wanted Himax 2025-5400 or similar high KV motor | flanker | Aircraft - Electric - Power Systems (FS/W) | 1 | Aug 12, 2006 09:11 PM |
| High KV or Low KV | RockyTse | Power Systems | 2 | Apr 26, 2004 09:51 AM |
