Old Apr 02, 2008, 07:55 PM
soulys is offline
Find More Posts by soulys
My name is Geng
soulys's Avatar
Ashburn,VA
Joined Dec 2004
900mhz, 1.3ghz, or 2.4ghz?
what are the difference between the three and which one has the best range and quality?
soulys is offline Find More Posts by soulys
Old Apr 15, 2008, 03:02 PM
Zukoff is offline
Find More Posts by Zukoff
Joined Apr 2008
900MHz - is the best. It is legal only in USA.
2.4 GHz is legal everywhere, but it is can work bad with 2.4 Ghz transmitters nearby.
1.3 GHz is legal in Europe for radio hobbyists.
Who did used 1.3 GHz how is it good compared to 2.4 GHz?
Zukoff is offline Find More Posts by Zukoff
Old Apr 15, 2008, 05:30 PM
lee2005 is offline
Find More Posts by lee2005
lee2005's Avatar
UK, South Yorkshire, Rotherham
Joined Nov 2005
I'm using 1.3ghz now. i used to use 2.4ghz and i used to get allot of multi path issues. but now with 1.3ghz i get less interference and I'm only using the stock antennas. it is only 300mw though not 500mw.
Edit: also i can't notice any differnace in video quailty. but i can tell a differnace in sound quality slightly, but all you hear is the motor so it doesn't bother me .
lee2005 is offline Find More Posts by lee2005
Old May 01, 2008, 08:21 PM
fuhan2000 is offline
Find More Posts by fuhan2000
fuhan2000's Avatar
Joined Jul 2006
lee2005,
Do u have GPS onboard your plane? GPS use a couple of frequencies (e.g., signal L1 is 1575.42MHz.) Any interference between the GPS and 1300MHz VideoTx.?
Has anyone here use 900MHz for FPV when a GSM basestation is located ~500 meters away? To be more precise, it is a GSM 900/1800.
So,
1.3GHz is great. But what about GPS?
900Mhz is said to be better at going through obstacles. But what about GSM inteference 500m away?
2.4GHz is ok. Until those 2.4GHz RC Tx got swicthed on.
Rgds,
fuhan
fuhan2000 is offline Find More Posts by fuhan2000
Old May 02, 2008, 03:05 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
also you should know is much more easy to find 2,4 ghz antenas than 900 or 1,3 ghz,
2,4 ghz is used everywhere, microwaves, wifi, bluetooth... so you need go to a "clean" area for a better reception.
as lower the frecuency, then better the object penetration. 900 will performe better in a house than 2,4 ghz.
has highter the frecuency, then tinyer the antena. a 2,4 ghz 3dbi antena is smaller than a 3dbi antena of 900 mhz.
also you should know that...
with a a 300 mw output power at 1,3 ghz you will get the same range than a 500 mw at 2,4 ghz transmitter
so highter not always means better.
hope it help you the decide wich one fits better your needs.
wallaguest1 is offline Find More Posts by wallaguest1
Old May 08, 2008, 02:44 AM
mjr_larkin is offline
Find More Posts by mjr_larkin
Joined Dec 2007
So what benefit does 1.3ghz have over 900mhz?
mjr_larkin is offline Find More Posts by mjr_larkin
Discussion 900mhz or 2,4Ghz caret Xtreme Power Systems 6 Mar 09, 2008 05:39 PM
Discussion Carbon and DX7 (or 2.4Ghz in general) Raphael Radios 52 Apr 11, 2007 06:02 PM
Discussion 1 motor or 2? Forester Power Systems 6 Dec 23, 2006 12:04 AM
WTB Graupner 1.85 or 2.33 gearbox or G/B parts SchiessCo Aircraft - Electric - Airplanes (FS/W) 4 Jun 14, 2002 12:25 AM
