Old Apr 02, 2008, 11:40 AM
julian.i is offline
Find More Posts by julian.i
Flys like a chocolate teapot
Joined Mar 2008
Question
planks pitch stability
hi
does anyone know of a ratio of chord to wingspan that a plank with no other horizontal support will remain stable?
and is there anything i can do apart from dihedral, sweep and as low a COG as possible to help lower this ratio?
thanks
julian
ps im talking about an unpowered plank if that makes any diff
julian.i is offline Find More Posts by julian.i
Old Apr 02, 2008, 11:56 AM
screamin' eagle is offline
Find More Posts by screamin' eagle
Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
I don't know of any hard and fast rules, but I've built/flown a handful of different homebrew planks. To use a concrete comparison, I've done two different 60" flying wings. One had a 6 1/2" root chord and 5 1/2 inch tip chord. The other has a 9 1/2" root and 4" tip chord. Both are single tapered at both LE and TE. Both are very pitch stable, even for flying wings.
screamin' eagle is offline Find More Posts by screamin' eagle
Old Apr 02, 2008, 12:02 PM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Originally Posted by julian.i
hi
chord:wingspan (i.e. aspect ratio) should have little or no effect on stability - which is chiefly a function on the airfoil pitching moment, in combination with reflex on the elevons. Plank airfoils like PW51 & MH64 are specifically desinged to be pitch stable.
EDIT - For more info see e.g. Martin Hepperles site:
http://www.mh-aerotools.de/airfoils/index.htm
follow "flying wings" & the links at the bottom of the flying wings airfoil page - he explains it all in there...
Phil
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Apr 02, 2008, 12:03 PM
julian.i is offline
Joined Mar 2008
are you using a zreo camber airfoil? or do you have to adjust the elevons up? or is the pitching moment of the airfoil totaly overcome by the low centre of gravity? ------edit------thanks Phil lol you got there first-------
cheers
Discussion Effect of landing gear on pitch stability deh6 Modeling Science 5 Feb 06, 2007 07:59 AM
pitch stability in a dive chainick Flying Wings 13 Aug 31, 2005 10:02 PM
Question Pitch Stability Twinkletoze Hand Launch 19 Mar 23, 2005 04:18 PM
