Old Jan 09, 2003, 10:03 PM
tenover is offline
Find More Posts by tenover
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Need help fixing pop-up trailer FAAST!!
So I'm packing for a desert trip tomorrow, and when I went to put the top down on my pop-up trailer, it wouldn't go down (you know, the kind where you turn the crank one way to lift it, and the opposite to go down). I unscrewed the "crank mechanism", and it seems like it will go up because it's tightening itself, but when I turn it the opposite way, it unscrews itself, thus not turning the gears!!! Help, my wife is freaking, and I need to fix it tonight!! Should I just throw some Loctite in there so it will stick?? Please help....
Scott
tenover is offline Find More Posts by tenover
Old Jan 09, 2003, 11:03 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Scott,
Sounds liek something may be binding and causing the handle to uncrew rather than move the gears. How long has it set open? I would lubricate everything that moves or slides, and look for missalignment in the lift mechanics, if the lube dont get it moving. Is it sitting on a level spot? Has it been since left open?
Hmm,
David
David Hogue is offline Find More Posts by David Hogue
Need help in setting up Futaba 6hsx on eolo nofuelheli Electric Heli Talk 4 Sep 10, 2003 11:13 PM
Need help fixing my Omega 1.8 FX1SUB Electric Sailplanes 7 Dec 02, 2002 09:41 PM
Need help on cleaning up wing sheeted surface. KOMET 44 Power Systems 2 Feb 07, 2002 09:50 AM
