Old Jul 04, 2008, 04:55 PM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
RcHobbyHelicopter.com Has International Shipping!
Originally Posted by Condor8000
Hey John,
When are you going to start shipping abroad?
I'm hooked on BL MIA's LOL!
Best Regards
Condor8000, Norway
Yes i have been shipping out Internationally for the past 3 weeks!
-cheers, johnw
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old Jul 04, 2008, 04:59 PM
Tucson,AZ
Joined Dec 2007
Sweet little Heli By The Way!
Cheers, johnw
Site Sponsor
Old Jul 04, 2008, 05:25 PM
jdog83 is offline
Find More Posts by jdog83
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
cooling hole on this motor?
but there are holes cut into the side of this tiny main motor to help cool it down?.....did they have this on the original motor?
jdog83 is offline Find More Posts by jdog83
Old Jul 04, 2008, 05:29 PM
Condor8000 is offline
Find More Posts by Condor8000
Skien, Norway
Joined Apr 2008
How did i miss that!?!?!?
Ok, now i know where to order next time!!
My MIA flies like a dream, except i do struggle with the tail authority.
I tried with a Micron tail rotor blade, and it seemd more responsive together with higher speed on the tail motor. Maybe my tail motor is dieing...
Best regards
Condor8000, Norway
Condor8000 is offline Find More Posts by Condor8000
Old Jul 04, 2008, 05:58 PM
fretman is online now
Find More Posts by fretman
fretman's Avatar
United States, CA, Lake Forest
Joined Dec 2007
you should try the geared tail setup with the MIA, then it will really fly like a dream.
fretman is online now Find More Posts by fretman
Old Jul 04, 2008, 06:02 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
johnIn2SonAZ,
Are any of the 4#3B MIA upgrades not put together by glue? I don't trust glue. I prefer bolts. Thanks
tonyastro is offline Find More Posts by tonyastro
Old Jul 04, 2008, 06:31 PM
Skien, Norway
Joined Apr 2008
Is the direct drive making the tail slower?
It's impossible to do any quick piros now.
I guess i will try the geared tail setup. Thanks fretman.
Best Regards
Condor8000, Norway
Old Jul 04, 2008, 06:37 PM
Skien, Norway
Joined Apr 2008
They are glued together. Done properly, they will be very strong.
My 3 year old stepped on my MIA framed 4#3, and it held together, except
a canopy and flybar.
Check out Marios assembly videos.
Mario offers some metal spacers instead of the white plastic blocks separating the lover and upper frame.
Best Regards
Condor8000, Norway
Old Jul 04, 2008, 07:17 PM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
Best Regards
Condor8000, Norway
I like geared tail too
when putting tailcase on mia boom-you can either drill it out and pressure fit
or do like I did and snip tailcase where it mounts on boom-I let the pressure of the plastic hold it on-works great! and can just slip tail wires through notch
also if you tried new tail motor and still no authority try this:
put rudder trim all the way to right, turn on tx, initialize heli, then center rudder trim
worked on my v1 bl
on my v2 bl didnt need any trim-but climbout sucked
mk
microkites is offline Find More Posts by microkites
Old Jul 04, 2008, 07:23 PM
fretman's Avatar
Joined Dec 2007
Best Regards
Condor8000, Norway
DD tails doesn't have nearly the responsiveness as the geared setup. And the motor seems to work much harder as it gets pretty hot after each flight. With geared tail the motor is barely warm. I really wanted to go DD myself to avoid the headache of the tail gears, bearings etc.. coming apart but just doesn't work well enough for my tastes.
Happy 4th everyone!!
Old Jul 04, 2008, 07:31 PM
fretman's Avatar
Joined Dec 2007
put rudder trim all the way to right, turn on tx, intialize heli, then center rudder trim
worked on my v1 bl
mk
You mean, left trim all the way before initializing?
Old Jul 04, 2008, 07:32 PM
Tucson,AZ
Joined Dec 2007
RcHobbyhelicopter Slightly Modded 4#3A V2
Just had some free time to do a little Modding.
4#3A V2
MIA Deluxe Flybar Tuning Kit
MIA Tuff Skids W/stock Battery Cage
I had to use longer screws from the Losi 1/36 truck parts bag and ream out the holes in the skids to get this to fit.
Turned EXTNT up!
Very Fun to Fly!
Happy 4th!
Cheers, JohnW
Site Sponsor
Old Jul 04, 2008, 08:05 PM
Joined Sep 2007
hmm -if I remember right I was having to do it to the right
matter of fact I am sure of it!
maybe I was doing it wrong all that time-but it sure fixed my tail authority!
I have repeated this many times-but it amazed me that I didnt have to touch my tail trim for almost 300 flights/crashes!-and over 50 of them brushless
I suspected it was the new gearing
mine was pre-production-set up perfectly
also my original motors were short ones- for over 150 flights on one!
in example-motor mesh was spot on for all that time. same with flybars and collar- no adjustments for all 250-300 flights!
point of all this being-
if TUNED perfectly, this thing needs no mods(imho)spring, rubber band, nothing!
I reccomend using your ears to tune too
I could hear the quiet new v2 servos working while I was hovering-just friggin amazed me!
mk
Old Jul 04, 2008, 08:06 PM
Skien, Norway
Joined Apr 2008
Good suggestion.
Thanks MK.
Best Regards
Condor8000, Norway
Old Jul 04, 2008, 08:11 PM
Tucson,AZ
Joined Dec 2007
You have to Move the trim all the way to the opposite direction.
for example if you have the trim all the way to the left and the tail still isn't still move the trim all the way to the right and then have the gyro center itself upon initialization.
-johnw
Site Sponsor
Mini-HowTo WALKERA 4#3 Mods. Vario3 Micro Helis 77 Oct 31, 2008 12:20 PM
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 06:27 PM
Sold Walkera 4#3 flys awesome! trab1925 Aircraft - Electric - Helis (FS/W) 7 Feb 26, 2008 11:08 PM
Discussion Walkera 4#3 mods red-panda Micro Helis 10 Oct 11, 2007 01:45 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 07:19 AM
