Old Jun 19, 2008, 12:16 AM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
Originally Posted by jdog83
i used a piece of antenna rod for a tail boom, and a stiff metal wire for the flybar and wow what a stable heli!
the biggest difference i noticed was with the stiffer metal tail boom. not only do i not have to keep replacing tail booms, i now have a much more stable heli!!!
has anyone broken the frame of the heli from an antenna rod tail boom?
it seems too stong for the plastic...but is it ever sweet!
jdog
I suppose it is possible- but not real likely I think
depends how you crash, I suppose
did you need to mod yours?
many diameter of antenna out there- do you know what tx yours if from(or company)?
I am using a slightly smaller diameter one to save weight and so I can pressure fit it-used liquid electric tape and dipped to make seal
still very strong!
I use magnet wire for my t. motor wire so no problem running it through
mk
microkites is offline Find More Posts by microkites
Old Jun 19, 2008, 12:49 AM
fretman is offline
Find More Posts by fretman
fretman's Avatar
United States, CA, Lake Forest
Joined Dec 2007
jdog
With enough crashing the boom mount on the frame will eventually crack. ask me how I know?
I tied the boom back on with cotton thread down the boom about an inch and ca'ed it. that one never broke. one downside is you're adding weight.
Then I moved everthing over to the MIA frame and never thought of the boom again.
fretman is offline Find More Posts by fretman
Old Jun 19, 2008, 01:08 AM
MarioIArguello is offline
Find More Posts by MarioIArguello
MarioIArguello's Avatar
Joined Jun 2006
Originally Posted by 1Hammer
I have a shopping cart full of things for the 4#3 including a G-10 ridged frame which I'm intending to build with all 4#3B 2.4ghz parts. How can I be sure I receive the newer frame that works with the 4#3B servos and main gear when I place my order?
Thanks again, John
John, all current MIA 4#3 frames (double servo holes) shipping are compatible with the Walkera 4#3B version, as well as, backwards compatible, with the original Walkera 4#3 and 4#3A.
MarioIArguello is offline Find More Posts by MarioIArguello
Old Jun 19, 2008, 02:07 PM
pristo82 is offline
Find More Posts by pristo82
pristo82's Avatar
Nottingham UK
Joined Jan 2007
Originally Posted by MarioIArguello
Hi Ross,
I personally like the Carbon Flex with the cool flex struts but I don't crash land as often as a beginner pilot so this is the way I would go if I was looking from the outside into the upgrades at my site. I would also go with an "Edge" canopy or the "Phantom Carbon Pattern" one, because they were designed for the MIA frames, specifically and they give the helicopter a unique personality. These frames also provide improved flight characteristic by nature of their design.
I would recommend getting the MIA TUFF Ultra-Miniature LG, as a retrofit to the MIA frames for the 4#3's or as a direct retrofit to the stock 4#3's, any of them. This particular LG was made avaialble, in response to people requesting a more durable one. This is also one of my favorite items, because of its ultra durability and utility, but for looks, I like the carbon struts that come with the Carbon frames. Some folks like the Rigid ones, I do too but these may be a bit to rigid for beginner pilots.
The Preset Deluxe Flybar is an excellent upgrade, these really increase the stability of the rotor head and you will feel the difference right away. I would also add the matching anodized shaft collar-swashplate standoff, this part keeps the swashplate from moving up and down. You can do this with a couple spacers made from plastic tubing really easy, but the alu parts have a preset height and makes install a snap, these also add to the aesthetics of the whole helicopter by complementing the red rotor head parts of the 4#3B.
There is also a brand new training gear, this follows in the tradition of the MIA TUFF LG so this one is calle the MIA TUFF Training gear - Palm Size helis, it has been specifically developed for palm size helis such as the 4#3, there is also one for the 52# pictures of these new items will be at my site this week end.
Get the 500mah battery that John carries , also these are very nice batteries. John has also done some brushless setups and he has the motors to do so. I have done custom brushless setups, as well, but I don't sell the motors. John carries MIA upgrades as well so if you want to order all in one shot, John can also set you up with MIA upgrades. We can also help you via my site. Thanks.
Thanks Mario, i will take you recomendation on board and get the preset deluxe flybar , collar and tuff struts , i will also buy a new frame and canopy and some batteries from john ,
Look forward to having a MIA 4#3b
Ross
pristo82 is offline Find More Posts by pristo82
Old Jun 19, 2008, 07:01 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Picofly,
Take a look at my earlier post, the one with the pictures of the canopies on the digital scale. The MIA Edge canopies (any color that is on my site) are lighter than the stock 4#3B canopies. Even the MIA PHantom Canopies are lighter than the Stock 4#3B one, so whcih ever you chose should keep your 4#3B lighter. If you go brushless and direct drive I recommend the MIA frames.
I'm looking for an alternative to the stock canopy as well because they break too easy.
So, your Phantom canopy will fit right onto the stock 4#3B without any modifications?
Is it stronger?
Do you have any pics of it on a stock 4#3B or 4#3 ?
sideburn is offline Find More Posts by sideburn
Old Jun 19, 2008, 07:28 PM
Joined Jun 2006
Is it stronger?
Yes the Edge or Phantom canopies will fit the stock 4#3s, just drill the mounting hole for the canopy support bar accordingly. Note on the 4#3B, the stock frame has mounting provisions for a secondary canopy mounting bar at the front of the motor plate. So if you want to use the front mounting, the canopy will install like on the following picture. I trimmed the canopy underside, slightly, to clear the MIA TUFF struts, which are mounted directly to the 4#3B plastic frame. This is one of various LG and Canopy mounting options available with MIA parts.
Old Jun 19, 2008, 08:25 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
Mario,
Great stuff... now for the wooden blades...
SteveH
shoutchen is offline Find More Posts by shoutchen
Old Jun 19, 2008, 10:52 PM
1Hammer is offline
Find More Posts by 1Hammer
Micro Helicopter Electrician
1Hammer's Avatar
Central California Coast
Joined May 2008
The following MIA upgrade part kits have been added to our site.
* De-Luxe Flybar Stabilization kit
* Main Shaft Collar - Swashplate Standoff Kit
* TUFF(tm) Training Gear -Palm-Size Helicopter
See attached pictures for explanation and benefits each kit provides your 4#3.
Mario, I just completed my order. Very cool, I'm looking forward to much fun with the new and improved parts!
Thanks, John
1Hammer is offline Find More Posts by 1Hammer
Old Jun 21, 2008, 12:39 PM
jdog83 is offline
Find More Posts by jdog83
I Like Deraring
jdog83's Avatar
Canada, ON, Guelph
dollar store
just get a tv antenna from the dollar store buddy!!! none of this expensive tx equipment!!!
much better with this mod, less frustrating too, less finicky too....and not much more weight, in fact i don't even think it moved my c of g...
does anyone know if the tail motor pulsates because the rotors and/or flybar are out of balance? cause that what it seems like to me...
please advise
jdog
jdog83 is offline Find More Posts by jdog83
Old Jun 23, 2008, 03:18 PM
nexgen is offline
Find More Posts by nexgen
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
So I am running into a recurring problem with performance on my G-10 setup. I seem to be running through bearings like crazy. the little white block doesn't hold a good seat for the bearings anymore, they pop out quite often. I can see inside the block where the outside of the bearing slips, it is creating a black area where they are slipping. I am trying to find a good way to fix this without gluing the bearings in, as I have tried that before, but not enough, and they still slip, too much and I glue the bearing . Any suggestions?
nexgen is offline Find More Posts by nexgen
Old Jun 23, 2008, 03:22 PM
Kelley is offline
Find More Posts by Kelley
Kelley's Avatar
Goodyear, AZ
Joined Jan 2003
Mario,
Is the TUFF landing gear for the Walkera frame still available? I don't see it on the site any more
Kelley is offline Find More Posts by Kelley
Old Jun 23, 2008, 03:52 PM
Joined Jun 2006
Remove the bearing and smear a bit of white Elmers glue aroung the white block let it dry completely, this should create some tension for the bearing then reseat the bearing make sure the bearing sits square and flush. THe blocks normally have some tension so when the bearings are installed they should have a press fit. Unless the bearing is has locked with the shaft this wil overpower the press fit creating what you described also if the bearing is too loose you will see the black ring around the white blocks. Contack cemement wil work also since it dries to a rubbery surface and should lock the outer surface of the bearing in place. Follow the same install procedure make sure the bearing sits square. Alternately, you can smear a thin coat of contact cement on both the outer metal part of the bearing and then to the inside of the white block let dry then gently press fit.
This is not required with new installations as there is enough tension on the block bearing pockets to hold the bearings in place.
Old Jun 23, 2008, 03:53 PM
Joined Jun 2006
Originally Posted by Kelley
Mario,
Yes it is there.
Old Jun 24, 2008, 12:06 AM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
tuff skids
Mario,
they are at www.rchobbyhelicopter.com
at a discount!
-johnw
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Mini-HowTo WALKERA 4#3 Mods. Vario3 Micro Helis 77 Oct 31, 2008 01:20 PM
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 07:27 PM
Sold Walkera 4#3 flys awesome! trab1925 Aircraft - Electric - Helis (FS/W) 7 Feb 27, 2008 12:08 AM
Discussion Walkera 4#3 mods red-panda Micro Helis 10 Oct 11, 2007 02:45 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 08:19 AM
