Mia 4#3b
Hi mario , my 4#3b flys very well stock , but im dying to have a go at one of your frames , so the question is which setup have you found the best ?
I was thinking g10 frame rigid , preset deluxe flybar and a canopy Is there anything else you would add to this list ? Also have you tryed a 4#3b brushless setup yet ? using your upgrades Cheers Ross |
Helsinki, Finland
Does a MIA Edge cannopy fit to standard 4#3B frame? I would like to save some weight with the cannopy. I have understood that MIA cannopies are 1.2g lighter than 4#3B the standard one. At this time I am not willing to uppgrade to a whole MIA frame. I want to keep my 4#3B as small and lightweight as possible.
More on MIA upgrades for the 4#3B
I personally like the Carbon Flex with the cool flex struts but I don't crash land as often as a beginner pilot so this is the way I would go if I was looking from the outside into the upgrades at my site. I would also go with an "Edge" canopy or the "Phantom Carbon Pattern" one, because they were designed for the MIA frames, specifically and they give the helicopter a unique personality. These frames also provide improved flight characteristic by nature of their design. I would recommend getting the MIA TUFF Ultra-Miniature LG, as a retrofit to the MIA frames for the 4#3's or as a direct retrofit to the stock 4#3's, any of them. This particular LG was made avaialble, in response to people requesting a more durable one. This is also one of my favorite items, because of its ultra durability and utility, but for looks, I like the carbon struts that come with the Carbon frames. Some folks like the Rigid ones, I do too but these may be a bit to rigid for beginner pilots. The Preset Deluxe Flybar is an excellent upgrade, these really increase the stability of the rotor head and you will feel the difference right away. I would also add the matching anodized shaft collar-swashplate standoff, this part keeps the swashplate from moving up and down. You can do this with a couple spacers made from plastic tubing really easy, but the alu parts have a preset height and makes install a snap, these also add to the aesthetics of the whole helicopter by complementing the red rotor head parts of the 4#3B. There is also a brand new training gear, this follows in the tradition of the MIA TUFF LG so this one is calle the MIA TUFF Training gear - Palm Size helis, it has been specifically developed for palm size helis such as the 4#3, there is also one for the 52# pictures of these new items will be at my site this week end. Get the 500mah battery that John carries , also these are very nice batteries. John has also done some brushless setups and he has the motors to do so. I have done custom brushless setups, as well, but I don't sell the motors. John carries MIA upgrades as well so if you want to order all in one shot, John can also set you up with MIA upgrades. We can also help you via my site. Thanks. |
Take a look at my earlier post, the one with the pictures of the canopies on the digital scale. The MIA Edge canopies (any color that is on my site) are lighter than the stock 4#3B canopies. Even the MIA PHantom Canopies are lighter than the Stock 4#3B one, so whcih ever you chose should keep your 4#3B lighter. If you go brushless and direct drive I recommend the MIA frames. |
Thanks, John
Hey Mario,
I just received one of your latest MIA frames for the 4#3, but it must be one of your old stock. It doesn't fit my 4#3b stuff on it. can you send me the 'new' one? I already have a couple of the old ones for the original 4#3. Also how do you fit the TUFF landing gear? It gets in the way of mounting the battery on the heli. |
The TUFF LG mounts in various ways. I will take a picture and post it later on so that you can chose the mounting method that works with your particular setup. If you are simply attaching the TUFF Struts from under the frame, use a piece of foam sheet to make up the different of space so that the battery clears the stuts. |
a very stable 4#3 v1
i used a piece of antenna rod for a tail boom, and a stiff metal wire for the flybar and wow what a stable heli!
the biggest difference i noticed was with the stiffer metal tail boom. not only do i not have to keep replacing tail booms, i now have a much more stable heli!!! has anyone broken the frame of the heli from an antenna rod tail boom? it seems too stong for the plastic...but is it ever sweet! jdog |
Thanks again, John |
| Thread Tools | |
| Mini-HowTo WALKERA 4#3 Mods. | Vario3 | Micro Helis | 77 | Oct 31, 2008 12:20 PM |
| Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! | sketchaholic | Micro Helis | 6422 | Mar 07, 2008 06:27 PM |
| Sold Walkera 4#3 flys awesome! | trab1925 | Aircraft - Electric - Helis (FS/W) | 7 | Feb 26, 2008 11:08 PM |
| Discussion Walkera 4#3 mods | red-panda | Micro Helis | 10 | Oct 11, 2007 01:45 PM |
| Discussion Walkera 4#3 | axelen | Micro Helis | 11 | Aug 19, 2007 07:19 AM |
