Old May 28, 2008, 07:15 PM
MarioIArguello is offline
Find More Posts by MarioIArguello
MarioIArguello's Avatar
Joined Jun 2006
Gain Control on the 52#
Originally Posted by sideburn
Yeah, I'm not worried about the cyclic as much as I am the rudder. There is no gain control on the rx and the knobs on the TX don't seem to be doing anything at all.
The DIP switch #12 is set to off though. Should this be set to ON?
Because this helicopter is collective pitch and , you can balance the helicopter tail control by adjusting the pitch and throttle curves.
Note: You don't want too much pitch on the main blades, you want head speed, the right amount which is found by trial and error will smooth out any tendencies of the tail being slugish.
MarioIArguello is offline Find More Posts by MarioIArguello
Old May 28, 2008, 07:27 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
There is really no reason to leave the stock motor in. You will be changing them after just a few flights and it could freeze up and burn out the main esc in the 4in1. I would have to say that in the right hands it could go inverted with the stock setup but only when it is setup as close to perfect in the stock form as can be. And only within the first minute of flight because it loses power after that. I personally would not try it. Once you go brushless you will wonder why you even put another stock motor in it. You also want to upgrade that tail motor because it wont hold the tail very good with climbouts once you go brushless. And i found the tail holds better if you use the gov mode on the brushless esc. It will have a constant headspeed then.
buster7467 is offline Find More Posts by buster7467
Old May 28, 2008, 07:44 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
yeah, 2nd flight and I have noticed it loses power pretty quickly.
so with switch 12 on, i set the knobs to zero and the rudder seems to hold ok.
still not quite sure when the V1 vs v2 are doing or where I should set them.
I'll just have to keep messing with it.
sideburn is offline Find More Posts by sideburn
Old May 28, 2008, 07:46 PM
morgantown, wv
Joined Mar 2004
Well then you need to read the thread on the 52. It explains all the settings and what works best. Start with that and then fine tweek the settings for how you like it.
Old May 28, 2008, 08:03 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
I will look for the regular 52 thread. All I found so far was a brushless conversion thread.
I'm curious how it is storing the gyro/curve settings. Is it storing it in the tx and when you replace the batteries you have to go through it all over again?
Old May 28, 2008, 08:07 PM
morgantown, wv
Joined Mar 2004
You might want to send walkera an email on that. I am not sure.
Old May 28, 2008, 08:58 PM
milwiron is offline
Find More Posts by milwiron
Flying RC Heli's since 1977
Joined Dec 2003
Originally Posted by MarioIArguello
Cooking nylon or any plastic in your kitchen is not be safe!, plastics give off unsafe and unhealthy fumes when heated to high tempeatures.
Save yourself the trouble and get these MIA TUFF struts and skids kits already made in various sizes to fit your helicopter for only $4.99, let me know what size helicopter you have.
I enjoy making my own parts and I have the education and background to do it. I wouldn't mention anything that was unsafe.
I would suggest you brush up on your polymeric chemistry... and read the RC Groups' rules about advertising in threads.
milwiron is offline Find More Posts by milwiron
Old May 28, 2008, 09:25 PM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
Yes! This was my first choice! because this is how I also made some of my very early Palm Size helicopters like the MIA Mosca pictured below. But given that the 4#3 is pretty light, to begin with, making the LG from the same material as the frame adds a bit of aesthetical continuity.
If you want the miniature MIA TUFF(TM) Struts for the 4#3, I will have these also on my site next week along with the separate LG G10 and Carbon parts that some of you, also enquired about.
fantastic Mario!
am eagerly awaiting
I am very interested in your wood blades I have been watch for,too- especially if you design some v2 ones!
mk
microkites is offline Find More Posts by microkites
Old May 28, 2008, 11:13 PM
fretman is online now
Find More Posts by fretman
fretman's Avatar
United States, CA, Lake Forest
Joined Dec 2007
Originally Posted by microkites
fantastic Mario!
am eagerly awaiting
mk
I second that... can't wait to try some light, stiff, longer woodies.
I tried some cf'ed blades that are about 10mm longer and loved the way the 4#3 flew.. only thing was that flight time was cut down to about 4 min from 10 min. And the losi was super hot afterwards.
fretman is online now Find More Posts by fretman
Old May 29, 2008, 07:09 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
I always flew mine with DIP switch 10 turned on and I was always playing with the dials to adjust max pitch and rpm at which I got it.
Jason
jasonjetski is offline Find More Posts by jasonjetski
Old May 29, 2008, 12:24 PM
nexgen is offline
Find More Posts by nexgen
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
Mario, can a guy order a set of the 4#3 TUFF skids without them being listed on your site? Or should I just wait till they are on there.
nexgen is offline Find More Posts by nexgen
Old May 29, 2008, 01:53 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
Jason
Mine seems to fly well with the PIT lock (DIP 10) v2 set to 0 and V1 set to -40 or so and then i set the Throttle curve (DIP 11) v2 to 100 which gives me maximum headspeed and v1 set to 0 for a linear curve.
so i end up with the throttle stick movements not so sensitive on the blade pitch and a high headspeed.
(stock setup still)
Old May 29, 2008, 02:14 PM
Joined Jun 2006
Check my site in a couple days, I am adding more stuff they will be there.
Old May 29, 2008, 02:54 PM
fretman's Avatar
Joined Dec 2007
Mario, are you still working on the woodies for the 4#3 or are has it been put on the back burner for now?
Old May 29, 2008, 02:55 PM
morgantown, wv
Joined Mar 2004
What is the price going to be for the 52 frame?
Mini-HowTo WALKERA 4#3 Mods. Vario3 Micro Helis 77 Oct 31, 2008 12:20 PM
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 06:27 PM
Sold Walkera 4#3 flys awesome! trab1925 Aircraft - Electric - Helis (FS/W) 7 Feb 26, 2008 11:08 PM
Discussion Walkera 4#3 mods red-panda Micro Helis 10 Oct 11, 2007 01:45 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 07:19 AM
