Old May 21, 2008, 04:36 AM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Originally Posted by johnIn2SonAZ
you will need atleast a 350mah lipo or more at 20C disch. rate.
the medusa sucks some amps. its rated at 44watts but i thing it draws more.
the motor comes with screws. that is a very cheap esc i hope it holds up. cheap stuff usually doesn't.
-johnw.
yeah i was trying to get a CC pheonix 10 cheap.. havent bough the esc yet
i do have a stock one from a belt cp but i think its to big.
any suggestions on a lipo and what about connectors.. can i get a lipo with the right connectors on it already?
sideburn is offline Find More Posts by sideburn
Old May 21, 2008, 04:37 AM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
Medusa Powered W52#
Just finished another BL Conversion on a Walkera 52#.
parts used:
Medusa 4100Kv Afterburner 12MM BL Motor
CC10 Esc
64#C Main Blades, and Skids
8Tooth Pinoin
480mah 10C walkera li-po
speed controller settings:
auto lipo
voltage cut off: normal
brakeff
throttle type:auto calibration
timing advance:high syco-headspeed!
low voltage cut off:soft cut off
soft start: soft start
it feels dialed in now i like the CC esc better than the Feigao for sure.
it just cost so damn much
cheers, johnw
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old May 21, 2008, 04:41 AM
Tucson,AZ
Joined Dec 2007
52# BL conversion
you can find some lipos with the right dimensions but you will have to remove the stock battery tray and use velcro llike i did look at the photos i just posted.i wouldn't run bigger than a 10tooth pinoin heaspeed will be too high and the Medusa will get too hot and you may fry the esc. the battery needs to have a JST battery connector on it. try to keep battery weight below 46grams.
Site Sponsor
Old May 21, 2008, 04:53 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
are you reprogramming the tx as described here
do you have the recommended pinion, batteries with connector, velcro for sale?
Old May 21, 2008, 05:11 AM
Tucson,AZ
Joined Dec 2007
parts coming soon
i will be getting the pinions at the end of the week hopefully. i am still working on where i can get the perfect battery in terms if weigh vs. current output vs. size.in that write up is says to use the main motor port for the BL esc, do not! use the main motor port for the BL esc. this will not work properly. you must solder onto the PC board of the rx and tap the pink and white wires from the opposite side of the board. this is the proper location for powering the BL esc.
Site Sponsor
Old May 21, 2008, 05:23 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
yeah I am having trouble finding a battery myself that includes the jst connector. The thunder powers have a jst but then they dont have the balance charger connectors.. just the 2 wire jst connector.
this one looks close but it is 50grams
do I want to go with 2 cell or 3 cell?
Also that website talks about reprogramming the TX.. i gues that is not necessary.
Old May 21, 2008, 05:43 AM
Tucson,AZ
Joined Dec 2007
Bl Set Up W52#
yeah I am having trouble finding a battery myself that includes the jst connector. The thunder powers have a jst but then they dont have the balance charger connectors.. just the 2 wire jst connector.this one looks close but it is 50gramsdo I want to go with 2 cell or 3 cell?Also that website talks about reprogramming the TX.. i gues that is not necessary.
if you go 2S you will have a problem with the tail motor holding it's designed for 3S operation. so i stayed with 3S to keep things simpler. the TP lipos are heavy 50+ grams i have them for my Gaui but too heavy for this heli. you will have a problem with blades too. the stock blades can't handle the Medusa's speed they crack and self destruct!my tx settings:SWITCH 10:V1=60%,V2=80%SWITCH 11:V1=0%,V2=80%SWITCH 12:V1=-10% V2=80%
Site Sponsor
Old May 21, 2008, 05:50 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
ok how about this battery. larger view
as far as blades go all i know about so far are these carbon ones
Old May 21, 2008, 05:54 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Until my VP tail mod is done I fly my #52 with an Esky HB tail motor on 2S, holds better than the stock motor on 3S, plastic pinion from a 4#3 main motor is a direct fit.
SebastianJ is offline Find More Posts by SebastianJ
Old May 21, 2008, 06:10 AM
Tucson,AZ
Joined Dec 2007
Those blades are a little bit longer than stock you may get tail rotor/main rotor contact on hard landings but i'm not positive on this. the battery looks good try it.
-johnw
Site Sponsor
Old May 21, 2008, 06:28 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
-johnw
thanks, any suggestions on blades?
Old May 21, 2008, 06:35 AM
Tucson,AZ
Joined Dec 2007
Im using the fiberglass blades fro the 64#C but i can't get those anymore all 64#C parts are discontinued. still looking for other options.
-johnw
Site Sponsor
Old May 21, 2008, 06:39 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
-johnw
ah ok,
well i'm getting there.. I ordered the battery and the medusa motor.
so I just need some better blades, an ESC and I guess I will use the pinion gear from one of the spare tail motors I have coming.
Old May 21, 2008, 06:44 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
-johnw
John,
Is this any good to you?
http://www.rctoysaustralia.com/index...emart&Itemid=1
His website says he still has 16 sets in stock.
I live about 45 minutes drive from him depending on traffic.
Iam happy to help you get them if you want them.
Regards Jason
jasonjetski is offline Find More Posts by jasonjetski
Old May 21, 2008, 06:50 PM
Tucson,AZ
Joined Dec 2007
64#C Main blades
Originally Posted by jasonjetski
John,
Regards Jason
thanks jason. i'll send you a pm. the only problem is i will eventually run out. i need to find stiffer stronger blades that are the exact length and size as the origonals.
-johnw
Site Sponsor
Mini-HowTo WALKERA 4#3 Mods. Vario3 Micro Helis 77 Oct 31, 2008 01:20 PM
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 07:27 PM
Sold Walkera 4#3 flys awesome! trab1925 Aircraft - Electric - Helis (FS/W) 7 Feb 27, 2008 12:08 AM
Discussion Walkera 4#3 mods red-panda Micro Helis 10 Oct 11, 2007 02:45 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 08:19 AM
