Old Apr 30, 2008, 09:19 AM
stevel48 is offline
Find More Posts by stevel48
stevel48's Avatar
I cant wait for the wooden blades
stevel48 is offline Find More Posts by stevel48
Old Apr 30, 2008, 03:32 PM
baygenco is offline
Find More Posts by baygenco
master 4#3
istanbul Türkiye
well i believe it is not related to the flybar paddles in my case. in my perfect balanced setup the heli was rock stable even if the paddles were not the same level(i have tried).
thanks for the input.
i am wondering Marios comments on the tbe.
Originally Posted by Martyn McKinney
There is one possible reason that I can think of.
If the paddle blades are not at zero pitch, there will be aerodynamic forces on the paddles while turning because the outer paddle blades are effectively moving faster through the air than the inner blade.
This can put unbalanced forces on the rotor system causing the toilet bowl effect.
This effect is most noticeable on the PicooZ heli in which turning right causes the heli to go forward and turning left causes the heli to slow or hover.
The flybar on the PicooZ is at a different angle to the flybar than the standard 90 degrees which permits this heli to either go forward or hover with only 2 channels.
This effect may also be seen on co-axial helis.
The upper stabilizing rotor system is further away from the center of mass of the heli and there is a force moment when turning because of the difference in distance of the 2 rotor systems on the main shaft.
baygenco is offline Find More Posts by baygenco
Old Apr 30, 2008, 03:39 PM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
paddle set up
I Do Not See This with any of my 4#3's! i am flying with a little positive pitch on the flybar paddles and they make aggressive turns without any tbe. So i don't agree with what you res saying here. i am flying six 4#3's with this set up.
cheers, johnw
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old Apr 30, 2008, 03:43 PM
Tucson,AZ
Joined Dec 2007
tbe
MarioIArguello and others with knowledge of the heli mechanics, its out of topic but had to ask,what is the reason for tbe? i am experiencing ccw tbe with 4#3,if i leave the sticks,the heli draws a big ccw circle and whilst looses altitude. i could not get rid of this.i had the 4#3 hands of hovering for 3-4 seconds before a stupid crash.any input will be much appreciated.
genco.
You may have a damaged main blade. try a new set of main blades.
it may do the trick.
-johnw
Site Sponsor
Old Apr 30, 2008, 04:56 PM
baygenco is offline
master 4#3
istanbul Türkiye
i dont like the feeling of the sticks with positive pitch paddles.its like something holds the heli in the air,less responsive and less precise. i tried the positive pitch on paddles but the tbe continues, also i tried another set of main blades and its the same ccw tbe. im sick of this!
Old Apr 30, 2008, 06:15 PM
Tucson,AZ
Joined Dec 2007
tbe
Did you bend the main shaft? are there any vibrations?
-johnw
Site Sponsor
Old Apr 30, 2008, 07:19 PM
baygenco is offline
master 4#3
istanbul Türkiye
-johnw
there was the vibration and the rotorhead plastic was bend,i had changed the rotorhead, this head seems to be good,also there was a lot of play on the swashplate,i changed it too. these are all after a terrible transmitter mistake crash on ground which i damaged the swashplate ball,flybar and rotorhead.it was flying like a dream before the crash and i was able to hover nose in a feet from my nose
anyway, i changed most of the parts, even the frame, but tbe still remains.
Old Apr 30, 2008, 07:43 PM
Tucson,AZ
Joined Dec 2007
tbe
Well do the servos operate smoothly? when you crashed did it fall on it's side and hit the servo horn. you may have a damaged servo. or you may have damaged the reciever and done something to the gyro circuit inside?
-johnw
Site Sponsor
Old Apr 30, 2008, 10:30 PM
Deen is offline
Find More Posts by Deen
Arizona Desert
Me too!. A head stiffener and some woodies will tighten this thing up nicely.
Deen is offline Find More Posts by Deen
Old Apr 30, 2008, 11:21 PM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
woody for woodies!
well I am flying around my 4#3 v2(bl)
was showing off.....
fff along a small wall......
an inch or 2 away from the ground.....
tapped the wall......
actually chopped a blade in half!
I have crashed every variation of 4#3 1000's of time-only nicked a blade-even bl!
so these are either weaker blades than v1-or the gearing and bl are too much for them!-on a hit I mean
sigh -I guess I have to go back to being cautious flying! pout,,snivel snivel
some v2 woodies please!
I think walkera is going to phase out v1-just a hunch-but watch!
mk
microkites is offline Find More Posts by microkites
Old Apr 30, 2008, 11:49 PM
DJ NeX is offline
Find More Posts by DJ NeX
Tempe, AZ
DJ NeX's Avatar
Just got my 4#3 in from JohnIn2SonAZ! Wow the 2.4ghz flies awesome!
DJ NeX is offline Find More Posts by DJ NeX
Old May 01, 2008, 12:19 AM
Tucson,AZ
Joined Dec 2007
The Perfect Li-Po UpGrade For the MIA Frames
I just tested the new 1s 500mah li-po in my carbon MIA frame. Flight time seemed like forever! This is the perfect battery for these frames. It weighs 11g before the connector is soldered on. Same as Stock. It's thinner,narrower, but longer than the stock li-po. You can hardly see it up in the battery tray. I just ordered 38 of them for my website. They will be up soon! And they do fit in the stock battery cage!
cheers, johnw
www.rchobbyhelicopter.com
Site Sponsor
Old May 01, 2008, 12:20 AM
Tucson,AZ
Joined Dec 2007
Thanks!
Thanks again H!
happy flying!
cheers, johnw
Site Sponsor
Old May 01, 2008, 12:35 AM
MarioIArguello is offline
Find More Posts by MarioIArguello
MarioIArguello's Avatar
Joined Jun 2006
I just tested the new 1s 500mah li-po in my carbon MIA frame. Flight time seemed like forever! this is the perfect battery for these frames. It weighs 11g before the connector is soldered on. Same as Stock. It's thinner,narrower, but longer than the stock li-po. You can hardly see it up in the battery tray. I just ordered 38 of them for my website. They will be up soon!
cheers, johnw
John,
Those batteries look perfect as you show on your pictures. I use similar batteries on my 4#3 with the MIA Woodies, but mine are rated at 450 mah, 500 mah should be better. Nice!
MarioIArguello is offline Find More Posts by MarioIArguello
Old May 01, 2008, 12:38 AM
Tucson,AZ
Joined Dec 2007
wow i just got almost 13 minutes with the heavyer G10 Riged skided MIA FRame!!!
I am really impressed with these lipo's. and the stock charger works fine!
I'll get them on my site asap.
cheers, johnw
Site Sponsor
Mini-HowTo WALKERA 4#3 Mods. Vario3 Micro Helis 77 Oct 31, 2008 12:20 PM
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 06:27 PM
Sold Walkera 4#3 flys awesome! trab1925 Aircraft - Electric - Helis (FS/W) 7 Feb 26, 2008 11:08 PM
Discussion Walkera 4#3 mods red-panda Micro Helis 10 Oct 11, 2007 01:45 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 07:19 AM
