The 45 flybar changes the cyclic control timing of the whole rotor head, since it is coupled to the main rotor, it acts to stabilize the rotor system further. I can explain it better in a video with the actual setup. There are many helicopters out that use the 45 degree flybar to the main rotor to do exactly that, but mainly this has been employed in 2 channel toys and mostly in coaxial helis because they do not require the added complexity of controlling a flybar from the swashplate. But this can also be done on a regular tail rotor heli. |
Tucson,AZ
Joined Dec 2007
Mario,
the Micron tail prop corrects the drift problem i was having. this set up is with the stock motors not losi. the DD and geared MIA's are now flying well with the micron tail prop. maybe you can do a video on your head set up and install? thanks, johnw |
Yes, I will have a video fo the Head assembly next. |
Tucson,AZ
Joined Dec 2007
-johnw |
MIA Walkera 4#3 Videos 1
Ok here is a video I did with the Help of my son.
This video shows the Semi-Automatic Stabilizer system I have employed on my Walkera 4#3, of course along with the other upgrades. I must mention that the aluminum parts for the rotor head do add weight and flight times will be less than with the stock setup. If you simply go with the MIA G10 frame and Stock motors and Equipment with direct drive, you should have very minimal flight differences, as with the sotck Walkera out fo the box, before any mods. The way I have it set up, in particular with the MIA G10 frame and the longer boon, fins, canopy, decals stickers, and direct drive really make flying this little guy a lot more enjoyable. MIA - Walkera Video 1
Typical Flybar Vs Semi or Fully Autostabilized.
Here are the options: Typical Flybar (90 Degres with the Main Blades) Total maeuvers freedom. First time pilots may have a hard time, especially with tiny helicopters. Semi Auto-Stable (Flybar at 45 degrees with the Main Blades) Has almost autostable stability, allows some but not total ease of FFF, Preferrred for somone learning to fly, that still wants a good degree of control, great for indoor confined areas, allows nose in practice, but still requires a bit pf piloting skill. Fully Auto-Stable (Coxial with flybar at 45 degrees with the top blades)Control to bottom blades in direct control. Has close to total autostability. Great for Beginner Pilots wanting a simple system. Nose in? Very easy. One of the features of having a "too much of an autostable system" is that the heli wants to pitch up "balloon" when you want to push it forward fast, same thing happens with coaxial helis and even with some cambered blades on regular fixed pitch micros. I have minimized this on my setup by going with my own woodies flat bottom. But with the system the way I have it it wants to autostabilize itself the minute you let go of the controls. |
I don't like cambered blades, except on tail rotors, because of the effect I mentioned in my previous post. |
| Thread Tools | |
| Mini-HowTo WALKERA 4#3 Mods. | Vario3 | Micro Helis | 77 | Oct 31, 2008 12:20 PM |
| Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! | sketchaholic | Micro Helis | 6422 | Mar 07, 2008 06:27 PM |
| Sold Walkera 4#3 flys awesome! | trab1925 | Aircraft - Electric - Helis (FS/W) | 7 | Feb 26, 2008 11:08 PM |
| Discussion Walkera 4#3 mods | red-panda | Micro Helis | 10 | Oct 11, 2007 01:45 PM |
| Discussion Walkera 4#3 | axelen | Micro Helis | 11 | Aug 19, 2007 07:19 AM |
