Old Jan 09, 2003, 05:41 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Found a good source for micro size wire.
If you look at an IDE or floppy drive cable (any ribbon cable for that matter) you'll find 20 or more lengths of very fine stranded wire of high quality. You can pick these ribbon cables up for pennies at small computer shops, or pay a bit more and find them at CompUSA or the like. Hope this helps, I've been searching and searching for fine stranded wire for Li-poly hook up wire and the like, this stuff works pretty well.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Jan 09, 2003, 06:39 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
another old classic is to use wire from old mice. Quite good stuff
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jan 09, 2003, 06:52 PM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
Jim,
If you find the newer version of IDE cable, EIDE, the wires are even smaller, well at least the ones I've found.
Philip
fill is offline Find More Posts by fill
Old Jan 09, 2003, 10:01 PM
flytowner is offline
Find More Posts by flytowner
flytowner's Avatar
Texas,USA
Joined May 2001
Great idea guys! I'm a computer geek and have tons of that stuff! That wire would probably make a perfect RFFS-100 antenna.
flytowner is offline Find More Posts by flytowner
Old Jan 10, 2003, 07:28 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Philip,
Besides trying to judge the size of the wires, is there a way to identify the EIDE from the IDE cables?
Dave Wulff
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jan 10, 2003, 07:35 AM
fill is offline
Houston Texas
Joined Mar 2001
Dave,
The EIDE will have blue connectors while the IDE will have black. The stuff works pretty good, I've been using it for over 2 years now. Pretty flexible, but doesn't like heat too much so be careful with the iron. I usually will pre-tin the wire first.
Philip
Old Jan 10, 2003, 07:41 AM
Dave Wulff's Avatar
Joined Feb 2002
Philip,
Thanks, every time I buy a replacement hard drive it comes with a new cable that I never use...probably have a bunch around somewhere.
Dave
Old Jan 10, 2003, 09:14 AM
MrC is offline
MrC
Find More Posts by MrC
MrC
Columbus, Ohio
Joined Nov 2001
How much current with these wires carry?
I'm thinking that this might be a good source to replace wires in the servos to lighten them.
--MrC
MrC is offline Find More Posts by MrC
Old Jan 10, 2003, 10:57 AM
Jgardner is offline
Find More Posts by Jgardner
Fanfold abuser
Jgardner's Avatar
Rochester Monroe Cty, New York, United States
Joined Aug 2002
Thanks for the tip. I just wired up my RFFS for the first time and thought more flexible wire and stranded wire would be an improvement. The first two strands would be color coded, as well.
Jgardner is offline Find More Posts by Jgardner
Old Jan 10, 2003, 01:14 PM
Joined Aug 2000
Good idea on the mouse wire Graham, there is some good long wires in there, and they can be found DIRT cheap. Fill: I'm still in the stone age and don't have any EIDE cables, are those the new 100 pin cables that I see now? Sounds like an even better source thanks!
-Jim
Old Jan 10, 2003, 01:16 PM
Joined Aug 2000
MRC:
I don't know how much current these wires can carry, but would be pretty confident in rewiring a servo with the wire. The GWS picos come with wire that is very nearly the same gauge. The only thing that you'll need to be careful about is wire color since the majority of the wires will be grey. The simple fix is to get a sharpie or two and color the ends of the wires.
-Jim
Old Jan 10, 2003, 02:25 PM
crvogt is offline
Find More Posts by crvogt
RIP "Long Shadow Flyer"
crvogt's Avatar
Upstate New York-- Rochester, NY USA
Joined Oct 2001
Telephone cords have nice small wire inside, usually colored red, green, black, yellow. These are the wires from the phone to the wall, or the Modem to wall cords (everyone probably has a couple in the drawer by the computer). Small stranded very flexable!
The other suggestions got me thinking and cut open some spare cords laying around......
crvogt is offline Find More Posts by crvogt
Old Jan 10, 2003, 03:11 PM
drliu is offline
Find More Posts by drliu
Living Room Aviator
drliu's Avatar
Joined Jun 2002
One consideration for those interested in saving the most weight possible is that plastic insulated wire is always significantly heavier than the same size conductor insulated with an enamel coating (technically some of these "enamels" are actually plastics but for clarity I'm refering to those wires with typically shiny ultrathin coatings that are removed by sanding, scraping, or in some cases, soldering).
One wire I'm having good recent results with is AWG 36 wire with a single polyester insulation coat. It weighs 2.95 mg/in and has no problem with currents of 200 mA (and quite possibly more) over our micro sized lengths (< 10"). Comparable plastic insulated wire can weigh several times as much.
-David
drliu is offline Find More Posts by drliu
Old Jan 10, 2003, 03:37 PM
fill is offline
Houston Texas
Joined Mar 2001
Jim,
The actual connector is the exact same, but I think on the older IDE not all the pins are used. I'm looking at both cables right now, and my IDE says 28awg while my EIDE is 30awg.
Philip
Old Jan 10, 2003, 05:18 PM
Timmy is offline
Find More Posts by Timmy
Timmy's Avatar
Ogden Ut
Joined May 2002
another source for some (I think) 40awg wire is guitar pickups. There is a TON of it on the bobbins.
Timmy is offline Find More Posts by Timmy
Question good source for nichrome wire pval3 Hot Online Deals 12 Jun 23, 2007 11:37 AM
Question Good source for 22 AWG and up wire? ejaf Scratchbuilt Indoor and Micro Models 18 Mar 28, 2007 11:47 PM
Alert Found (another) good source for Honeybee LiPos for cheap! Jeremy Z Micro Helis 0 Oct 22, 2006 07:04 AM
is this a good source for actuator wire? jonathan8388 Scratchbuilt Indoor and Micro Models 1 Dec 13, 2005 07:32 PM
Good source for Graupner spinners, folders etc.. leftysdeceiver Electric Plane Talk 2 Apr 30, 2001 09:45 PM
