Everett Wa.
Joined Jun 2001
Glad to see the 170. This and the low wingers are light in the thread offerings. I still think the Beechcraft is a little small in wing area for R/C.
The Champ and the 170 have that bulged windshield. Do you plan to do it like the plans (2 piece), pull your own from a plug, or as I have and just ignore the bulge and wrap the windshield as a single sheet. I see that you have cut the slots for the balsa landing gear struts. I would recommend that you find some other method to make the L/G. The balsa gear even with the wire support didn't even work for the light rubber powered ships, Do think about the torsion type gear I show in my builds. http://www.rcgroups.com/forums/showp...3&postcount=20 http://www.rcgroups.com/forums/showp...0&postcount=25 All the best, Konrad |
Everett Wa.
Joined Jun 2001
To help hold the paper to the balsa while cutting I often use a very low tack glue stick, I think it is the purple stuff. This keeps me from making a perfect paper part only to find that the pattern moved and the balsa part is trashed.
Do look at trying your hand at laminating the outlines if you're not using the kit wood. http://www.rcgroups.com/forums/showp...62&postcount=6 All the best, Konrad |
2.5oz! Let's hope your math is wrong.
I surely doubts doing floats is beyond your skill. I don't have any design in mind yet, although I do have some plans saved here somewhere. OK maybe I'll try the laminations as you suggest although I will have to go with my 1/16" wood as it weighs the same as my 1/32"! Here is a picture of the little aluminum tube glued in place for the float option. |
Everett Wa.
Joined Jun 2001
That tube is set where? Is that a broken stringer?
I do like contest wood but not for stringers. At least on my covering jobs they distort badly, real bad. As to using 1/16 wood to laminate with, it might kink. Remember that even with 8 or 10lbs wood the hoops will be lighter as there is about 2/3 less wood in the hoops. True there is more glue.Konrad |
The tube is right behind the cabin, behind former B5.
Yes I squeezed a little too much while trying to use the tube to drill through the keel and broke a stringer And I even sharpened the tube first.I'm really not too worried, as I cut most of the stringers a little bigger than 1/16 and I don't go for max heat and shrink on the covering. I found a carbon fiber tube that closely fits the motor so I won't be using the motor mount on this model. I am also planning on trying pull pull on this one. I wonder what the weight difference would be between the laminations and just cutting the tail feathers out of a solid sheet of light balsa and then cutting out some holes. Any idea? |
Everett Wa.
Joined Jun 2001
I file little teeth on the ends of my tubes. Actually use a dull blade to scribe teeth on the end of the tubes this small. Makes a nice little hole saw.
I save this tool and cut a new tube for the model. I don't like Swiss Cheese! Pull pull another slam dunk. Konrad |
| Thread Tools | |
| Discussion Guillow,s cessna 172 video | Zimm | Scale Electric Planes | 79 | Sep 20, 2009 08:59 PM |
| GUILLOW'S CESSNA 172 SKYHAWK conversion to electric. | reznikvova | Parkflyers | 25 | May 03, 2008 12:56 AM |
| Video Guillow,s cessna 172 video | Zimm | Electric Plane Talk | 15 | Dec 10, 2007 03:08 PM |
| Discussion Guillow's 24 inch wing span Cessna 150 | guapoman2000 | Scale Electric Planes | 7 | Feb 10, 2005 08:07 AM |
| RFFS for Guillow's 24" Cessna 170 | mkirsch1 | Indoor and Micro Models | 6 | Jan 22, 2003 07:26 AM |
