Old Mar 30, 2008, 12:22 PM
octane-link is offline
Find More Posts by octane-link
Joined Aug 2007
Tower Pro Motor to Replace Eflite Power 25
Just as the title says! The Eflite motors are a hit in my wallet, and Tower Pro motors are nice and inexpensive.
Has anyone done this and could tell me what a good replacement motor is with similar specs and similar installation procedure? I put two Tower Pro motors on the Eflite P-38 with only minimal changes to the entire procedure, and I liked that convenience.
octane-link is offline Find More Posts by octane-link
Old Mar 30, 2008, 02:41 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
This is about as close as I can see - a bit lighter, slightly higher Kv, but if one believes the HC specs (ha!) about the same power handing capacity.
http://www.hobbycity.com/hobbycity/s...idProduct=4949
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 30, 2008, 06:14 PM
Joined Aug 2007
I just got that motor for my P-38 since it matches the Park 450 fairly well! Now I am a bit worried!!!
Old Mar 30, 2008, 06:27 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That motor is nothing like the park 450!!! It is almost three times more powerful. I would recommend a Scorpion 3014 or 3020 as a replacement for the Park 25. I wouldn't use a tower pro motor at that size when scorpion is quite inexpensive.
For a good Park 450 replacement, the Tower Pro Bm2409-18D is ok.
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 30, 2008, 06:30 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
???? the Park 450 is about 150W (14A cont.)... we are talking 500W+ here????
The E-flite Power 25 is said to be good for 550W peak (optimistic?) and the HXT 605W peak (v. optimistic?).
Old Mar 31, 2008, 12:24 AM
Joined Aug 2007
Yes, you are right on the watts. Thanks for seeing that, I would have been in major trouble there!
is this the tower pro motor you were referring to?
http://www.hobbycity.com/hobbycity/s...?idProduct=664
Or would something like this work?
http://www.hobbycity.com/hobbycity/s...idProduct=2111
The 2nd one has a higher Kv than I wanted, but I don't know. I think the first one is what you referred to, and that would do the job on the Eflite P-38.
Sorry for getting off-topic here, but I guess I have my motors to replace the Power 25's! Now to get some 40A(?) ESC's for it.
EDIT: What would be the harm in limiting the ATV of the throttle channel in the radio to less than 50%? That should keep the watts down in the low 200's or high 100's depending on the setting. I don't see that as permanent, but its a start, yes?
Sold NIB Eflite Power 25 motor Steve H. Aircraft - Electric - Power Systems (FS/W) 1 Sep 06, 2007 12:41 PM
Sold Eflite Power 25 cherokeetestpilo Aircraft - Electric - Power Systems (FS/W) 3 Dec 05, 2006 06:33 AM
Sold Eflite Power 25 Tram Aircraft - Electric - Power Systems (FS/W) 1 Nov 29, 2006 06:11 AM
Question Which Tower Pro Motor and Prop for GWS ME-109 Sympster Electric Warbirds 16 Oct 06, 2006 10:42 PM
Discussion gws edf max rpms? and edf with tower pro motor? ronmeister Electric Ducted Fan Jet Talk 23 May 16, 2006 06:10 PM
