Old Jun 22, 2001, 08:41 PM
Ryan Nau is offline
Find More Posts by Ryan Nau
Tork it or Dork it
Ryan Nau's Avatar
Elizabethville,PA USA
Joined Jul 2000
New Jeti Brushless motor in Zagi?
How would the Jeti Brushless motors work in the Zagi. the 15-3 or 15-4?
Would it work as good as an astro 020?
Would it take the Zagi verticle and give it a lot more speed?
Ryan Nau is offline Find More Posts by Ryan Nau
Old Jun 22, 2001, 08:45 PM
2fish is offline
Find More Posts by 2fish
louisville ky us
Joined Jan 2001
WWWWWWWWWWWWWWwOOOOOOOOOOOOOWWWWWWWWWWWWW.I bet that thing cooks.I bet it tops out at 75mph.
[This message has been edited by 2fish (edited 06-25-2001).]
2fish is offline Find More Posts by 2fish
Old Jun 22, 2001, 09:19 PM
Randy S is offline
Find More Posts by Randy S
Professional Dork
Randy S's Avatar
Winchester, Kentucky
Joined Jul 2000
I should know before long. I already have a 15-4, and I had my LHS order an FMA Razor Speed 600 airframe for me. I'm wondering if sub c battery packs will be too heavy... I only have 1 pack of 800 AR's.
Randy S is offline Find More Posts by Randy S
Old Jun 22, 2001, 09:34 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
It would probably work, but the size pack that you would need would be very heavy and that would off set a lot of your gains.
http://www.ezonemag.com/disc/Forum12/HTML/002437.html
http://www.ezonemag.com/disc/Forum12/HTML/002160.html
http://www.ezonemag.com/disc/Forum12/HTML/002440.html
http://www.ezonemag.com/disc/Forum12/HTML/002392.html
dave_lilley is offline Find More Posts by dave_lilley
Old Jun 23, 2001, 12:20 AM
rcastab is offline
Find More Posts by rcastab
rcastab's Avatar
SF Bay Area, California, USA
Joined May 2001
I have put in an Aveox 1005/4Y on my zagi with a graupner 6x3 folding prop and with the Zagi 1700mah pack, and it just screams.
About the battery pack, maybe you can just use the Zagi 1700mah pack with the Jeti motor.
http://www.geocities.com/rcastab/Zagi.html
rcastab is offline Find More Posts by rcastab
Old Jun 23, 2001, 09:32 AM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
Would the Jeti 15-4 brushless fit in the Zagi motor tray?
I have a Firecat ordered with a Jeti Brushless 15-4 motor. It will be my first brushless.
Do you need a special brushless speed control for it or can you use anyone. Like a Castle Creations 35 amp speed control?
Old Jun 23, 2001, 11:14 AM
AndrewK is offline
Find More Posts by AndrewK
Ready for a Vacation!
AndrewK's Avatar
Atlanta, GA
Joined Dec 2000
You have to have a brushless controller. Just get the Jeti one and it wont kill your bank.
Andrew
AndrewK is offline Find More Posts by AndrewK
Old Jun 23, 2001, 01:06 PM
Randy S is offline
Professional Dork
Randy S's Avatar
Joined Jul 2000
Ryan,
The 15-4 won't fit in the Zagi tray, that's one of the reasons I am getting the Speed 600 Razor airframe.
Old Jun 23, 2001, 07:52 PM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
What about if you cut it out for it a little. Thats what I had to do for the Turbo 450.
Are the 15-3 and 15-4 the same size?
Old Jun 24, 2001, 11:08 AM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
Will the Razor 600 motor tray fit on the Zagi? I need a new motor tray anyways. The 15/4 fits in it, right? New creations sells the motor trays for it.
Does the Razor 600 motor tray like the Zagi X. Do you put your battey at the same spot?
Old Jun 24, 2001, 01:42 PM
Randy S is offline
Professional Dork
Randy S's Avatar
Joined Jul 2000
Ryan,
You may be able to cut the tray a little and get the 15-4 to fit. A Razor tray and a Zagi tray are different. In the Razor the battery goes through a hatch in the tray, down into the foam fuselage. You may however be able to rig something using the Razor tray. I think it would fit on the Zagi.
Old Jun 24, 2001, 02:00 PM
Randy S is offline
Professional Dork
Randy S's Avatar
Joined Jul 2000
I took my speed 400 Razor and started weighing the different components that will be going into the Jeti powered Razor... and... I REALLY like what I saw!!!! It looks like the AUW is going to be 27-28 ounces. According to some info I saw on the Jeti 15-4, it has 33 ounces of thrust! This could be fun!!! Anybody know how this compares to a Turbo Zagi? (Geez... I'm starting to feel like Tim on Home Improvement.)
Old Jun 24, 2001, 06:34 PM
Ryan Nau is offline
Tork it or Dork it
Ryan Nau's Avatar
Joined Jul 2000
I'm ordering to new Creations tomorrow. I need a motor tray for my Zagi and also ordering the HL Firecat combo which comes with the Jeti 15/4 brushless. When i'm putting my firecat together, i'm going to try the 15/4 in it.
I have a 450 turbo in my Zagi know. How much oz of thrust do you get with the 450 turbo on 8x800ar?
Is the motor the same size as the 450 turbo?
Old Jun 24, 2001, 08:41 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
The 15/3 and 15/4 are physically the same size, yes. Just one has one more turn on the widings than the other.
BEC is offline Find More Posts by BEC
Old Jun 30, 2001, 06:20 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Randy, Any updates on the Jeti powered Razor? I am curious about the results as I was thinking of getting one for my Zagi.
John
JohnM is offline Find More Posts by JohnM
Jeti Brushless motor in Java 150 sailplane ptglass Electric Sailplanes 4 Oct 19, 2002 04:15 AM
astro flight brushless 050 in a zagi? Excon Foamies (Kits) 1 Jan 11, 2002 10:26 AM
Jeti Brushless Motor/Controller ScotY Aircraft - Electric - Airplanes (FS/W) 2 Dec 11, 2001 02:14 PM
New Jeti Brushless motors for ECO8? Tooly Electric Heli Talk 16 Jun 21, 2001 09:51 PM
Plettenberg Moskito Brushless motor in Adrenalin! Erik Johansson High Performance 9 May 18, 2001 04:54 PM
