The seam of the inner and tip panel is reinforced with some glass fibre. http://www.f3k.nl/index.php?id=127&page=3 Quote:
Any glue that can be sanded when dry can be used. some people use Titebond II wood glue, or UHU hart. (balsa cement) http://www.f3k.nl/index.php?id=59 Quote:
Frans |
Joined Oct 2012
I first put on the upper side and 10 minutes later on the bottom, maybe that was the problem. I probably should have used grain filler that the varnish doesn`t get drew to much into the wood.
I tried to fix it with the hot air gun, it worked nod bad at all, I think I`ll get it straight after a few more tries... Another question: How thin should the trailing edge be? I sanded mine not as thin as the airfoil jig is, mine is about 1mm ![]() ![]() Greets |
| Thread Tools | |
| 1 meter mini IFO? | Fantam | Parkflyers | 24 | Nov 07, 2002 08:53 PM |
| Mini Pencam 1.3 in the UK? | Mike_Y | Parkflyers | 12 | Sep 20, 2002 12:20 PM |
| Mini Pencam 1.3 | gooster | Parkflyers | 1 | Sep 16, 2002 08:02 PM |
| WTB- Aiptek Mini PenCam 1.3 for aerial photography | gooster | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 13, 2002 10:38 PM |
| 1 meter electric sail plane | Havens54 | Electric Sailplanes | 1 | May 19, 2002 03:37 AM |
