Old Jul 08, 2010, 04:46 PM
Jimmy Yucca's Avatar
Arleta, California
Joined Aug 2009
Your probably right. But it was still a good educated guess.
Jimmy Yucca is offline Find More Posts by Jimmy Yucca
Old Jul 09, 2010, 03:41 AM
Crazy, not stupid
Zwolle, The Netherlands
Joined May 2007
Yes, it was. And it is indeed not needed on the small MiMi. I've used several rudders, some just "rounded off" on all sides, some asymmetrical, some sanded into a real airfoil. None of that mattered in terms of launching or flying. Usually a few clicks down + right trim (I'm a right hand thrower) on your launch is enough to get a straight launch.
So, I hope you have a computer Tx in which this can be programmed
Otherwise, don't pay too much attention to weight, especially when it's a bit windy the MiMi needs it. Finished around 200 grams is still fine, lighter is of course ok, then attach some strips of lead to the underside of the wing (there's space for it), pieces of about 10 gram each will do.
I'm using Dyamond D47's normally but MiMi will fly perfectly with Pico's or even HTX500's from unitedhobbies. hardly matters.
What might be a good idea when you haven't finished your wing yet is give it ailerons. That will help in launch (ailerons 2-4% up will give you a few more meters of hight) and enable faster, smaller turns when needed. And of course it's a lot of fun (You could leave out the rudder that way too, less weight to the tail!) Rudderless ships fly just as good but also launch higher.
What is the actual idea of your competition? Who can throw the highest, fly the longest..?
sadkingbilly is offline Find More Posts by sadkingbilly
Old Jul 09, 2010, 07:49 AM
DrIli's Avatar
Colombia, Valle del Cauca, Cali
Joined Mar 2010
Hello I just send a PM to Frans with my mail for the plans.
Thanks Frans in advance.
I will keep you posted with the proyect.
I guess I will be the first to built the Mimi in Colombia.
DrIli is offline Find More Posts by DrIli
Old Jul 11, 2010, 06:56 AM
DrIli's Avatar
Joined Mar 2010
Thanks for the plans!
Received them today.
Old Jul 16, 2010, 08:04 AM
Frans Bal's Avatar
Vlaardingen, The Netherlands
Joined Feb 2004
DrIli,
Well not exactly, you are number 5.
Frans
Frans Bal is offline Find More Posts by Frans Bal
Old Jul 16, 2010, 08:45 AM
The Sky is Our Playground
bugsnatcher21's Avatar
Joined Nov 2006
Hello MIMI world, I just send a PM to Frans with my e-mail for the plans.
I am going to thank Frans in advance too. I am looking forward to this one. The MIMI will be my first DLG that I have built. I have been flying power gliders for a while now. Saw the MIMI DLG and was hooked.
You have to love those THERMALs
bugsnatcher21 is offline Find More Posts by bugsnatcher21
Old Jul 16, 2010, 12:15 PM
Joined Nov 2006
Just received the plans. I will keep you posted on the build.
Thanks you Frans
Old Jul 19, 2010, 12:04 PM
DrIli's Avatar
Joined Mar 2010
What servos will work with a 3.7V 1S Lipo setup?
Most of them start at 4.8V.
Old Jul 19, 2010, 01:10 PM
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Some people are using these little devices to safely run things on single cell lipos. I have no experiance with them myself but I have seen plenty of positive reports. This is just an example.
TURNIGY Voltage Booster for Servo & Receiver
Rob...
mxspode is offline Find More Posts by mxspode
Old Jul 19, 2010, 04:13 PM
Frans Bal's Avatar
Joined Feb 2004
I have several in use and they work fine.
Frans
Old Jul 19, 2010, 06:36 PM
Joined Nov 2003
Will they also work with 4 servos?
RAy
kostuk is offline Find More Posts by kostuk
Old Jul 19, 2010, 06:59 PM
NorCal
Joined Oct 2003
I have first hand experiance with these working fine at 3.7V:
Airtronics 94091
Airtronics 94802
D4.7
JR DS188
Futaba 3154
Hyperion digi
That represents 100% success on the handful of servo types I've tried.
I'm also curious how that voltage booster would work on a 4 servo all digi DLG. Does it have a current limit that might put the plane at risk. Right now, not knowing, I feel safest with a direct hookup to my single cell lipo.
Bob McGowan is offline Find More Posts by Bob McGowan
Old Jul 19, 2010, 07:49 PM
DrIli's Avatar
Joined Mar 2010
Thanks I will give the D47 a try.
Old Jul 20, 2010, 04:54 PM
Steve
USA, PA, Marysville
Joined Nov 2009
I finally got to try the Mimi I built for my son. He and I got together today, I had a 60 inch dlg I just got assembled and he had his Mimi.Ive flown it before ,but limited myself so I wouldnt break it. Today there was no limit. It was alot more comfortable to fly than the 60 inch dlg.It didnt go as high but the flight time sure seemed just as long and very controlable.Hand catches with no problem. My next 1 I was goin to try and streamline the fuse but now I can see Frans did his homework on this design. Aint changing a thing.
saddlesore is offline Find More Posts by saddlesore
Old Jul 21, 2010, 02:18 PM
Joined Nov 2003
Hi Bob,
Thanks for the info. Was that with a 2.4 or 72 RX? I heard that the 2.4G RXs like higher voltages. Also what mAH battery do you use?
Ray
1 meter mini IFO? Fantam Parkflyers 24 Nov 07, 2002 08:53 PM
Mini Pencam 1.3 in the UK? Mike_Y Parkflyers 12 Sep 20, 2002 12:20 PM
Mini Pencam 1.3 gooster Parkflyers 1 Sep 16, 2002 08:02 PM
WTB- Aiptek Mini PenCam 1.3 for aerial photography gooster Aircraft - Electric - Airplanes (FS/W) 2 Sep 13, 2002 10:38 PM
1 meter electric sail plane Havens54 Electric Sailplanes 1 May 19, 2002 03:37 AM
