Old Mar 27, 2008, 09:50 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
2.4GHz worth an upgrade?
Just wanted to see/hear a few opinions...
General consenses on 2.4GHz?
I've hear a LOT of good things about 2.4g but also a lot of negatives... If I am looking to upgrade from a simple 4ch starter radio should I stick with 72mhz until 2.4g has had a while to prove itself and work out most of the buggs that still are/may be out there?
Thx
AC5FF is offline Find More Posts by AC5FF
Old Mar 27, 2008, 10:23 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
What are the negatives you are concerned with? I don't follow all the 2.4 threads, but it is my observation that the positives vastly outnumber the negatives.
In my opinion, there are many advantages over 72 Mhz (and 50 mHz as well).
Bill
ebill3 is offline Find More Posts by ebill3
Old Mar 27, 2008, 10:39 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
This article might provide you with more understanding of the strengths/weaknesses of 2.4GHz when compared to 72MHz.
XJet is offline Find More Posts by XJet
Old Mar 27, 2008, 10:49 PM
AC5FF is offline
AC5FF's Avatar
Joined Sep 2007
while i am fairly new at RC; maybe my concerns are just rantings of others...
I see myself taking this hobby in one or two directions. AP and/or Gliders.
AP concerns; I've read a lot about 'blocked' signals--basically dealing w/line of sight. If a battery pack/esc/motor can cause a 'blacked out' or 'reduced signal strength' area than what will putting a much larger object (i.e. camera) going to do to the signal?
Glider concerns; I've also read about the absorbing qualities of carbon and 2.4g signals. Since a lot of the gliders i am considering would contain a fair amount of carbon (if not full carbon fuse)... Its just another concern I guess
XJet; I'm bookmarkign this page to read at work tomorrow since it's already running late for me.. Thx for the link though... I'll definatly give it a good read through tomorrow!
Old Mar 28, 2008, 04:47 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
I have been using it for over a year - absolutely great, you won't look back.
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 28, 2008, 05:25 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
That depends on if you are having problems with 72 MHz.
With my Trex helicopter I started with PCM and had some lockouts.
Get a Spektrum system and that was crap. More crashes due to brownouts and I did not like the transmitter programming.
Traded the Spektrum in for a Futaba 7C-2.4 FASST radio and everything is now working perfectly. I also like the transmitter programming much better.
So for me it was a painful process but in the end I have a radio that I am happy with.
RC Man is offline Find More Posts by RC Man
Old Mar 28, 2008, 09:38 AM
hfenn is offline
Find More Posts by hfenn
Barnwell, SC
Barnwell, SC
Joined Sep 2004
I've owned a Spektrum DX6 for almost two years and have been so pleased that I've gotten rid of all 72MHz (except the one in a RTF mini chopper) and just recently got the DX6i. I have 4 airplanes and 3 helicopters flying on Spektrum.
hfenn is offline Find More Posts by hfenn
Old Mar 28, 2008, 07:17 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Most of the downsides with 2.4 actually can be a problem in 72 MHz. Low voltage effects any electronic device. How many "glitches" with 72 were due to low voltage?
Poor antenna placement can effect 2.4 or 72.
OTOH, 2.4 you don't have to worry about the kid down the street with his one box RTF turning on his radio and crashing your aircraft. That alone was enough for me to switch. No waiting to fly because somebody else is on the same frequency.
I like not having to deal with long antennas on small aircraft. The short Tx antenna is also nice.
Pinecone is offline Find More Posts by Pinecone
Old Mar 28, 2008, 07:19 PM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
Sorry, but IMO, you have to FIX the brownout (low voltage) issues before your heli is safe. No matter what system you use.
Spektrum Rxes are spec'd to work down to 3.5 volts. My testing shows that they work down to about 3 volts. If your power system is dropping to 3 - 3.5 volts, you have serious problems with bad servos, binding linkages, or something else wrong with your heli.
Old Mar 28, 2008, 09:34 PM
FrankW is offline
Find More Posts by FrankW
Danger! Danger!
FrankW's Avatar
Portland Intl, Oregon, United States
Joined Dec 2002
My opinion. Buy 2.4Ghz now. There's not point in buying old technology unless you already have a large supply on hand and not enough money to convert. I currently have over a dozen aircraft (planes and helis) flying on 2.4 and I wouldn't go back. The cost to convert was a big expense, but well worth it. If you have 72 Mhz equipment and want to convert, do it now while you can still sell your old stuff, because in a couple years 72Mhz won't be worth anything in the used market.
It's nice not having to worry about getting shot down or having to wait for your frequency to open up at the field.
I'm finding lately that 2.4Ghz is getting blamed for a lot of things that are pilot error and low battery voltage.
BTW: Spektrum is having a reciever giveaway when you buy a new system and on or two extra recievers: http://www.spektrumrc.com/giveaway/
-Frank
FrankW is offline Find More Posts by FrankW
Old Mar 28, 2008, 10:25 PM
AC5FF is offline
AC5FF's Avatar
Joined Sep 2007
This is the main reason I'm looking at 2.4GHz. Another local flyer at the park here has a couple of RTF radios. While I'm on a JR (Positive shift I believe) he felt that his radio on the same channel (Negative shift) was sufficient enough seperation.
I started loosing control immediatly; luckly i was on approach to land and all I did was noze over; however the jitter or ??? caused one of my servos to strip the gears... At least that's my bet as to what happened. The servo (heck the whole radio is less than a yr old!) But I bought cheap, unsure of my commitment to the hobby... Now that i realize how much I enjoy it I think i'd be better suited to a more powerful radio
Old Mar 28, 2008, 10:51 PM
FrankW is offline
Danger! Danger!
FrankW's Avatar
Joined Dec 2002
Depending on the radio, even one or two channel seperation isn't enough. The other flyer should've known better and not have turned on his radio while you were flying (provided he was aware of what channel you were on). Field etiquette dictates that he should pay for any damage to your plane.
That's another good point on 2.4... you don't have to risk shooting down someone elses $2000 giant scale aerobat and have to pay for it.
-Frank
Old Mar 28, 2008, 10:56 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Bill
Yes... no and maybe...
If 72 mhz is doing what you want...
And you are not seeing any interference issues...
you can keep using the 72 mhz.
Don't buy just to "keep up with the Jonses"...
If you are in the market for a new system ANYWAY... there are good arguments to make that new system 2.4 ghz.
If you find you have interference issues, or the field is crowded and you have a hard time getting your frequency pin... 2.4 is a decent answer.
RE channel separation... Narrow band allows 4 consecutive "channels" to fly at once... We've done it with no issues.
You can't complain about someone turning on a different frequency and interference resulting... unless it has happened before and you found that the other person's radio is defective. (I have had a defective radio BLANKET 30 frequencies! and interfere on all others, confirmed by frequency analyzer... My radio...)
+ vs - shift...some MORON decided it was funny to tell people that you could get away with both (on the same frequency) at once...it even passes a 10 ft range check 90% of the time. It NEVER passes a 100 ft range check...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Mar 29, 2008, 01:22 AM
GD5015 is offline
Find More Posts by GD5015
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
Exactly why I switched. It only happened one time, but when I drive to the field I want to fly. Not watch.
John
GD5015 is offline Find More Posts by GD5015
Old Mar 29, 2008, 02:09 AM
ebill3 is offline
ebill3's Avatar
Of course not;why make such an inappropriate comment.
Buy the latest proven technology and don't look back.
Bill
Discussion Multiplex Evo - worth the upgrade to 2.4 ssphoenix Radios 10 Feb 06, 2008 09:53 AM
Discussion Is 2.4gHz worth it? sdueck Radios 21 Nov 09, 2007 04:22 PM
Discussion 2.4ghz upgrade path DX7 vs. Module Ping Radios 3 Oct 14, 2007 11:54 PM
Discussion Anybody need to upgrade to 2.4ghz? brovic777 Mini Helis 2 Sep 20, 2007 09:44 PM
Discussion Will an eflite 2.4GHz transmitter work as a buddy box? Unterhausen Radios 2 May 09, 2007 03:20 PM
