Go Back   RC Groups > Aircraft - Electric - Airplanes > Scale Electric Planes
Old Mar 27, 2008, 11:13 AM   #1
Vernon Hunt's Avatar
Wiley Post Bi-plane/Hurst Bowers
After getting well along with the DR1 build, I have decided to build a front yard flyer (my front yard). For this project I wanted something simple and it had to be a bi-plane. My dad saved every plan ever printed and every article from the magazines since 1960. Well, after he died I got all his stuff. Alot of the plans have since been sold or lost. I did however save the things that interested me. One of these plans was the Hurst Bowers 1975 Wiley Post Bi-plane. He never sent for the plan, but the magazine clipping is in the binder I saved. I have enlarged the model from 1" scale to 1 1/2" scale. That gives a wingspan of 45".
I started by cutting the 2 wing rib templates from plywood. Then cut the 24 lower wing ribs from 1/16" balsa. The wing has been beefed up with a covered leading edge of 1/32" sheet, and trailing edge. This means the ribs will be cap striped. Spars are 1/8" sq. balsa. Lotsa small parts, but very fun to build.
I'm not sure what power to use, but it will be an AXI on Li-polys. The idea will be to fly comfortably in the yard, and have some reserve to clear the trees and fences. So let the build begin!
  • Name: wiley post article 1.jpg
  • Name: Wiley Post Article 2.jpg
  • Name: Bottom wing 3.jpg
  • Name: Bottom wing 1.jpg
  • Name: Bottom wing 5.jpg
  • Name: Bottom wing 2.jpg
  • Name: Bottom wing 6.jpg
  • Name: Bottom wing 4.jpg
  • Name: Bottom wing 7.jpg
Vernon Hunt is offline Find More Posts by Vernon Hunt   Reply With Quote
Old Mar 27, 2008, 12:29 PM   #2
scrubs's Avatar
45" ?? Obviously your front yard is more generous than mine.
bill
scrubs is offline Find More Posts by scrubs   Reply With Quote
Old Mar 27, 2008, 12:55 PM   #3
Bill,
I'm a former Milwaukee resident, and winter builder. At least 7 months for building and 2 months for flying.
I have about 2 acres for flying in the front yard. But with the trees and fence it can get dicey. I have flown 3D electric, discus launch gliders, and electric flying wings in the yard. This model should be perfect.
Vern
Old Mar 27, 2008, 01:14 PM   #4
playing trains.. back soon
My front yard is about 15 foot square...now if I give it a lot of rudder movement and make VERY tight turns...
Nice building Vern - I like the 'D' box style of wing construction (used a lot by one of my fave designers, David Boddington) as it gives a very strong wing. Look forward to the rest of your build.
Steve
Redbaron25 is offline Find More Posts by Redbaron25   Reply With Quote
Old Mar 27, 2008, 01:46 PM   #5
miniphase's Avatar
Vern
good to see you churning out another model Vern, any of
those electric wings your own design? My swift wing is ready for covering.....
Paul
miniphase is online now Find More Posts by miniphase   Reply With Quote
Old Mar 27, 2008, 01:53 PM   #6
Paul,
Yes, they were all my own design. Small flying wings are great for sitting in the yard and thermal soaring.
I have never stopped building in 50 years, just getting more practical. I have to stay home to get client calls, so flying at home is the way to go. My wife also likes the fact that these smaller models are cheaper.
Vern
P.S. Get that Swift covered and flying. Can't wait to see it fly!
Old Mar 28, 2008, 02:29 PM   #7
DPlumpe's Avatar
A great start, Vern! Hurst's Wiley Post has held my attention since that 1975 issue (I still have the article) and I'll be very interested in your approach to scaling it up, especially since the original was essentially a rubber-powered freeflight with few mods for a Cox .020 and pulse rudder.
Hurst Bowers left us quite a legacy. I'm in only my third build of his designs (Buhl Sport Airsedan, Kinner Sportster, and Farman Moustique so far), though I have parts cut out for 4 more and plans for 73 of the 74 I know of.
Keep it coming!
-Dave
  • Name: Wiley Post A Bipe, 28.5in Hurst Bowers 7507MA plan.gif
Description: Hurst's original plan Hurst's original plan 97.5 KB · Views: 174
DPlumpe is online now Find More Posts by DPlumpe   Reply With Quote
Old Mar 28, 2008, 07:07 PM   #8
Dave,
My dad used to tell me about the designers like Hurst and others. I built alot of the rubber jobs when I was a kid in the 50's and 60's. So now to have many old plans to choose from I'm like a kid in a candy store. This project brings back memories and is so much fun I'm already planning my next project. I'm beefing up some of the structure, but still trying to keep it light. This should turn out to be a very nice model.
Vern
Old Mar 29, 2008, 08:31 PM   #9
Top wing time. The pictures tell the story on how this wing is built. A little more detail than the bottom wing. The ailerons make it a bit more challenging. But the final result worked out very well. So far both wings weigh 3ozs. Not bad for the extra wood on the leading edges. The wing tips are easy and light.
  • Name: Top wing 1.jpg
Description: cutting ribs using a ply template cutting ribs using a ply template 40.2 KB · Views: 55
  • Name: Top wing 2.jpg
Description: simple and easy... no notches at this time simple and easy... no notches at this time 38.5 KB · Views: 44
  • Name: Top wing 3.jpg
  • Name: Top wing 6.jpg
Description: ready to start building ready to start building 39.7 KB · Views: 46
  • Name: Top wing 4.jpg
Description: leading edge, trailing edge, and cap strips first... then spars leading edge, trailing edge, and cap strips first... then spars 37.8 KB · Views: 44
  • Name: Top wing 5.jpg
Description: now I notch the ribs to fit the spars now I notch the ribs to fit the spars 35.0 KB · Views: 31
  • Name: Top wing 7.jpg
Description: then add the top spars then add the top spars 43.6 KB · Views: 36
  • Name: Top wing 8.jpg
Description: ready for leading edge top skin ready for leading edge top skin 34.2 KB · Views: 34
  • Name: Top wing 9.jpg
  • Name: Top wing 10.jpg
Description: blocking in the aileron blocking in the aileron 39.8 KB · Views: 41
  • Name: Top wing 11.jpg
  • Name: Top wing 13.jpg
Description: wing tip glued ready for sanding wing tip glued ready for sanding 35.2 KB · Views: 31
  • Name: Top wing 12.jpg
  • Name: Top wing 14.jpg
Description: both panels almost ready to cut the ailerons both panels almost ready to cut the ailerons 37.4 KB · Views: 39
Old Mar 29, 2008, 09:42 PM   #10
And you are?
eliworm's Avatar
Nice to see this model going together. It's one I have thought about for a long time. Looking good.
Jim
eliworm is offline Find More Posts by eliworm   Reply With Quote
Old Mar 30, 2008, 10:23 AM   #11
Pat Daily's Avatar
Vern
Great to see another Hurst Bowers design--I remember the original Wiley Post that Hurst built with rubber power many years ago. I think somewhere along the line it got converted to electric ff. I will ask Don Srull--he may even have it somewhere in his basement. Hurst's ff designs are great for small electric rc at about 30-40 inches.
Pat
Pat Daily is offline Find More Posts by Pat Daily   Reply With Quote
Old Mar 30, 2008, 01:02 PM   #12
Dave, Jim,and Pat,
Thanks for the comments and appreciation for Hurst Bowers modeling. I'm modeling the things now that I put off for years. I just hope I do this Wiley Post Bi-plane justice, and some semblance of Hurst's great modeling skills. Thats what makes it so much fun.
Vern
Old Mar 30, 2008, 06:51 PM   #13
Here are the results of cutting out the ailerons. Very tidy and light. I should have waited and put these up with the last set of shots.
  • Name: Wing aileron 1.jpg
  • Name: Wing aileron 2.jpg
  • Name: Wing aileron 3.jpg
Old Apr 02, 2008, 03:14 PM   #14
Worked on the fuselage over the past couple of days. Pretty basic stuff, but a joy to build this way. Trying to do a very perfect build is the challenge. It doesn't take long to get alot accomplished. I use squares to align the sides so they are vertical when joining them. I also draw the top view directly on the board to layout the fuse. This way I know it's straight. Also started blocking in the cowl and cocpit area.
  • Name: Fuse 1.jpg
  • Name: Fuse 2.jpg
  • Name: Fuse 3.jpg
  • Name: Fuse 4.jpg
  • Name: Fuse 5.jpg
  • Name: Fuse 6.jpg
  • Name: Fuse 7.jpg
  • Name: Fuse 8.jpg
Old Apr 03, 2008, 05:29 PM   #15
DPlumpe's Avatar
Looks great, Vern, but you cheated You covered the top of the nose with a balsa block, instead of struggling in a vain attempt to curve planking around that very tight compound curve. Or did you struggle with planking first, then use a block?
You gonna install all your RC gear thru the cockpit opening, using dental mirrors and double-jointed tweezers, or will you have a hatch somewhere? Also, I don't think Hurst's Ace Baby R/C bang-bang magnetic actuator will be strong enough for your scaled-up model.
-Dave
Ace Simple Series Ultimate Bi-plane: anyone try one? Any powerplant suggestions? Falcore Electric Plane Talk 6 Jun 04, 2002 12:54 AM
Suggested motor for IC BI-Plane Twmaster Sport Planes 1 Jan 21, 2002 09:09 AM
Sports Bi-plane wad Sport Planes 9 Jan 18, 2002 10:05 PM
Bi-Plane CG????? Indian Valley Electric Plane Talk 1 Jan 15, 2002 11:07 PM
Bi-plane airfoil? AW Power Systems 5 Oct 01, 2001 06:43 PM
Congratulations SimpleM!
