Old Mar 27, 2008, 01:40 AM
bretd123 is offline
Find More Posts by bretd123
Joined Oct 2007
Will THIS motor work with THIS plane?
I really don't know that much about matching planes with electric motors. i matched the second number on the recomended motor to the second number on the hobbycity motor.? I also want to know what ESC too.
http://www.10374.com/3dbatix/plans/extra330.pdf
http://www.hobbycity.com/hobbycity/s...idProduct=2049
bretd123 is offline Find More Posts by bretd123
Old Mar 27, 2008, 02:24 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
I think that motor is too light and fast for that plane. They reccomend a motor that weighs about 56 grams and needs a 12 amp speed controller.
You want a lower kv rating. Something like this http://www.hobbycity.com/hobbycity/s...idProduct=6549
or this
http://www.hobbycity.com/hobbycity/s...idProduct=2112
Someone else might like to qualify this or give other reccomendations.
aerophilia is offline Find More Posts by aerophilia
Old Mar 27, 2008, 09:26 AM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
that plane's about the same size and weight as the NASTY.
Look in the plans section and see what they're using. I think you need a little bigger motor and esc.
DRITCH is offline Find More Posts by DRITCH
Old Mar 27, 2008, 11:53 AM
DontTellTheWife is offline
Find More Posts by DontTellTheWife
Joined Mar 2007
I've just completed a 50% reduced size build of this plane. Tomorrow I'll be driving to Orlando to pick out my motor, ESC and batteries.
Total weight (AUW) will be 8.3 oz.
I've selected the BP A2208-14 for my brushles motor.
http://www.bphobbies.com/view.asp?id...7&pid=B1898550
BP 18A Brushless ESC
http://www.bphobbies.com/view.asp?id...2&pid=B1198427
Either a 7.4V or 11.1V Thunder Power 1320mAh battery. Depends on if the 7.4V will power my ESC with three servos connected.
8x4 prop. should give me between 110 and 120 watts with the 11.1V battery, 75 watts with the 7.4V and a 9x5 prop.
The description of the motor says it's good for 3D planes around 8oz and aerobatics up to 12oz.
I've included a few pics.
Any comments are welcome. This is my first venture into Foamies.
DontTellTheWife is offline Find More Posts by DontTellTheWife
Old Mar 28, 2008, 12:42 AM
bretd123 is offline
Joined Oct 2007
Do you think a KF airfoil will work with this plane?
Discussion Will This Motor Work With This? ViRtUaLvIrUs Electric Power Cars 11 Sep 09, 2007 11:30 AM
Question What plane will work with this? DSK Foamies (Kits) 4 Jan 22, 2006 08:03 PM
Question Will this motor work with shockyflyers bamm 3D Flying 36 Apr 12, 2005 05:46 PM
Will this ECS work with this motor? blk96gt Power Systems 3 Feb 23, 2005 08:47 PM
Question Will this motor work with this plane??? raythomas Parkflyers 10 Jan 02, 2002 09:06 PM
