Go Back   RC Groups > Aircraft - Exotic and Special Interest > Waterplanes
Old Apr 01, 2008, 02:49 AM   #16
No substitute for span
L over D's Avatar
Keep up the good work rotorheid, that will be really nice shagbat!
I made a Walrus-design last spring that was a little more basic but very focused on flying/swimming. Cyril Carrīs design seems to be a little bit smaller but with much more scale details. I was also surprised to read that Carr had not flown it from the water and actually doupted that i would work. I hope you dont mind me posting some pics of a Walrus in itīs true element!
The important thing is the "steps" under the fuselage and the floats. If they are to shallow the plane will not let go of the water. But with the steps set right a Walrus is a dream to land a take off from any pond, lake or river.
Happy swimming!
Johan
  • Name: walrus.sn6.flyby.jpg
  • Name: walrus.sn1.takeoff.jpg
  • Name: walrus.sn1.taxi.jpg
  • Name: walrus.sn1.landing.jpg
L over D is offline Find More Posts by L over D   Reply With Quote
Old Apr 01, 2008, 08:53 AM   #17
This is my other autogyro!
rotorheid's Avatar
Cool "Shagbat" pics.
Hi Mr Lift/Drag,
Absolutley delighted that you put your pictures here, a pleasure sir.
Can you please supply more information on your Walrus? Specs and such like, thankyou.
I started installing the motor and radio bits last night, I made a fundamental error with my nacelle, too short, so spent a while resolving that problem. The motor I have is an XTRA 2815/24 good for 80+ watts. Weight with all componants but no paint or detailing is 310grams, it will be heavier than Mr Carr's original, I think my calculations will allow a MAUW of 400grams for a wing load of 5.5 oz/foot squared, still, not a lead lifebelt, I hope. I fitted a 7x?? prop I had spare as it gave me a max continious power of 70Watt, I use a mixer on throttle for an switchable, rated, combat power selection (85Watt)for emergencies. Cheers mates,
regards to all, Al
  • Name: P1010489.jpg
Description: Almost scale prop size, less two blades. Almost scale prop size, less two blades. 25.2 KB · Views: 156
  • Name: P1010490.jpg
Description: Very close @ blade tips/TE cut out. I will run it flat out so she cuts her own way before painting. Very close @ blade tips/TE cut out. I will run it flat out so she cuts her own way before painting. 18.9 KB · Views: 153
Last edited by rotorheid; Apr 01, 2008 at 10:41 AM. Reason: Added Engine pictures.
rotorheid is offline Find More Posts by rotorheid   Reply With Quote
Old Apr 01, 2008, 05:16 PM   #18
rotorheid's Avatar
Wing Float contsruction sans "Pink" Foam.
Hi Guys,
Tackled the wing tip floats after running the motor to test prop clearance on wing trailing edges, no mini snow storm, phew!
Pictures say it all, on with the next part, fitting out. Afterwards a final WBPU coat for water line and below, best to let dry overnight before continuing with rigging and paint scheme.
Cheers mates,
regards to all, Al.
  • Name: P1010491.jpg
Description: Before and after, 1/16th balsa profile, polystyrene sheet both sides and sand away. Before and after, 1/16th balsa profile, polystyrene sheet both sides and sand away. 24.1 KB · Views: 120
  • Name: P1010494.jpg
Description: Top tip #254 of 1000. Place heat shrink tube over Bamboo before cutting with side cutters, no messy splinters to take care of. Top tip #254 of 1000. Place heat shrink tube over Bamboo before cutting with side cutters, no messy splinters to take care of. 21.3 KB · Views: 107
  • Name: P1010495.jpg
Description: Wing floats tacked on with foam safe C/A, then gobs of fast epoxy to hold and fair the joint in with wet finger, quickly! Wing floats tacked on with foam safe C/A, then gobs of fast epoxy to hold and fair the joint in with wet finger, quickly! 22.7 KB · Views: 107
  • Name: P1010496.jpg
Description: Two shake and bake wing floats ready for WBPU before paint. Two shake and bake wing floats ready for WBPU before paint. 20.1 KB · Views: 104
Old Apr 02, 2008, 03:11 AM   #19
Jeff Seemiller
LONGBIKE's Avatar
Rotorhead,
This is really a great looking plane. I have got to build one on these where did the plan come from? Im not sure what rcm&e is.
LONGBIKE is offline Find More Posts by LONGBIKE   Reply With Quote
Old Apr 02, 2008, 03:41 AM   #20
meatbomber's Avatar
Longnbike
RCM&E Magazine from the uk, you can order back issues here : http://www.modelflying.co.uk/editori...scribe&sp=&v=8
I got me the one with the Walrus too it`s the february 2008 Issue (No.109), got mine in just 3 days shipped.
Rotorheid:
Your building speed borders to manical !
she`s looking really good, what i don`t quite get is with the landing gear not in a fixed retracted position but in the moveable configuartion that is in the plans, the wing gets it`s stiffness against folding up only from the little ply mounts for the folding wing mechanism ?
Cheers
MB
meatbomber is offline Find More Posts by meatbomber   Reply With Quote
Old Apr 02, 2008, 09:00 AM   #21
rotorheid's Avatar
CMBD (Compulsive Model Building Disorder) Victim speaks.
Hi MB,
Yes, I'm afraid I was diagnosed with CMBD some years ago, but I learn to live with it, I get such a rush when I lay the plan out for the first time, or open a new tube of glue, sort of a build junkie. hahaha.
The stifness in the wings on Carr's plan is from the completion of the basic box shape, he has a strong anchor point for both wings, two top and two bottom. There is a "Jury" strut at the leading edge of both wings to keep the form rigid when folding the wings back. The interplane struts hold the wings rigid at the tip end. So when the lock pins are fitted through the ply wood on the wing roots, the whole assembly becomes a rectangluar box when viewed from the front. The rigging wires, landing and flying wires become functional to add to the rigidity. It shows this on the plan but is not obvious, and it works. Same principle as most aircraft with a connection to the upper and lower spars to the mounts on the fuselage.
My Walrus will be the prototype version without the jury struts as I do not have the fold system. Hope this makes sense for you. Cheers mates,
regards to all, Al
  • Name: plane.jpg
Description: Early version, Non folding wings, No jury strut. This is the version I am building (easy paint scheme) Early version, Non folding wings, No jury strut. This is the version I am building (easy paint scheme) 28.8 KB · Views: 115
  • Name: JSJ_Vickers_Armstrong_Walrus.jpg
Description: Later version with folding wings and jury strut on leading edge at root rib. Later version with folding wings and jury strut on leading edge at root rib. 42.9 KB · Views: 93
Old Apr 02, 2008, 09:18 AM   #22
L over D's Avatar
[quote=rotorheid]Hi Mr Lift/Drag,
I will try (it was some time ago and I sold/gave away all the 6 pcs that was built). Wingspan was 100cm, the upper wing was only 3mm Depron and the lower was 5mm. My prototype had an ATOW around 280gram I think, small outrunner from Dualsky (forgot the type, around 25-35g) with an 12A esc and 2s 1000mAh LiPo-pack. Wingstruts was also 5mm depron (would have looked soo much better with wood or carbon... ).
The thing with my design was the CG, if set at 1/3 of upper wing it was very sensitive to thrust changes and generally unstable during descent. Since the designs are fairly similar I would recommend to set the CG at least at 1/4 of the upper wing (don't know what Carr recommneds for his plane), it also helps the handling in the water if it's slightly nose heavy.
With the CG right it flew very nice indeed, perfect for a calm summer evening (even though it took "strong" winds and "rough seas" rather well)!
Must agree with meatbomber, you are building like it's going out of style! Keep up the good work, it's very inspiring to follow your thread!
Sea trials and test flying on during this weekend?
Johan
Old Apr 02, 2008, 12:43 PM   #23
Jeff Seemiller
LONGBIKE's Avatar
Thanks MB,
But I guess I'm just stupid because when I go to there site and click on back issues it will just give me the one choice that I dont want and I cant change the issue number.
Old Apr 02, 2008, 03:05 PM   #24
meatbomber's Avatar
just send them a mail they`ll send you the issue worked for me
Old Apr 02, 2008, 05:55 PM   #25
rotorheid's Avatar
Keeping the water out and cabin build.
Hi guys,
Made the access panel with a wide sealing surface, will use Vaseline, Petrolatum or thickish grease to prevent/reduce water ingress. I have no sealing chemicals like corrosion X or experience of them. Got the cabin/canopy built onto the deck, needs finishing off but getting close to the Fun bit. The weather is pants just now so will take time tomorrow to complete and possible "pool trials" and adjusting on Friday. C/G should be achieved with battery position, no ballast.
Cheers mates,
regards to all, Al
  • Name: P1010498.jpg
Description: Access panel sanded slightly undersize to the access hole. Food wrap as seperation medium, tape handle to pull it out, edge smeared with epoxy to seal the gap. Could have used Silicon sealant. Access panel sanded slightly undersize to the access hole. Food wrap as seperation medium, tape handle to pull it out, edge smeared with epoxy to seal the gap. Could have used Silicon sealant. 26.3 KB · Views: 113
  • Name: P1010500.jpg
Description: Trimming off the rough epoxy "plug" while it is "green," soft but solid, not yet set hard. Trimming off the rough epoxy "plug" while it is "green," soft but solid, not yet set hard. 22.7 KB · Views: 107
  • Name: P1010502.jpg
Description: Access panel replaced on new food wrap. Deck piece ready for bonding only to panel with UHU Por. Access panel replaced on new food wrap. Deck piece ready for bonding only to panel with UHU Por. 25.8 KB · Views: 112
  • Name: P1010504.jpg
  • Name: P1010505.jpg
Description: Cabin glazing added, deck taped down. Cabin glazing added, deck taped down. 20.9 KB · Views: 96
  • Name: P1010506.jpg
Description: Glazing done, needs shaping and frames added when dry, tomorrow. Glazing done, needs shaping and frames added when dry, tomorrow. 23.2 KB · Views: 110
Old Apr 02, 2008, 06:42 PM   #26
e-powered foam
rawy's Avatar
Nice Job Rotorheid, really impressed by the building pace, was expecting some more info on that engine dummy, nobody else asked so I do
Except in cases of major crashes I never had problems with water on/in electronics, I try to avoid contact with water by placing receiver and esc's protected by .......yes foam
The advantage of our favourite building material is that it needs power to bring it under water
rawy
rawy is offline Find More Posts by rawy   Reply With Quote
Old Apr 03, 2008, 01:55 AM   #27
rotorheid's Avatar
Bristol Pegasus Dummy Engine.
rawy
Hi Rawy, Guys,
Glad you asked for some info, when I took close up pics I saw that one of my prop retainer screws was missing, found it under the work bench ! Was due for a tidy up so it could have gone in the skip, thanks.
Full size Pegasus Radial Engine. circa
Type: 9 cylinder spark ignition air-cooled poppet valve radial engine
Cylinders: 9 cylinders in one row
Valve arrangement: 4 valves per cylinder
Bore and Stroke: 5.75 x 7.5 in
Swept volume: 1,753 cu in (28.7 litre)
Compression ratio: 5:1
Max revolution: 2,600 - one minute
HP range: 600 - 1010
I worked briefly on it's big brother, the Hercules, a two row, 14 cylinder,
37 litre monster when I was a young apprentice in the RAF (a long time ago!)
Model size Balsa Pegasus.
I made a cock up in the distance measurement for my prop position, as mentioned in post #17, I laminated some light balsa sheet, sanded to a circle and glued 9 pieces of balsa rod around the side. I wound some thick wool on the rod and stuck a small balsa stick for the push rod covers. I smeared some PVA glue with the fingers over the wool to bulk it out, sanded and painted when dry.
Hope this helps, off to the work table again, cheers mates.
regards to all, Al
  • Name: Pegasys18.jpg
Description: Bristol Aeroplane Company "Pegasus" radial engine, circa 1930. Bristol Aeroplane Company "Pegasus" radial engine, circa 1930. 23.9 KB · Views: 87
  • Name: P1010508.jpg
Description: Motor wires run down inside of rear strut to 12 amp ESC behind cabin. Motor wires run down inside of rear strut to 12 amp ESC behind cabin. 24.8 KB · Views: 109
  • Name: P1010507.jpg
Description: Balsa, wool and glue made a good spacer to put prop in correct position. Balsa, wool and glue made a good spacer to put prop in correct position. 23.0 KB · Views: 90
  • Name: P1010509.jpg
Description: Close up view, Hey! where's my wee prop screw?? Close up view, Hey! where's my wee prop screw?? 25.4 KB · Views: 112
Old Apr 03, 2008, 05:41 PM   #28
rotorheid's Avatar
Fly by wire and a new coat.
Hi Guys,
Took forever to put in 4 pieces of kite string for the control hook up, next time I do one of those setups I will get them in before I close up the fuselage, what a faff! No matter, servos fitted and working, rudder and water rudder made, looks tiny hope she is stearable. Flying and landing wires done, with thinner kite string. "What's that Bob?, your kite seems too near, and turns to the right all the time...eh... can't think why mate."
Base coat of aluminium applied, bloody can ran out too soon, so it's thin in places. Pictures tell a thousand words so here are some more. Cheers mates.
regards to all, Al
  • Name: P1010516.jpg
Description: Not a lot of prop clearance. Not a lot of prop clearance. 62.2 KB · Views: 80
  • Name: P1010517.jpg
Description: 9 gram servo, this one for rudder. Elevator servo is in tandem but fitted 5mm higher for string clearance. 9 gram servo, this one for rudder. Elevator servo is in tandem but fitted 5mm higher for string clearance. 80.8 KB · Views: 115
  • Name: P1010518.jpg
Description: Start of flying wires going on. Start of flying wires going on. 71.3 KB · Views: 94
  • Name: P1010520.jpg
Description: Lower surface sprayed first. Lower surface sprayed first. 63.9 KB · Views: 131
  • Name: P1010523.jpg
Description: Remainder sprayed, I used my auto shake method for the spray can. Stick the can inside two heavy socks and chuck in the tumble dryer on medium heat for 10 mins, works great! Remainder sprayed, I used my auto shake method for the spray can. Stick the can inside two heavy socks and chuck in the tumble dryer on medium heat for 10 mins, works great! 22.0 KB · Views: 100
  • Name: P1010524.jpg
Description: I'll make the decals while the paint gets harder, could be a window for the pool tomorrow?? I'll make the decals while the paint gets harder, could be a window for the pool tomorrow?? 20.9 KB · Views: 125
Old Apr 03, 2008, 05:50 PM   #29
meatbomber's Avatar
sooooo nice !!! what paint are you using ? most spray paints i find are eating the depron and the "styro safe" stuff i have not seen a silver yet...
Old Apr 03, 2008, 06:43 PM   #30
rotorheid's Avatar
RC Styro Paint, Hobby Colors.
Hi MB,
Thanks mate, I just have to get my magnifying glass to read the info on the can.
Looks like it's Dutch/Nederlande/Holland as the first language on the can is Dutch.
Bar code and stock no. 5 412966 159336 Pearl Silver.
5 412966 168109 STC Silver 810
I got it from local craft shop, some of the cans were u/s with the heat and old stock, hope they still make it. BTW if you put two coats of WBPU on the depron, and spray car acrylic gently from a bigger distance than normal it doesn't eat the foam too much, I did disolve a foamy jet once in the early learning process Doh!
regards Al
OK found the place, Belgium, check this link out.
http://www.ghiant.com/our-brands/art.../hobby-colours
  • Name: P1010525.jpg
Description: Two different styles, made by same company. Two different styles, made by same company. 26.5 KB · Views: 92
  • Name: P1010526.jpg
Description: GHIANT AEROSOLS NV
INDUSTRIEWEG 7 - 2340 BEERSE
Tel:  014/61.54.60
Fax:  014/61.75.25 GHIANT AEROSOLS NV INDUSTRIEWEG 7 - 2340 BEERSE Tel: 014/61.54.60 Fax: 014/61.75.25 28.5 KB · Views: 88
Last edited by rotorheid; Apr 03, 2008 at 06:57 PM. Reason: Added link to good depron paint.
Building Larry Park's Midge Diesel 10 Indoor and Micro Models 13 May 04, 2003 11:44 AM
Cyril Carr Vulcan - Plans BOD THE BUILDER Electric Ducted Fan Jet Talk 1 Jan 18, 2003 01:53 PM
Cyril Carr's Vulcan information wanted AirJer Electric Ducted Fan Jet Talk 5 Aug 06, 2002 07:41 PM
Building Recievers/ESC's flyingace15 Indoor and Micro Models 8 Jul 12, 2002 02:53 AM
building a DAW S-1-26 HLG t6e23 Electric Sailplanes 5 Mar 06, 2002 01:41 PM
Bored? Want to fight?
Join the RCGroups clan!
