Go Back   RC Groups > Aircraft - Exotic and Special Interest > Waterplanes
Old Mar 26, 2008, 05:30 PM   #1
This is my other autogyro!
rotorheid's Avatar
Thread formally known as Cyril Carr's "Supermarine Walrus," Part II, a bigger one!
Hi Guys,
As mentioned in the Depron Puddle Twin thread I was going to have a go at the Free Pro-Plan from the February 2008 edition of RCM&E.
I have got underway with the wings building. Due to lack of real crisp depron I am using a softer more flexible type obtained localy in the craft shop, like foam board without the paper. It is 3mm and 5mm only but comes in white and vomit green. I decided on a double skin wing with a depron spar as a deviation from Cyril's design. This one is definately for swimming pool operations. Some Magazine and build pics for your enjoyment. Cheers mates,
regards to all, Al
  • Name: P1010440.jpg
Description: Centrefold of Feb 2008 RCM&E, what a belter! Well done and thankyou Mr Carr. Centrefold of Feb 2008 RCM&E, what a belter! Well done and thankyou Mr Carr. 28.6 KB · Views: 264
  • Name: P1010443.jpg
Description: Build text and pics from RCM&E magazine article. Build text and pics from RCM&E magazine article. 28.8 KB · Views: 137
  • Name: P1010444.jpg
Description: Build text and pics from RCM&E magazine article. Build text and pics from RCM&E magazine article. 28.6 KB · Views: 130
  • Name: P1010437.jpg
Description: Upper and lower wings cut. Upper and lower wings cut. 19.0 KB · Views: 132
  • Name: P1010438.jpg
Description: Lower skins 5mm, with 5mm deep straight spar, not full span, to squeeze 3mm top skin onto tip outline. Lower skins 5mm, with 5mm deep straight spar, not full span, to squeeze 3mm top skin onto tip outline. 20.9 KB · Views: 188
  • Name: P1010439.jpg
Description: Leading edge and front of spar glued before trailing edge. Leading edge and front of spar glued before trailing edge. 20.0 KB · Views: 145
  • Name: P1010445.jpg
Description: Top skin stuck down, a double curved profile, may add balsa leading edge for roundness and feather trailing edge. Top skin stuck down, a double curved profile, may add balsa leading edge for roundness and feather trailing edge. 16.7 KB · Views: 180
  • Name: plane.jpg
Description: An early version without the stowable wing fold. An early version without the stowable wing fold. 28.8 KB · Views: 135
  • Name: SMWFB.jpg
Description: An outstanding painting of the Walrus over a brooding sea. An outstanding painting of the Walrus over a brooding sea. 62.9 KB · Views: 199
  • Name: P1010446.jpg
Description: All wing panels complete, shaping when dry. All wing panels complete, shaping when dry. 21.0 KB · Views: 143
rotorheid is offline Find More Posts by rotorheid   Reply With Quote
Old Mar 27, 2008, 05:47 AM   #2
rotorheid's Avatar
Fuselage start and progress of the Shagbat!
Hi Guys,
Up early on day off to start the fuselage. Built upside down as it's easier. I quite like the green stuff now, you can see where your angles are off. Just need to buy some ice lollies, sticks for the struts...mmmmmm.
Cheers mates,
regards to all, Al
  • Name: P1010447.jpg
Description: Top deck and two sides. All 3mm depron. Top deck and two sides. All 3mm depron. 20.4 KB · Views: 123
  • Name: P1010448.jpg
Description: Top deck and two sides position check. Top deck and two sides position check. 23.7 KB · Views: 128
  • Name: P1010449.jpg
  • Name: P1010450.jpg
Description: 5 min wrestle with UHU Por and it's done. 5 min wrestle with UHU Por and it's done. 17.8 KB · Views: 144
  • Name: P1010451.jpg
Description: General view of hull. General view of hull. 16.6 KB · Views: 125
  • Name: P1010452.jpg
Description: Inverted on drawing with lower wings. Inverted on drawing with lower wings. 20.9 KB · Views: 132
Old Mar 27, 2008, 05:55 AM   #3
meatbomber's Avatar
Great i just received my copy of the mag with the plan... i HAD to get that oneafter you mentioned it because it`s the nicest Walrus plan i have seen to date.... i'll follow this build very closely and i'll probably make this my on-tour building project as it has anice size to stow away in my travel shop
meatbomber is offline Find More Posts by meatbomber   Reply With Quote
Old Mar 27, 2008, 05:59 AM   #4
rotorheid's Avatar
Good one mate, post some pictures of your build please, what colours will you do? Look out for the MISTAKE on the drawing regarding "up" thrust. It shows down thrust! I will not make it this way. But go the original aircraft drawing route. (Ye canna change the laws o' physics laddie!)
regds. Al
Last edited by rotorheid; Mar 27, 2008 at 06:29 AM. Reason: Warning, drawing wrong.
Old Mar 27, 2008, 10:18 AM   #5
rotorheid's Avatar
V hull and keel.
Hi Guys,
Floored the cabin, stuck on my clear laminating plastic foil, now adding the keel and V hull planking. Gives a good bilge compartment. Will go with all fly by wire (string) for the tail surfaces. Cheers mates.
regards to all, Al
  • Name: P1010453.jpg
Description: Cabin floor glued in, keel plate added, clear plastic foil over side joint/spray rail fitted and trimed. Cabin floor glued in, keel plate added, clear plastic foil over side joint/spray rail fitted and trimed. 18.7 KB · Views: 154
  • Name: P1010454.jpg
Description: Keel on and started the V hull planking, edge sanded out/feathered to zero. Keel on and started the V hull planking, edge sanded out/feathered to zero. 16.1 KB · Views: 129
  • Name: P1010459.jpg
Description: Forward V hull to do later. Forward V hull to do later. 23.8 KB · Views: 146
Old Mar 27, 2008, 10:34 AM   #6
meatbomber's Avatar
Are oyu an airplane al ? the way you write the coments under the photos seems very familiar
The idea of seeling the bottom is good (actually really good!), you`ll still have to get the bottom water tight as you don`t want water sloshing around in the bilge either... just think of it.. only 15g of water running from forward to aft is going to produce a massive shift in CG (well now how do i know that )
Are you gonna do the tissue and WBPU un the bottom for sealing the hull ?
Old Mar 27, 2008, 02:48 PM   #7
rotorheid's Avatar
Originally Posted by meatbomber
Are oyu an airplane al ? the way you write the coments under the photos seems very familiar .................
Hi Meatbomber
Not sure what you mean? (language barrier only) I have been involved with full size and model avaition since 45 years, last 34 years flying and maintenance fulltime, so yes, I guess it has rubbed off on me.
Yes I will do tissue and WBPU on the hull for sealing, you've seen my landings, I need all the help I can get! Cheers mate,
regards to all, Al
Old Mar 27, 2008, 04:55 PM   #8
rotorheid's Avatar
V hull progress
Hi Guys,
Depron fore pieces for V hull laminated and bent into shape, had to cut three times. Doh! Some filler and a quick rub down then a coat of WBPU ready for tissue later. Back to wings and tail surfaces now.
rgds, Al
  • Name: P1010460.jpg
Description: Front of V hull complete, primer coat of household WBPU. Tissue on tomorrow. Front of V hull complete, primer coat of household WBPU. Tissue on tomorrow. 22.6 KB · Views: 140
  • Name: P1010461.jpg
Description: Nose shape not quite right, but it will do for me. (modified for swimming pools?) Nose shape not quite right, but it will do for me. (modified for swimming pools?) 17.9 KB · Views: 123
  • Name: P1010462.jpg
Description: Front view with spray rail/chines? shown. Front view with spray rail/chines? shown. 17.2 KB · Views: 120
  • Name: wal38.jpg
Description: Copy of orginal rigging diagram, thankyou whoever I got it from. Copy of orginal rigging diagram, thankyou whoever I got it from. 99.2 KB · Views: 323
Old Mar 27, 2008, 04:58 PM   #9
meatbomber's Avatar
DOH i wanted to type if you are an airplane engineer, as the captations on your photos are the style usually seen on maintenance workorders (am an engineer/Pilot too.. first Lauda Air now Pink Aviation Services)
Old Mar 28, 2008, 05:28 PM   #10
rotorheid's Avatar
Jiggery Pokkery!
Hi Guys,
A bit more progress tonight, wasn't really in the mood as a disasterous days flying for my friend, Wolfgang. He reduced his Airworld ASK21 with gas turbine to Zero, from 800 mtrs in about 3 secs, what a real shame.. on the 3rd flight. You could put the biggest piece in your pocket. Lost pitch control completely, radio worked OK after the impact, weird.
Steam Pidgeon
Wing fettling with makeshift jigs for alignment, lower wings on and braced. I cut 3mm depron tyres and glued them in the retracted position, used bamboo for the gear legs, stiffened up the wing a treat, dihedral looks a bit much but it's no biggy to sort out with some tweaking.
regards to all, Al
  • Name: P1010466.jpg
Description: Left wing (master) on first. Left wing (master) on first. 16.2 KB · Views: 118
  • Name: P1010467.jpg
Description: Incidence adjusted with pins, then glued with 5min epoxy, just a smeg. Incidence adjusted with pins, then glued with 5min epoxy, just a smeg. 20.1 KB · Views: 115
  • Name: P1010468.jpg
Description: Right wing on to same angles as left. Right wing on to same angles as left. 15.5 KB · Views: 107
  • Name: P1010469.jpg
Description: Fin and rudder tacked on for effect. Fin and rudder tacked on for effect. 18.4 KB · Views: 129
  • Name: P1010470.jpg
Description: View showing u/c legs as wing brace. View showing u/c legs as wing brace. 16.8 KB · Views: 134
Old Mar 29, 2008, 06:00 PM   #11
rotorheid's Avatar
Access hatch, Motor nacelle and final tissue covering.
Hi Guys,
A little more done tonight after work, I did undo the wheel legs and reduced the dihedral on lower wings, it looked very mickey mouse before. Off to bed as on early shift this week, bah! Cheers mates,
regards to all, Al
If you have a spare 10 mins here is a cracking Video of the Walrus in action from youtube, cool staged rescue mission and soundtrack.
Supermarine Walrus in Action (5 min 31 sec)
  • Name: P1010471.jpg
Description: Tissue applied onto tacky WBPU, Rear, step, front then sides. Lower half of rear then full sides at front. Tissue applied onto tacky WBPU, Rear, step, front then sides. Lower half of rear then full sides at front. 21.7 KB · Views: 132
  • Name: P1010474.jpg
Description: Tissue cross grain at front. Tissue cross grain at front. 23.2 KB · Views: 112
  • Name: P1010475.jpg
Description: Front centre line overlaped. Front centre line overlaped. 18.5 KB · Views: 136
  • Name: P1010476.jpg
Description: Motor mount and balsa profile to aid shapeing/profiling, wood to provide strut mount integrity. Motor mount and balsa profile to aid shapeing/profiling, wood to provide strut mount integrity. 21.8 KB · Views: 102
  • Name: P1010477.jpg
Description: Nacelle roughed out by hand. Nacelle roughed out by hand. 16.8 KB · Views: 129
  • Name: P1010478.jpg
Description: Radio access hatch cutout, will make canopy and fore deck as one with insert plug to seal bay, all seams and joints oversealed with WBPU inside. Radio access hatch cutout, will make canopy and fore deck as one with insert plug to seal bay, all seams and joints oversealed with WBPU inside. 16.6 KB · Views: 114
  • Name: P1010481.jpg
Description: Sides trimmed off with sandpaper, all WBPU well rubbed in with finger to seal grain, seams oversealed tomorrow when dry. Sides trimmed off with sandpaper, all WBPU well rubbed in with finger to seal grain, seams oversealed tomorrow when dry. 18.8 KB · Views: 125
Old Mar 30, 2008, 04:07 AM   #12
e-powered foam
rawy's Avatar
Very nice Job Al,
Is that green foam PU ? is the specific weight higher than the depron ? it looks like some PU sheets I got here ? only that my PU is haevyer than depron. much harder too.
still have too much unfinished stuff laying around here but your very clean build inspires to go on with a new project, hhhmmmm will first try to clean the bench here, better for the family politics too
nice to have more inspiring builds here,
rawy
rawy is offline Find More Posts by rawy   Reply With Quote
Old Mar 30, 2008, 08:57 AM   #13
rotorheid's Avatar
Depron/Polyurethane?
Hi Rawy,
Thanks mate, now you've set me thinking, I cut two pieces the same size and weighed them on digital post scales, you're right, the green stuff is heavier, by some 40% never noticed that on the small pieces I am using. Stifness is the same, cantilevered both sheets off the table, same fall angle. Has the same production marks (roller mill or flexible finger supports?) as the white stuff. They make the same sound when tapped and both pick up the same amount of Bass from my loud speakers. Try walking past your hi-fi playing loud Rammstein whilst carrying a sheet, you can feel it!
Looks and cuts like Depron, however as mention before it is imported from China to the local craft shop and is very cheap. £1.40 for a sheet 1000x800x3mm or £1.60 for a sheet 1000x800x5mm, the only PU sheet I've used before was Rohacell/Kegecell for full size glassfibre glider repairs, PU dust from sanding is very grity and harsh, nothing like that, no wee bubbles in this stuff. I like it as a construction medium as it cuts so well, and floats! I better call it Chinese Depron after the Chinese Olympic Aerobatic Champion Pilot: Wan Wing Low.
Cheers mate,
regards to all, Al
Old Mar 30, 2008, 11:51 AM   #14
rotorheid's Avatar
Ice lollyathon!
Hi Guys,
After a hard day of ice lolly munching I had sufficient sticks for the engine nacelle. I made a best guess at the thrust lines and positioning and glued the two front mounts, the nacelle and finaly the rear lolly sticks, sorry, struts into position. I hope any discrepancies with the angles are overcome, well I have a rudder and fingers so it won't be too bad. cheers mates,
regards to all, Al
  • Name: P1010482.jpg
Description: Nacelle front struts on. Nacelle front struts on. 16.1 KB · Views: 117
  • Name: P1010483.jpg
Description: Nacelle tacked on and jigged with foam block. Nacelle tacked on and jigged with foam block. 17.9 KB · Views: 143
  • Name: P1010484.jpg
Description: All four struts on. A little side thrust and some "Up" thrust. All four struts on. A little side thrust and some "Up" thrust. 39.8 KB · Views: 126
Old Mar 30, 2008, 06:10 PM   #15
rotorheid's Avatar
Al gets help with rigging.
Hi guys,
Starting to look like something now, had some chums round to help secure the upper wing, splendid fellows, kept banging their heads on the ceiling with their jumping up and down though.
Seriously, got stuck in after tea and the result is as you see. The tip float position is an extension of the wing struts, they will be trimmed to size later. That's it for tonight, more tomorrow, hopefully. Cheers mates.
regards to all, Al
  • Name: 6230img_tz_silo.jpg
Description: Wing rigging pals, nice blokes. Wing rigging pals, nice blokes. 9.8 KB · Views: 97
  • Name: P1010485.jpg
Description: Not strictly scale, more Fun scale. Not strictly scale, more Fun scale. 19.6 KB · Views: 150
  • Name: P1010486.jpg
Description: 3/4 side view, Mr Messy is back! 3/4 side view, Mr Messy is back! 23.8 KB · Views: 152
  • Name: P1010488.jpg
Description: Can you guess what is yet? Can you guess what is yet? 20.4 KB · Views: 180
  • Name: P1010487.jpg
Description: Leave to dry overnight. Leave to dry overnight. 20.5 KB · Views: 144
Building Larry Park's Midge Diesel 10 Indoor and Micro Models 13 May 04, 2003 11:44 AM
Cyril Carr Vulcan - Plans BOD THE BUILDER Electric Ducted Fan Jet Talk 1 Jan 18, 2003 01:53 PM
Cyril Carr's Vulcan information wanted AirJer Electric Ducted Fan Jet Talk 5 Aug 06, 2002 07:41 PM
Building Recievers/ESC's flyingace15 Indoor and Micro Models 8 Jul 12, 2002 02:53 AM
building a DAW S-1-26 HLG t6e23 Electric Sailplanes 5 Mar 06, 2002 01:41 PM
Bored? Want to fight?
Join the RCGroups clan!
