What you have is a clever radio with a dumb feature. Get yourself a Dubro servo saver
http://www.shopatron.com/product/part_number=120/101.0 Set it up as shown in the drawing with the springs just at the forward end of the servo arm & just one of the collars at the back. You have to move the linkages in or out of the servo or throttle arm to match the servo travel as best you can. Once it's all set up back off the idle stop screw on your engine so the throttle can close completely. With your radio stick right back & the trim down adjust the rear collar so the servo holds the throttle pushrod right back closing the throttle. Tighten it up. Leaving the trim down push the throttle stick all the way forward. Move the front collar back until the springs hold the throttle wide open plus a little spring tension. Tighten the front collar up. Now check that the throttle stick opens the throttle from fully open (& compressing the spring slightly) to fully shut without stalling the servo. With the throttle stick fully back move the trim lever forward, the throttle should now be open a little, probably a fast idle setting. Now push the throttle fully forward. The throttle should open fully & any extra movement will be taken up by the spring. Hope this helps, John. |
I have used your system and it really works well thanks alot. In the mean time I have bought a 9ZAP so hence my other thread on how do i set up the throttle servo. Thanks tim |
| Thread Tools | |
| Discussion I Have A T-rex Hde But I Don't Know How To Set Up My Radio | agapornis | Mini Helis | 1 | Jan 08, 2006 03:51 PM |
| Question How to set up my CC Ph 10 | zman12000 | Micro Helis | 3 | Dec 18, 2004 02:00 AM |
| How to set up my CC Phoenix 25 | Joe Labrutto | Power Systems | 14 | Jul 10, 2004 08:48 PM |
| How do I set up my Endo? | roberts | Power Systems | 17 | Apr 07, 2004 10:41 PM |
| How to set up my first plane? | dshuen | Parkflyers | 9 | Nov 05, 2001 04:05 PM |
