Old Jul 29, 2008, 07:53 PM
skypilot_one is offline
Find More Posts by skypilot_one
United States, CT, Ledyard
Joined Sep 2003
Originally Posted by Julez
Hi!
I just recieved an upgraded firmware from Junsi, and it appears as they finally solved the slow balancing issue.
With the old firmware, I let the charge, which I documented here, run until this morning. The charger still not terminated the charge after 43h
Then I installed the new firmware, connected the same pack again, and the charge was finished in ~30min. Note that I set the balance to "slow" and balance tickle "on". Without that, it would likely have finished even faster.
Yesterday, I spent a beautiful day at the canal, driving my new Airboat. I made a couple 10A charges, until my lead acid battery was drained
Everything worked flawless, and my buddys consider buying such a charger, too
Cheers,
Julian
What firmware upgrade?
skypilot_one is offline Find More Posts by skypilot_one
Old Jul 29, 2008, 08:35 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Hello skypilot,
Sorry to say that we have closed the firmware upgrade now, for there are strange behaviors occured in LKC and bedger-b' chargers after firmware upgrading.Now, their chargers are on the way to us, we will investigate the cause for these strange behavior, after we finish the investigation, we will
re-release the firmware upgrading file.
Best regards,
Junsi
junsi is offline Find More Posts by junsi
Old Jul 29, 2008, 08:40 PM
Sisyphus is offline
Find More Posts by Sisyphus
Sisyphus's Avatar
Upper U.S.
Oh, my, we've got trouble right here in River City.
Sisyphus is offline Find More Posts by Sisyphus
Old Jul 29, 2008, 09:28 PM
planekrazee is offline
Find More Posts by planekrazee
Gales Ferry, CT
Joined Jun 2008
junsi,
Does the Chargery charger suffer from these problems or does it use someone elses proprietary code?
I bought two 106b chargers and do not feel comfortable using them. I thought I was buying a product tested and marketed as a good, fast charger with superior power and speed to the CellPro10S. From this thread I have found it can't balance charge in less time no matter what the ratings are.
I feel that if the units have problems that you don't have a repair for YOU should refund my money and the money others have spent on this untested product. YOU should do your testing by giving the chargers to a select group of people and let them do your beta testing and not sell units with QC issues that have not been properly tested. The FMA chargers were beta tested before being sold to the general public to get the big bugs out.
As a consumer it is not my responsability to purchase and install an upgrade adapter to download code, code that does not fix the problems and make the charger what it should have been.
When I saw all the possible charge senarios for the LiPo packs I had a feeling the software was not going to work properly. It looked like you didn't know the right way to get the charger to function.
planekrazee is offline Find More Posts by planekrazee
Old Jul 29, 2008, 09:32 PM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
Originally Posted by planekrazee
junsi,
Now you've gone and done it.
Old Jul 29, 2008, 09:38 PM
Gales Ferry, CT
Joined Jun 2008
The manufacturer should have used thier own money for testing, not mine. I don't like throwing away money.
Old Jul 29, 2008, 10:39 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
junsi,
Hello planekrazee,
We can fully understand your mood.
To some extent you are right.We admit that there are some bugs with our current chargers. Actually, before releasing the 1010B and 106B, the two products have experienced a lot of beta tests in our country, which almost took a year to finish these beta tests. After we put our products into international market, we receive a lot of kindest suggestions for improving our products; we try our best to implement these features needed for our end users to our chargers. And the current two chargers version 3.06 are far different from the original ones, we have to admit that we didnít thought that new features implement would bring such troublesome bugs. Now, we are focus on optimizing these features in our chargers and are responsible for making our products reliable.
As for your two chargers, please contact your supplier as soon as possible. If you still have problems regarding our products, feel free to contact us!
Best regards,
Junsi
Old Jul 30, 2008, 04:39 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Just to make sure that the horse is really dead...
Tested the two balancing methods using Hyperion charger and balancer (modified so that balancing can be turned off manually). An old 1800 (used to be) 3S Lipo was charged and balanced prior to the test. Discharges was done using 12V bulbs down to 3.0V on lowest cell. The pictures should speak for them selves. Differences in charging time/mAh put back was smaller than I expected:
65:18/1439 mAh vs 63:28/1379 mAh.
No need to balance the whole time though .
Fred
flarssen is online now Find More Posts by flarssen
Old Jul 30, 2008, 05:08 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Good test.
You can see also that the third cell gets even higher than the other two in the end, when balancing the hole time.
So the balancer has too bleed more current away:
first in the beginning and the in the end.
I also often ascertained that balancing from the beginning is not necessary, because the imbalance is getting smaller in the end.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Jul 30, 2008, 05:15 AM
Son, Norway
Joined Sep 2004
As a software developer, I know that implementing new functionality can lead to unexpected problems. Even fixing a bug often creates new ones . Looking back, what you probably should have done was to collect all the suggestions, implemented them and run a new round of beta testing before releasing it to the wolves.
Hope you get the problems fixed soon .
Fred
Old Jul 30, 2008, 07:55 AM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
Fred, it appears to be a hardware thing, too.
Most consumers have as a basic assumption that a product is reasonably tested in all aspects before marketing. (This is not just my opinion, but that of the commentators, too.)
And, that is also the basic assumption underlying products liability: the burden is on the manufacturer to conduct all testing, etc. before distribution since it has the superior ability to do so.
Like it or not, that's the way it is in most markets.
Old Jul 30, 2008, 08:18 AM
Gales Ferry, CT
Joined Jun 2008
junsi,
Old Jul 30, 2008, 01:03 PM
badger-b is offline
Find More Posts by badger-b
Badger
badger-b's Avatar
UK
Joined Jul 2008
VERY long balance times
Seems I am also suffering with extremely long balance charge times - as reported by others. 8S A123s with 2 x 4 point balance plugs , correctly wired and plugged in. At start the pack shows
1@ 3.58 2@ 3.54 3@ 3.60
4@ 3.56 5@ 3.56 6@ 3.56
7@ 3.47 8@ 3.60
Disabled timeout limits and set up a 4.6A balance charge, with balance on CV stage setting.
Some 3 hrs and 11 minutes later I get.....
1@ 3.55 2@ 3.53 3 @ 3.51
4@ 3.40 5@ 3.40 6@ 3.55
7@ 3.59 8@ 3.60
Version 3.06 as before ( charger is being returned to junsi when my replacement arrives ) but wondered what the fix was for this particiualr issue
badger-b is offline Find More Posts by badger-b
Old Jul 30, 2008, 01:31 PM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
hm.. i waiting for mine devices with 3.06
hope it will be fixed soon
alex.guzun is offline Find More Posts by alex.guzun
Old Jul 30, 2008, 01:39 PM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
Originally Posted by badger-b
Seems I am also suffering with extremely long balance charge times ....
I think Julez reported this as solved by Junsi in the upcoming update (v3.07 ?). Julez go to test this before general availability as I understood his post #1396.
Trickle off, and fast balance charge seem to be the workaround.
T
thomanie is offline Find More Posts by thomanie
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
