Old Jul 25, 2008, 06:44 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi!
I just recieved an upgraded firmware from Junsi, and it appears as they finally solved the slow balancing issue.
With the old firmware, I let the charge, which I documented here, run until this morning. The charger still not terminated the charge after 43h
Then I installed the new firmware, connected the same pack again, and the charge was finished in ~30min. Note that I set the balance to "slow" and balance tickle "on". Without that, it would likely have finished even faster.
Yesterday, I spent a beautiful day at the canal, driving my new Airboat. I made a couple 10A charges, until my lead acid battery was drained
Everything worked flawless, and my buddys consider buying such a charger, too
Cheers,
Julian
Julez is offline Find More Posts by Julez
Old Jul 25, 2008, 08:54 AM
Sisyphus is offline
Find More Posts by Sisyphus
Sisyphus's Avatar
Upper U.S.
Originally Posted by kgfly
Very valid concerns. It appears to me that these units are still being made in fairly small batches which makes it possible to quickly respond to these issues and limit the number of customers affected. What stands out is that Junsi have never dodged an issue, have found and implemented fixes and have made good for anyone that had an unresolved problem with their unit. It is that attitude and behaviour that keeps me enthusiastic despite the problems.
I think the problem with the coil pressing against the inside edge of the case lid is one I would like to see some comment on from Junsi. Is there a fix planned for future builds ?
Do you have a financial interest?
Sisyphus is offline Find More Posts by Sisyphus
Old Jul 25, 2008, 08:59 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
The ignore function can really be a relief
Old Jul 25, 2008, 09:00 AM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
I for one am very happy to hear this great news!
Phoenex is offline Find More Posts by Phoenex
Old Jul 25, 2008, 09:19 AM
Phoenex is offline
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Read the thread before posting or use the thread search function. Post 1023
Old Jul 25, 2008, 09:25 AM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
So, to paraphrase another, "How tiny, is tiny?" (It depends on what "is," "is.") People with a stake in a matter seldom are totally objective. That's not a bad thing or a good thing, just a way of weighing what is said.
Old Jul 25, 2008, 10:20 AM
trustworthy97 is offline
Find More Posts by trustworthy97
Joined Oct 2007
Originally Posted by junsi
Hello,
Thanks for your concerns!
We are so sorry about these QC issues. Fortunately, we finally find solutions to these QC issues. As for the bad solder joints, we require our staff in factory to do soldering carefully and another person to be charging for QC. For the components shorting against case, we will do a little change to the inner cover. As for the banana sockets, we plan to change the current sockets into gilded banana sockets.
Best regards,
Harrief
Guys, if everybody had the same feelings about this charger, it would be a very dull thread. Here's my take on this-"if" this thing caused a fire, I'd be pretty upset if I lost something like my house. I'm not an engineer, but it looks and sounds like it could happen, then where would you be, even if you like to tinker?
Maybe it's not fair to compare, but I'll bet Ford wishes it had done more "development" before the old Pinto went on the market.
Tinkering is fun, but if there is any potential for danger, well, I don't think that's fun.
You can say it'll never happen, but you know what does happen.
If I'm wrong, I'm sure somebody will say so.
trustworthy97 is offline Find More Posts by trustworthy97
Reply With Quote  (Disabled)
Old Jul 26, 2008, 03:41 PM
tantive is offline
Find More Posts by tantive
Joined Mar 2008
Hi,
I really like this charger and recently upgraded it to FW 3.06.
I'd like to suggest some additional features (wishlist):
-Special Mode Power supply:
Like Foam Cut, so adjustable voltage and current, but no time limit.
So the charger can be used as an power supply for all types of mobile devices ranging from cell phones to laptops.
-Display the amount of mAh per cell during balancing.
Showing the balanced mAh on a per cell basis could really help users to identify bad cells in their packs (e.g. 3s lipo, one cell balanced around 100mAh, other two cells just 20mAh).
-Determine the internal resistance of the connected pack (don't know if possible).
Just see those suggestions as wishes of which I think they could make this wonderfull charger even better
Kind regards
Michael
tantive is offline Find More Posts by tantive
Old Jul 26, 2008, 07:16 PM
longhair is offline
Find More Posts by longhair
Why's the rum always gone?
longhair's Avatar
Beaver Falls, PA
Joined Apr 2004
I just updated mine to 3.06. other than having to tear into it a second time to remove my momentary switch to put it on upgrade mode that was a very pain free upgrade. A couple servo leads and USB-TTL converter. No need to search out special drivers, three easy to solder connections. I think both my Trirons may go up for sale so I can but a second 1010b.
Nice charger Junsi.
longhair is offline Find More Posts by longhair
Old Jul 27, 2008, 08:42 AM
madhun1 is offline
Find More Posts by madhun1
QPower 18650
madhun1's Avatar
Sunshine Coast
Joined Jun 2006
Originally Posted by luky
So you don't have to worry about ordering it from China.
What is so worrying about ordering from China?
madhun1 is offline Find More Posts by madhun1
Old Jul 27, 2008, 10:25 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by tantive
Hi,
Kind regards
Michael
Hello Michael,
Thanks for your feedbacks and your kind suggestion.
As for the Special power supply mode,"francu" has mentioned in post 1213
We are sorry to say that it's difficult for us to add this feature into our current chargers for we use MCU to adjust power supply, the adjusting reaction speed of MCU isn’t so fast as the power supply’s loading speed. If the power supply’s loading speed changes too fast, which may do damage to the charger. We will take this into consideration for our later chargers .
Best regards,
Junsi
junsi is offline Find More Posts by junsi
Old Jul 27, 2008, 10:38 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Gilded banana sockets
Hello everybody,
We just got the gilded banana sockets from the factory, let’s see what them look like, see picture in attachment !
Best regards,
Junsi
Old Jul 28, 2008, 02:11 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
1)Dataloging via USB/SD Card
We plan to develop the next charger which support dataloging via USB .
2)Bidirectional PC Communication for charging parameters/monitoring
We will take this into consideration, now, we are study the "Logview" to see whether its suitable for our charger.
Does this mean that there will be no logging capability in future firmware versions for the current charger?
Discussing plans for a "next charger" before the current one is even stable, is perhaps not a smart move. Many people don't like to see new improved models released just after they bought the thing! Just have a look in the x last pages of the Hyperion Duo thread:
http://www.rcgroups.com/forums/showthread.php?t=790474
Fred
flarssen is offline Find More Posts by flarssen
Old Jul 28, 2008, 03:25 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Fred
Hello flarssen,
Nice question!
The next charger is just a plan, we are now focus on improving the current 1010B and 106B, we won't release any new chargers until the current chargers become stable. We are serching for a way to add the logging capability to the current chargers in future firmware versions.
We welcome users to make wish list here, and glad to see that they share their great ideas with us.
Best regards,
Junsi
Old Jul 28, 2008, 03:46 AM
ptt81 is offline
Find More Posts by ptt81
ptt81's Avatar
USA, TX
Joined Feb 2005
Originally Posted by Julez
Hi!
Cheers,
Julian
Is this a new firmware of is that the V3.06? Im glad to hear that they slow balance is gone, thats the exact problem I reported in earlier posts. Btw, I got an extra one of these if anyone is interested.
ptt81 is offline Find More Posts by ptt81
Site Sponsor
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
