Old Feb 26, 2013, 07:16 PM
RedOctobyr is offline
Find More Posts by RedOctobyr
United States, MA
Joined Jan 2011
If you plug a known-good battery (one you've been using without issues) directly into the balance ports, and plug in the main discharge leads, is it any better?
If not, and it's been working OK, I'd suspect something's wrong with the charger.
RedOctobyr is offline Find More Posts by RedOctobyr
Old Feb 26, 2013, 07:20 PM
GoNavy93 is offline
Find More Posts by GoNavy93
Joined Feb 2013
It would be nice if these chargers had factory/system reset sort of thing where you hold down some buttons or whatever on power-up.
GoNavy93 is offline Find More Posts by GoNavy93
Reply With Quote  (Disabled)
Old Feb 26, 2013, 07:35 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Load a default memory setting if you havent used all 10 of them.
evltoy is offline Find More Posts by evltoy
Old Feb 26, 2013, 08:07 PM
GoNavy93 is offline
Joined Feb 2013
Good idea! I don't use the memories anyway.
Old Feb 27, 2013, 01:24 AM
Ricky971 is offline
Find More Posts by Ricky971
Italy, Toscana, Orbetello
Joined Mar 2012
Hi Guys...
...Is there a way to clibrate the input volgate reading on the chargers? I know you can clibrate output cell voltage readings.
evltoy
Off course, there is! I've a 106B Plus with 3.14 firmware, but I think that is the same with the other BC.
Prepare Your charger, Your Power Supply (and Your battery, if You want to calibrate everything).
Let's measure the PS output voltage.
Press all the four buttons togheter on Your iCharger and then electrify Your iCharger.
You'll ear four "beep": immediately after the fourth "beep" release the buttons.
If You don't release the buttons immediately after the beep, it will appears a write on display "Junsi...n. xxxxxxxxxxxx" with the serial number and You have to restart operation.
If You have released the buttons in time, You'd have a normal display page.
Press and hold for three seconds the "Stop" button: now You'd have a display page with "Vi xx.xxV" - "Int xx " - "Vo 0.00V" - "Ext 0"
Let's press togheter and hold for three seconds the three buttons "Dec", "Inc" and "Start".
Now You'd have the "Vi" blinking and showing alternatively the setted amount and the calibration amount.
With the "Inc" and "dec" buttons You can now set the correct amount that You've measured before, with Your precision multimeter.
If You want to calibrate also "Vo", let's measure Your Lipo battery, then connect it to the BC.
Press "Start" button and it will start to blink the "Vo" amount; let's do the same and correct it.
If You want to calibrate also single cell amount, You had to connect both, the Lipo power plug and the lipo calibrating plug, then press "Stop" and the display will stop blinking.
Let's press "Inc" button for a little and You'd have the cell's voltage page.
Press and hold for three seconds the same three buttons (dec, inc, start) and it will start to blink the first amount, press start again to move between cells amount, press "Stop" to end.
Ricky971 is offline Find More Posts by Ricky971
Old Feb 27, 2013, 04:47 AM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Ricky971
This info is GOLD! Thank you for taking out the time to explain this to me.
Old Feb 27, 2013, 04:57 AM
Ricky971 is offline
Joined Mar 2012
It's a pleasure! I think that this is the reason because Forums exist.
Old Feb 27, 2013, 05:53 AM
Gayo is offline
Find More Posts by Gayo
Joined Feb 2013
Have you tried manually setting it to 2S instead of letting it auto-detect the cell count?
Yes, but no luck.
Nope, it didn't worked.
I guess I have to send it back in warranty.
Thanks for your help!
Gayo is offline Find More Posts by Gayo
Old Feb 27, 2013, 08:33 AM
LoopyStickman is offline
Find More Posts by LoopyStickman
Netherlands, NH, Amsterdam
Joined Feb 2013
iCharger 206 with P350 supply
Hi guys, complete newbie here at his first post, please have mercy! I am shopping for my first Bixler 2 build and I want to buy the iCharger 206B with the P350 power supply.
http://www.progressiverc.com/icharger-206b.html
http://www.progressiverc.com/p350-power-supply.html
However, the specs for the 206B say:
"Maximum charge power capacity: 300W (@ input voltage > 18V)"
And in the specs for the P350:
"Output voltage: 15V DC"
Does this mean that I cannot get the full 300W out of the 206B with that power supply?
I don't think I will need anywhere near that in this moment, but I am trying to look down the road a bit.
LoopyStickman is offline Find More Posts by LoopyStickman
Old Feb 27, 2013, 08:45 AM
United States, MA
Joined Jan 2011
Welcome!
That's correct, you won't get the full 300W out of the charger with 15V. Depending on what you plan to charge, that may not be an issue just yet. If you're only going to be pulling 200W (as an example, which would be 16A for 3S), you're fine for now.
Depending on budget, and how much DIY you're willing to entertain, you can buy/make a much more powerful power supply than that 350W, for less money.
A pair of used HP DPS-600PB server power supplies, wired in series, will give you 24V, 47A, 1150W. You can buy them for about $30 shipped, from eBay. Solder some wires on, connect some pins together, and do a ground modification, and you're in business. There are excellent instructions in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1581061
You can also start with just 1 for 12V, 47A, 575W, for $15, for now. The modifications are simpler when just running 1 (no need for the ground modification, so you don't have to open the cases on the supplies). The modifications sound harder than they actually are. If you can use a soldering iron, you can modify a single supply pretty readily. You could add a second later when you need the higher voltage, to achieve the full 300W output. You can modify two yourself for probably about $40-50, depending on what you spend on wire and connectors.
You can also buy them pre-modified for our use. Figure ~$60 or so for one, for 12V, more like $120 for two, for 24V. feathermerchantrc.com is one vendor, mrforsyth on this forum also does them, there are options as well.
Just an option that could give you more power for less money than a commercial hobby supply.
Old Feb 27, 2013, 09:08 AM
Jimmie Neutron is offline
Find More Posts by Jimmie Neutron
Michigan
Joined Jan 2011
24v/47a would "only" be 1128 watts
12v/47a would "only" be 564 watts
I build and sell 24v/41a/984w units with a handle, switch, and single AC cord conversions ready to hook up to your charger and use for less than $100 shipped within the lower 48 states.
Feathermerchant is a great guy to buy from as well.
Jimmie Neutron is offline Find More Posts by Jimmie Neutron
Old Feb 27, 2013, 09:47 AM
GoNavy93 is offline
Joined Feb 2013
I build and sell 24v/41a/984w units with a handle, switche, and single AC cord conversions ready to hook up to your charger and use for less than $100 shipped within the lower 48 states.
Dang, wish I'd known that. I just dropped $70 for a second converted and DC isolated HP server power supply. I want my 1000+W.
Old Feb 27, 2013, 05:52 PM
Joined Feb 2013
Just... wow.
RedOctobyr, if yours is not the most awesome, clear, exhaustive and welcoming reply ever to a first post, I don't know what is.
Thanks a lot for the info, I'll think about if the P250 is enough for now and look into the alternatives.
Old Feb 28, 2013, 03:22 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by Gayo View Post
When I plug everything, the screen says "Bal. Low". If I try to force the charge, the charger stops and shows:
BALANCE PORT
CELL LOW VOL
1: 3.90____3.95____0.95
Please check the PM we have sent to you.
Junsi
junsi is offline Find More Posts by junsi
Old Feb 28, 2013, 11:47 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Is there a REPAIR contact in the USA ?
I just plugged in my TRUSTY and LOVED 206b and ...
IT PULLED DOWN THE POWER SUPPLY.
Bottom case felt hot so I opened it up and check for the usual stuff,
No bulged electrolytics, no burned traces, no popped chips no obvious shorts.
I have NOT looked under the LCD YET
But the TRF1404 or TRF3205's are the big boys where it's getting HOT !
There IS a trace between the 1404 and 1st 3205 that looks Shorted but possibly by design.
You cant see it unless you Bend up those two TO220's
It's a feed thru next to a large Diagonal trace.
Spoz I could LEAVE the PS plugged in and wait till something POPS ! NOT !!!
Anyone ???
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
