Old Feb 01, 2013, 12:52 PM
Ricky971 is offline
Find More Posts by Ricky971
Italy, Toscana, Orbetello
Joined Mar 2012
Hi everybody.
I'm buying a used 106b Plus; the owner told me that he'll sell it at a low price because there's a problem: the battery charger normally switch on and start to charge but after 3-5 minutes it switches off itselves and then auto re-switch on.
I was reading something about a firmware upgrade that could solve this problem but I'm not sure 100%.
First question: is this a problem that is possbile to solve with a firmware upgrade?
Second: are all the 106b Plus upgradable?
Thanks everybody for the answers.
Ricky971 is offline Find More Posts by Ricky971
Old Feb 01, 2013, 08:51 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
You can try to upgrade to the latest V3.14 check if it can solve your problem, and let us know the result, thanks.
Junsi
junsi is offline Find More Posts by junsi
Old Feb 01, 2013, 09:16 PM
RedOctobyr is offline
Find More Posts by RedOctobyr
United States, MA
Joined Jan 2011
Hi everybody.
It's probably unrelated. But I've had this problem when using a 15V, 6A (90W) laptop power supply to power my charger (happens to be a 106B+, but would apply to anything). The power supply claims it can put out 6A.
But if I draw too much during a charge, like 5A, I can feel the power supply warming up, and the supply will eventually shut itself down, then turn on again, likely due to over-temperature protection.
When it does, I get the symptom you describe, the charger shuts off in the middle of a charge, then turns back on.
I can avoid this by reducing my charge rate so I don't overwhelm the supply. Or I run it off my big power supply
If the seller's power supply is up to the task, then it's probably not this. But I just figured I would mention it, as I can trigger the same symptoms.
RedOctobyr is offline Find More Posts by RedOctobyr
Old Feb 02, 2013, 01:54 PM
Ricky971 is offline
Joined Mar 2012
Thanks for answers!
Effectively, the owner uses a PSU Imax 401, that's a laptop power supply with 12V-5A output.
I'm just afraid that I'll buy this used charger for a (low) price but I won't be able to solve this problem.
I've just to decide if to buy it at a good price or to renounce at the "business" because it's not sure 100% that this problem can be solved with a firmware upgrade or changing the power supply.
The fact that it switches on is a good point of start, but maybe it's better to spend more money and to buy another one...
Help me to decide with Your experience, please!
Old Feb 02, 2013, 02:28 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Buy quality.
loNslo is offline Find More Posts by loNslo
Old Feb 02, 2013, 02:46 PM
Ricky971 is offline
Joined Mar 2012
Junsi
Thanks for Your suggestion.
You're the iCharger's farm owner, isn't it? What do You think about it?
Get the risk or change target?
Old Feb 02, 2013, 02:48 PM
Ricky971 is offline
Joined Mar 2012
Originally Posted by loNslo View Post
Buy quality.
So, Your opinion is that I'd have to renounce to this one?
Me too I'm slowly going in this direction...
The price was very good, but if it's broken is money in the garbage.
And this is not the right period to do these things...
Old Feb 02, 2013, 04:15 PM
United States, MA
Joined Jan 2011
FWIW, that is basically a smaller version of my laptop power supply. With the same symptoms as when I overdraw mine. That one is 60W vs my 90W. It doors not take much of a charge to exceed that.
Mine will reset when I overdraw my laptop supply. But will hammer along at 10A, 250W when I run off my 500W power supply.
The owner may simply be asking to much of the supply. Charge slower, or buy/build a better supply, and you *could* be fine.
Old Feb 02, 2013, 05:01 PM
Ricky971 is offline
Joined Mar 2012
Thanks, this is a positive point.
Whch kind of USB cable can I use to connect it to the PC?
The owner doesn't have it.
Old Feb 02, 2013, 05:49 PM
sebes is offline
Find More Posts by sebes
Joined Dec 2012
I'm using iCharger206 with solar panels. It works surprisingly well with variable input voltage. Not ideal of course, because iCharger doesn't have MPPT (maximum power point tracking) function. But it has input voltage cutoff setting in Settings menu, so I can choose correct input voltage myself prior Pb battery charging.
If I put (in Settings menu) for example 16V for input then iCharger holds this voltage very strictly and adjusts charging current itself. If I put 10A for example, then charger outputs only 4A. More sun, more current.
Very cool feature I guess it makes iCharger superior to most PWM solar chargers.
My "wishlist" for future firmware change would be:
1. Possibility to change input voltage cutoff during charging. Now I must stop the charge, change input voltage cutoff and then start charge again.
2. Option for Ni-Zn charging.
3. Option for balance discharging NiMH/NiCd batteries. iCharger stops discharing when first battery reaches it's minimum (0,9V or so).
sebes is offline Find More Posts by sebes
Old Feb 02, 2013, 06:10 PM
United States, MA
Joined Jan 2011
You need a special UNgrounded USB cable. See these posts, for instance:
A post by junsi:
http://www.rcgroups.com/forums/showp...postcount=2167
Another thread worth reading:
http://www.helifreak.com/showthread.php?t=363689
I don't know where you get another one, unfortunately. Perhaps you could somehow modify a normal USB cable to behave this way?
Old Feb 02, 2013, 07:44 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
No need to modify a cable. Simply use a 3S lipoly that is at least 1/2 charged to power the charger during firmware update to avoid any possible ground loop. I use a battery to power my charger during upgrade even when using the modified cable.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 02, 2013, 08:13 PM
United States, MA
Joined Jan 2011
Oh, that's a good idea, and pretty straightforward.
I was thinking about when connecting to a PC, for logging data during a charge/discharge.
Old Feb 02, 2013, 09:31 PM
kevinjulieevan is offline
Find More Posts by kevinjulieevan
kevinjulieevan's Avatar
United States, TN, Maryville
Joined Dec 2010
lipo storage voltage
i just got the 306b and a paraboard. i've noticed that when using the storage lipo setting it only drops the voltage to 3.9 volts per cell. my other chargers dropped my lipos to 3.8 volts per cell. can this be adjusted?
i was also wondering if it's ok to try and use the storage mode with the paraboard to drop several lipos to storage voltage at the same time?
thanks for any info or tips
k.t.
kevinjulieevan is offline Find More Posts by kevinjulieevan
Old Feb 02, 2013, 11:13 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
k.t.
Set your parameter for discharge reduce to "ON" and a value of 10%
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
