From first post of this thread
Joined Jan 2012
Hi.
I am getting the connection breakdown error on my 1010B+ due to a friend that accidentally plugged my charger to a 24V source instead of 12V source in Flying Field. The charger detect lipos when i plug in it, measure IR pack and discharge functions are OK, but charge lipos is impossible. I checked components D16 & Q26 and both seems to be ok. ![]() I tried to upgrade again 3.14 firmware, but the problem persist. Perhaps other components can be damaged? I dont see anything burned, but i am not a electronic expert. ![]() ![]() ![]() ![]() Any idea?? Thanks you! Palber |
Joined Feb 2011
SOP should be to contact the vendor where you purchased the charger and seek a return for repair authorization. If purchased from Progressive RC or EPBuddy then most often they are extremely good at taking care of their customers. If purchased from HK then I wish you luck.
If you are a DIY pearson then disassemble the charger and take very high quality hi resolution photos of the inside and post them and perhaps someone can spot the problem. You should perhaps also email or PM Junsi directly. It is always a good idea to read the FAQ file in the first post of this thread. Charles |
Canada, BC, Vancouver
Joined Oct 2011
Using 3S lipo as power supply for 306B?
Can I safely plug a fully charged 3S lipo into its paraboard, then hook up the paraboard to the power supply side of the 306B -- making the 3S lipo the power source?
Using 2 x 2.2mah 3S lipos plugged into the paraboard, would I then get 11.1V input with 4.4mah capacity? Supposing this would work, what would be the charging capability of the 2 x 2.2mah lipos? Will the charging side lipos discharge down to 3.3V per cell? Or will they stop discharging when the recipient lipos contain the same amount of energy as the power supply lipos? Please excuse any terminological blunders. Thanks! |
So. Cal.
Of course it will work. You will have ~44Wh of available charging capacity, assuming ~90% efficiency for your 306B. Depending on where you have minimum input voltage set on your 306B, you could easily overdischarge and damage your two 3S lipolys if you're not observant of what you're doing.
What exactly is it that you're wishing to accomplish? Having a detailed understanding of your end goal will be helpful in providing the best recommendation that will give you the highest probability of success. ![]() Mark |
Joined Oct 2011
Thanks for the observation about minimum input voltage: I'll be sure to get that right.
What I want to do is to recharge a set of 3 x 850mah 3S lipos via the 306B and 2 x 2200mah 3S lipos as source, so that I can achieve extended flying sessions on occasions when using a car battery isn't an option. Thanks! |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
