I'm also having issues with my balance port. Mines continues to give a "balance error" when plugged in. The charger works fine otherwise.
I opened up the charger, but I couldnt remove the lower cover because of the thermal paste on a component down there. Didnt want to pull too hard. However, from the top the board looked ok and the balance board is fine. any other ideas? |
Latest blog entry: SS FPV Maiden
I"m very happy with mine otherwise. I've had it for many many years (probably since the first came out). This is the first time its had issues..
Joined Oct 2007
As I charge packs parallel, such unbalance after STO mode is confusing to me ![]() Below there is procedure how I process when want to charge parallel packs: 1. Store all of them after STO mode with known voltage (3.85V per cell) 2. Connect parallel -> as voltage is equal on each cell connection is safe 3. Charge I do it with my Accucell (it balance also during STO mode) and it works excellent. Now it seems I need to find out how to match cell in 6s packs with iCharger without charging... Any idea? |
If your other charger has the same LiPolys perfectly balanced at Storgae then either it is balancing during discharge ( Not Good) , the LiPolys which are balanced at Storage are different ones and their cells are perfectly ,matched or at least matched bery well. For the past 6 years or so since I started recomending 3.85 per cell as the optimum Storage Voltage many have worried about cells at 3.7 ,3.8.3.9 etc. It does not matter. Storage between 3.7 and 4.0 is fine. I choose 3.85 as it is the mid point of this range. If the cells are not exactly matched capacity wise and the charger balances during discharging it will just make it more difficult to balance correctly during charging to 4.2. If you spend some time reading and studing the graphs here then the reason for unbalnced cells at different states of charge will be clearer and perhaps it will explain why discharged to storage or below cells should not be Forced into balance. http://www.rcgroups.com/forums/showt...ghlight=balanc Charles |
with my 206B, when charging small lipos (2S, 450mAh), the display of input voltage shows 24,35 Volts, which is probably correct but an input current of 0.00 Amperes which cannot be true.
With bigger lipos and higher currents (above 1A?) the displayed input current seems to be correct again. Is this normal? |
Son, Norway
Joined Sep 2004
Fred |
Joined Oct 2007
I'll explain the issue in another way ![]() Mentioned 6s I did for DIY LED project (3x2s) but for daily usage I fly with 2s and 3s. After flights, all packs I stored at 3,85V using STO mode in Accucell. In order to shorten time I connected them in series up to 6s -> 3x2s or 2x3s and as a result all cells regardless their initial state are 3,85V. If after few weeks I find some time in the afternoon for flying, I need to charge them very quickly - so as all of cells in all packs are 3,85V - I just connect them parallel and after 30 min, I go to my airfield with 3 fully charged 2s packs. That how it works with Accucel, buying more advance iCharger (besides a lot of other nice figures in 206B) I was thinking to do the same with 206B. It looks so simple (above) with cheap charger and it's hard to me believe that such "machine" like iChrger can't offer balancing during Storage mode ![]() Quote:
![]() Yes I agree. In my case the aim to have all cells at 3,85V is further parallel connection and charging multiple packs in the same time. |
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
