Old Oct 06, 2012, 03:51 PM
seattlebuoy is offline
Find More Posts by seattlebuoy
seattlebuoy's Avatar
United States, AZ, Flagstaff
Joined Sep 2011
I am considering purchasing the Icharger 206 or 306 and have a question. I will mainly be charging 3S batteries. Is there a current limit when charging with a 12 V power supply? My target is to have between 10A and 12A when charging 3S with a 12v power supply. Thanks!
seattlebuoy is offline Find More Posts by seattlebuoy
Old Oct 06, 2012, 04:09 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
The limit is 1/2 the output of the rated full input (this case 24V).
This is generally true for most chargers.
Although some chargers require 26V - 30V input to get full output.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Oct 06, 2012, 04:37 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Both chargers are capable of charging 3S at 10-12A with 12V input. Charging 3S means that input and output current is more or less the same.
Fred
flarssen is online now Find More Posts by flarssen
Old Oct 06, 2012, 04:51 PM
madmaxed is offline
Find More Posts by madmaxed
United States, MI, Grand Rapids
Joined Jul 2011
TheWoodCrafter is correct for the 306B but not for the 206B. The 206B has a maximum charge of 20A. This applies to the input as well as the output. Therefore at 12V input, 20A current, it is limited to approximately 240W charge.
Still more than enough to do 3S at 10-12A.
madmaxed is offline Find More Posts by madmaxed
Old Oct 06, 2012, 05:02 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
306B has a 50 amp limit for input and a 30 amp limit for output. It also has a 500 watt limit when input is 12 volts. It will never reach that limit on the input with 12 volts. It can reach the output limit though not on 3s packs.
gulio is offline Find More Posts by gulio
Old Oct 06, 2012, 05:25 PM
Joined Sep 2011
Thanks folks. My current charger is rateds at 5A, but only does that with 120V input. On the 12V PS, it only does 3.5V and tired of 1S charging in the field. Bumping to 2-3S will be very nice.
Old Oct 06, 2012, 06:00 PM
Joined Sep 2011
I think I see a 306 coming my way in the near future...!
Old Oct 06, 2012, 06:36 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
There is a graph in the manual for each icharger which shows the maximum output power for any input voltage, you can answer your question by reading the manual, which I'd always worth doing when investigating buying a new piece of equipment.
kgfly is offline Find More Posts by kgfly
Old Oct 07, 2012, 07:07 PM
Joined Sep 2011
I had looked at the manuals of several other chargers to no avail for the info I sought, so did not even bother looking until after my question was answered. A good manual for a change!
Old Oct 10, 2012, 05:59 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
I have a 106b that has a problem,where all my r/c stuff is 2s lipo the charger does it's job just fine however when balance charging my Zippy 5s cordless drill batt cell no4 reads very low and from storage voltage the charger goes into balancing eventually over 4 volts this cell will stabalize and the reading becomes acceptable.When it's in this stage of an imbalanced reading all of my testers read that cell as normal voltage that would be cheap buzzers to my EOS Sentry at the end of charge cycle the resting voltages are OK ,i am using my older acucell 6 on it where and the cell readings are normal all the way through the process for saftey, as my primary concern is this false reading will somehow entice the charger to do the wrong thing,has anyone seen this weird behaviour on a 106B.Thanks
The Tug is offline Find More Posts by The Tug
Old Oct 10, 2012, 01:14 PM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Holy lack of periods. LOL
neck is offline Find More Posts by neck
Old Oct 10, 2012, 03:53 PM
Tag1260 is offline
Find More Posts by Tag1260
USA, Eastern Ohio
Joined Jan 2005
Must Refrain, must refrain, must refrain..........
Tag1260 is offline Find More Posts by Tag1260
Old Oct 11, 2012, 07:08 AM
The Tug is offline
Barbados
Joined Jan 2011
Originally Posted by The Tug View Post
I have a 106b that has a problem,where all my r/c stuff is 2s lipo the charger does it's job just fine however when balance charging my Zippy 5s cordless drill batt cell no4 reads very low and from storage voltage the charger goes into balancing eventually over 4 volts per cell this will stabalize and the reading becomes acceptable.When it's in this stage of a very imbalanced reading all of my testers read that cell as normal voltage that would be cheap buzzers to my EOS Sentry, at the end of charge cycle the resting voltages are OK ,i am using my older acucell 6 on it where and the cell readings are normal all the way through the process for saftey as my primary concern is this false reading will somehow entice the charger to do the wrong thing,has anyone seen this weird behaviour on a 106B.Thanks
When the drill is in use i run a buzzer and the cell voltages are coming down fairly close which says to me it's not the battery having a bad no 4 cell,quite perplexing this,i suppose my solution would be to use the Acucell6 on this battery and use the 106b for my r/c stuff
Old Oct 11, 2012, 11:59 AM
bradhoke08 is offline
Find More Posts by bradhoke08
Old Dog learning new tricks~~
bradhoke08's Avatar
United States, PA, East Stroudsburg
Joined Jan 2011
Ok I have a 306b charger and my question is---
when battery is fully charged the 306b shows the cells all at 4.20 each but then when I check with any other battery checker like even the nice futaba battery checker/balancer it will show the cells decending like cell 1 @ 4.20 cell 2 @ 4.19 and cell 3 @ 4.18 and that would be the best case usaully it's not even that close. Is that what others are seeing as well? How accurite is the charger? and is it real important to have all equal cells or at what point of seperation should you be concerned?
Brad
bradhoke08 is offline Find More Posts by bradhoke08
Old Oct 11, 2012, 01:18 PM
gerard71 is offline
Find More Posts by gerard71
Joined Oct 2009
iCharger 106B+
Today I charged a 6s 5000mAh at 2C = 10A and I think the banana connected melted. Should I be worried or just solder a new connector?
Thanks.
gerard71 is offline Find More Posts by gerard71
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
