Old Oct 01, 2012, 11:00 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
You're welcome, Dan.
Today, I started charging a 2S pack that I made up. I set the charger to Lilo mode and 1.2 amps.
Make sure to balance charge. One never knows the state of charge of new individual cells.
Or better yet, charge them in parallel at first to ensure best equalisation.
And, 1.2A is a bit much for LiIon. The ones I use for my flashlights I usually charge at 0.5A.
The slower the better, if you are not in a hurry.
Jimmie, thanks for the kind words.
Julez is offline Find More Posts by Julez
Old Oct 01, 2012, 11:19 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Originally Posted by Julez View Post
If you are interested in maximum capacity, charge as LiPo.
If you want maximum life expectancy, charge as LiIon.
Every 0.1V less doubles the life expectancy.
WOW! No kidding?
loNslo is offline Find More Posts by loNslo
Old Oct 01, 2012, 11:29 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Originally Posted by danau View Post
Mark, do you notice a temperature rise when charging yours?
Typically not. But then I nearly always charge my low performance 18650's with either this charger or this charger. When I do use my iCharger, I charge low performance 18650's at about .4-.5 amps and walk away and only check the battery when it's done charging, at which point it's at ambient temperature.
My high performance 18650's (A123 LiFePO4) get charged at up to 5 amps and definitely experience a temp rise during charge.
As I see it, 5 degree C temperature rise in your cells is not particularly problematic but your charge rate may affect useful cycles. Bump it down a bit and temp rise will be negligible.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Oct 01, 2012, 07:13 PM
Cabledawg1 is offline
Find More Posts by Cabledawg1
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
Ive been needing a better charger and have recently bought a 24V 1400W power supply. Ive been studying 2 chargers...the Powerlab 6 and the 306B. Im pretty well decided on the 306B....mainly because its slightly less money.
Does EPBuddy or Progressive have a discount code or a shipping special?
Cabledawg1 is offline Find More Posts by Cabledawg1
Old Oct 01, 2012, 08:53 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
No, but
EP Buddy does offer free paraboards with a 306B purchase.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Oct 02, 2012, 05:54 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Originally Posted by loNslo View Post
WOW! No kidding?
No.
This is why I charge LiPos only to 4.15V.
I heard that the military, where dependability counts even more, charge them to only 4V or so. Maybe a little more.
Old Oct 02, 2012, 05:15 PM
eekflyer is offline
Find More Posts by eekflyer
Spark antenna on my Tx !
eekflyer's Avatar
USA, PA, Pittsburgh
Joined Mar 1999
106b+ update
Anyone gotten the 3.14 upgrade to work on the 106b+? I've tried to no avail on win7-64. My upgrader only shows the usb bridge device on a COM port, not a device name with a serial number as other charger models do. I tried both a standard and the 'special' cable. Tried pressing stop when powering up as well.
Also, I see 'charge port not connected', after about 3 mins into a charge, even though the charger shows good numbers for each cell (they are all within 0.1v of one another). The charger just started malfunctioning like this, recently. Anyone else see these problems?
eekflyer is offline Find More Posts by eekflyer
Old Oct 02, 2012, 09:45 PM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Any opinions as to whether it would be feasable to mod the 206b to increase the balance shunt current? Maybe someone has done it already. 200mA is not much to a 70Ah cell, though I realise the design was never for such large cells. Cheers :-)
Foxy is offline Find More Posts by Foxy
Old Oct 03, 2012, 10:48 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Ive been using a 306B for a couple months and recently its been charging my batteries and then entering an endless balancing cycle. It will charge normally but then go for hours in balancing mode. It only stops if I stop it manually or it hits the safety timer. Anybody know whats going on?
epyonxero is offline Find More Posts by epyonxero
Old Oct 03, 2012, 04:33 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Sometimes that is an indication of LiPolys going bad. What are the cell voltages displayed after 20 min. in the CV stage? Often dirty or loose balancing leads will cause issues also.
You could set to faster Balance and charger will not balance as long or as accurate. You could set the charge tro to say 4.15 versus 4.2 per cell.
Charles
Old Oct 04, 2012, 02:54 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
OT Sky Lipo's
anyone have experiece with these Lipo's?
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 05, 2012, 03:45 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Any ideas on why my 306b will not deliver the rated discharge amps with a resistor inline on +?
They are two one ohm 300w resistors paralled up.
stgdz is offline Find More Posts by stgdz
Old Oct 05, 2012, 04:40 PM
Jimmie Neutron is offline
Find More Posts by Jimmie Neutron
Michigan
Joined Jan 2011
So in other words you have 1 .5ohm 600watt resistor.
Jimmie Neutron is offline Find More Posts by Jimmie Neutron
Old Oct 05, 2012, 04:45 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Crap, knew I missed something. Late night work always misses something.
Time to desolder.
Old Oct 05, 2012, 04:51 PM
Michigan
Joined Jan 2011
I bet we have all made those late night mistakes!
Are you sure they are in parallel and not series? lol
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
