Old Sep 28, 2012, 06:41 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Non Dsch reduce.
Set to dsc. to 3.3 per cell at 5A
Actual LVC for a 3S would be 9.9V .
Start Dsc. and when 3S reachs 9.9 Dsch. ends.
Set Dsch. Reduce to 10%
Start same Dsch. now when 9.9 is reached under a 5Aload the dsc.is reduced same as a charge is normaly reduced until the 9.9V is reached under a reduced discharge of 10% of 5A or 0.5A.
Charles
Old Sep 28, 2012, 09:53 AM
gerard71 is offline
Find More Posts by gerard71
Joined Oct 2009
Thank you Charles.
I understand now.
gerard71 is offline Find More Posts by gerard71
Old Sep 28, 2012, 07:25 PM
aeromaniac is online now
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Hey Charles if the icharger storage voltage is 3.91 and the turnigy goes down 3.8v now I tend to parallel charge so mixing pack from storage voltage seems a bad idea ?.
aeromaniac is online now Find More Posts by aeromaniac
Old Sep 28, 2012, 07:28 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
.1V differential on 3S lipolys is absolutely inconsequential and the packs can very safely be connected together in parallel with zero ill effects.
Much higher differences have been empirically proven to produce no issues so you've nothing to worry about.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 28, 2012, 11:52 PM
Glow 😡 no no no
Joined Mar 2010
Mark
Thanks Mark for your reply.
Old Sep 29, 2012, 06:58 PM
danau is offline
Find More Posts by danau
Joined Apr 2009
iCharger 106B+ How to charge TrustFire
Hi,
Please, I need some help charging these batteries --> http://dx.com/p/trustfire-protected-...ue-5790?item=2
They are TrustFire TR18650 2500mAh 3.7V (Protected, Lithium ion)
I have given google a pretty good work out on this, but still i'm not 100% sure.
Question is, Should I charge them as LiPo, Lilo, or Life ?
What I have found is: Best to charge them at 0.5C...
A German forum suggested charging them as Lithium ion not as LiPo.
But... the battery indicates 2.75V as low cut, 3.7V Nominal, and 4.2V high cut.
Sounds like a LiPo to me...
Please help,
Dan.
P.S. Let me know if I should post this elsewhere. cheers.
danau is offline Find More Posts by danau
Old Sep 29, 2012, 07:36 PM
So. Cal.
I charge mine to 4.2 volts on lipoly setting.
Charging a .5C will leave the comfortably undercharged as they typically have pretty high internal resistance, especially with the protection pcb being part of the circuit.
Mark
Old Sep 30, 2012, 02:07 PM
LikeaNut is offline
Find More Posts by LikeaNut
Joined Sep 2012
data logging resolution
Hello
I just connected my iCharger 1010B+ to my computer. Data logging with Logview works fine, except that it only logs data every two seconds.
Is it possible to get a higher data log resolution? Like 0.1s would be nice.
thanks,
michael
LikeaNut is offline Find More Posts by LikeaNut
Old Sep 30, 2012, 02:35 PM
Jimmie Neutron is offline
Find More Posts by Jimmie Neutron
Michigan
Joined Jan 2011
I need a little help with hooking an external load for discharging.
I have searched, but I am getting a lot of non-relative results... too many for me to sift through.
A simple wiring diagram with load limits would be excellent!
Or maybe some links to where this topic has been covered before?
Thanks in advance!
iCharger 206B
24v/75a/1800w supply
Jimmie Neutron is offline Find More Posts by Jimmie Neutron
Old Sep 30, 2012, 05:42 PM
Southern Pride
If you are refering to using the Dsc. + feacture of the iCharger then
http://www.rcgroups.com/forums/showa...1&d=1320227505
If you want to build a very simple stand alone discharge unit
http://www.rcgroups.com/forums/showthread.php?t=1131817
Charles
Old Sep 30, 2012, 10:52 PM
Michigan
Joined Jan 2011
It is nice to see that you are still posting, Charles.
I remember reading your posts back when I read this entire thread, trying to decide whether or not to get an iCharger...
Thanks for the direction... now I need to study the spreadsheet and see if I can make sense out of it. lol
I am currently building my own stand alone discharger... I was just hoping to be able to possibly use the brains of the iCharger to more closely monitor/control the batteries I am discharging.
Old Oct 01, 2012, 03:06 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
There is an "LiXx monitor" mode where you can use the iCharger to monitor the per-cell voltages without it being part of the discharge process. See around p18 of the manual.
Lithium battery in monitoring mode
When you use other devices to charge or discharge Lithium pack, the iCharger can monitor each cell‘s voltage, battery temperature, charge time and so on, if one of the batteries appears over-charged,over-discharged, over-hot, over-capacity or over-time ,the iCharger will alarm with noise “Di…..” and blink the related information.
Perhaps that is what you are seeking?
kgfly is offline Find More Posts by kgfly
Old Oct 01, 2012, 06:36 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Originally Posted by danau View Post
Hi,
Please help,
Dan.
If you are interested in maximum capacity, charge as LiPo.
If you want maximum life expectancy, charge as LiIon.
Every 0.1V less doubles the life expectancy.
Julez is offline Find More Posts by Julez
Old Oct 01, 2012, 07:47 AM
danau is offline
Joined Apr 2009
Mark and Julez, thank you both for the replies. Guess I was just being over cautious. I was just afraid of exploding the battery, by charging it with the wrong battery type.
Today, I started charging a 2S pack that I made up. I set the charger to Lilo mode and 1.2 amps. After about 20 minutes I stopped the charge because I the temperature slowly increased from about 20 C to about 25 C. If I saw a Lipo do that, I would probably freak out and throw the thing outside by the lead. LOL .
Julez, thank you for the graph! I'll stick with 4.1V
Mark, do you notice a temperature rise when charging yours?
Thanks guys, much appreciated.
Dan
Old Oct 01, 2012, 10:33 AM
Michigan
Joined Jan 2011
Thanks!
This might be the simplest way to go...
I do have a way to monitor pack voltage with an alarm with my discharger... this would be an excellent way to double check the new system with the first few discharges to make sure everything is working as it should.
After all this time; kgfly, Julez, and Charles are still the "guardians" of this thread.
I thank you for your dedication!
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 01:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 04:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 09:55 PM
