Old Sep 26, 2012, 01:24 PM
gerard71 is offline
Find More Posts by gerard71
Joined Oct 2009
Originally Posted by gerard71 View Post
Anyone knows how to use this cable:
http://www.hobbyking.com/hobbyking/s...dProduct=27094
Banana plugs go into charger output, JST-XH goes into charger balancing port, JST-PH goes into batteries?
Did you see the connection of the cable? Mains go into balancer plug left and right pin directly. Is this ok?
gerard71 is offline Find More Posts by gerard71
Old Sep 26, 2012, 01:33 PM
Woody_99 is online now
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
It is OK.
I use two of these setup in parallel. Since the UMX batteries of this size charge from the balance tap, the connection you point out supplies the charge current to the battery from the balance tap too.
Woody_99 is online now Find More Posts by Woody_99
Old Sep 27, 2012, 02:33 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by lipoflyer View Post
Junsi, Will there be a firmware update for NiZn batteries?
Thanks for your support on our products, our engineers will study if it is feasible for the battery you mentioned, and keep you informed if have any update.
Junsi
junsi is offline Find More Posts by junsi
Old Sep 27, 2012, 02:45 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by gonzalix View Post
Hello guys,
I'm using iChargers since several years and without any problem. I have two 106B+ and another two 1010B+. Now i'm suffering some kind of programmed obsolescence or something like that.....
All of them with the 3.14 firmware version
One of the 106B+ resets whenever I start any kind of charge.
Both of the 1010B+ have the same problem, they are unable to charge my 2x5S Lipos returning Bal. Error or Vout Error. No problem if I charge 1x5S using the first balancing port. If I monitor the Lipos (charged at 4.xx volts) the first five cells, the ones on the first balance port seem to return normal values, but the cells on the second port incorrectly display 2.xx volts all of them. I have changed the balancing connector plate on both chargers with same results. I also tried to calibrate but the volatge difference is too high.
About the 106b+, please press STOP button and electrify the charger to upgrade to the V3.14 again,check if it can solve your problem.
And the 1010B+, plug second 5S battery pack into the charger without any balance board directly, check if the problem was caused by the charger or the balance?
Junsi
Old Sep 27, 2012, 03:14 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Hi Junsi
I have a 206b and it is a great charger, in fact it's the best charger I have ever owned and am thinking of buying another icharger, however I seem to have a problem when using storage cycle, if discharging a pack/s, it doesn't bring them down enough, most of the time it finishes at 3.91 per cell, I checked the setting and it is 11.4 on a 3s pack, can you please advise.
aeromaniac is offline Find More Posts by aeromaniac
Old Sep 27, 2012, 03:30 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
3.91V is fine for storage, but to get closer to the set voltage, you need to set "Discharge reduce" (in settings menu) to around 10%, or else the voltage will jump up some when discharge finishes.
Fred
flarssen is offline Find More Posts by flarssen
Old Sep 27, 2012, 05:31 AM
Glow 😡 no no no
Joined Mar 2010
Fred
if 3.91 is ok then it makes quicker to charge up my packs, mmm 😃👍
Old Sep 27, 2012, 05:46 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The OK storage range for LiPoly is 3.7 to 4.0 V per cell. I choose 3.85 approx. 7 years ago as a standard since it is mid point of that range. For short term such as a week or so 4.0 per cell is fine however it is best to use the lower end of the ranger for longer term storage.
Charles
Old Sep 27, 2012, 06:01 AM
Glow 😡 no no no
Joined Mar 2010
Thanks for the replies, if it's not broke then I'm not fixing it lol.
Old Sep 27, 2012, 07:55 AM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
The storage discharge termination voltage question comes up frequently in this thread.
It could be avoided if Junsi made the default setting from the factory for discharge reduce "ON", and "5%" or some similar low value like that. I cannot see any harm in such a default setting, but it would certainly avoid a lot of confusion.
Rumple is offline Find More Posts by Rumple
Old Sep 27, 2012, 08:28 PM
Southern Pride
It would cause extended discharge to X volts times and give a fasle capacity reading. If I set a discharge rate of 5A to 3.3 per cell then that is waht I want not 5A to 3.3 then .330 to finish the discharge. If you were doing cycles it would take forever.
What would help is purchasers taking the time to read the Owner's Manual.
Charles
Old Sep 28, 2012, 04:26 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
It would help to set a fixed discharge reduce of, like, 5%, as mentioned above, only in the storage program.
The discharge reduce that affects all other discharges shold be independent.
Julez is offline Find More Posts by Julez
Old Sep 28, 2012, 04:42 AM
gerard71 is offline
Joined Oct 2009
What does the % setting of Discharge reduce mean?
If I set this to 5% LiPo storage will stop at 3.85V - 5% (.1925V) = 3.6575V per cell?
Here is the explanation from the manual:
Discharge reduce setting. When you set it to ―ON‖,If the final voltage target
storage voltage is reached, the buzzer will beep for three times, and the left
of the second line display "D>>", and the charger enters into the high
precision discharge process. The process won‘t stop until the current
reaches xx% of the configured discharge current.
Old Sep 28, 2012, 05:04 AM
flarssen is offline
Son, Norway
Joined Sep 2004
It continues to discharge after target voltage is reached, gradually lowering current to maintain that voltage, until the current has dropped to xx% of the configured discharge current.
This is exactly the same as it does when charging, only the other way around..
If the charger had stopped immediately when 4.2V was reached during charging, pack voltage would drop significantly too.
Fred
Old Sep 28, 2012, 05:24 AM
gerard71 is offline
Joined Oct 2009
This sentence is not clear to me. Do I have to set Discharge Reduce to 95% to stop LiPo storage at 3.6575V per cell?
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
