Old Aug 07, 2012, 09:32 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The supplied USB cable has the shield not grounded on one end to prevent ground loops.
You cn use a standard USB cable as long as the charger and the computer are not both powered from AC or a power supply that is AC powered.
Many use a charged 3S LiPoly or a 12V Pb battery to power the charger when doing firmware updates.
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 07, 2012, 09:47 AM
g_lux is offline
Find More Posts by g_lux
Joined Aug 2012
Firmware update was a no go.
I had the charger connected to a 12v battery.
I installed the usb drivers successfully, plug the charger into the usb port.
Windows recognized the charger successfully.
I then continued to try to update the drivers but get a no device found error.
I left the charger connected to the 12v battery for about 25mins and the unit started getting very warm. I have a feeling the charger is toast.....
I had contacted hobby king and they are giving me the run around with not being able to find my order even-though I have both the Paypal receipt and the hobbyking receipt. There saying the order was refunded even though it never was. That is the only place i could have purchased the charger from.
g_lux is offline Find More Posts by g_lux
Old Aug 07, 2012, 11:21 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
I bought my Icharger from http://www.progressiverc.com/. They are known for their good service. Even if the Charger was bought elsewhere I would give them a call or E-mail and see if they can help.
Otherwise... every once in a while Junsi will pay a visit to the thread to help with these issues.
BGR is offline Find More Posts by BGR
Old Aug 08, 2012, 09:51 AM
g_lux is offline
Joined Aug 2012
no luck with progressiverc. Great guys working there but they cant help if I didnt buy it from them and thats understandable.
Eh looks like I may be out 140 bucks.
Old Aug 08, 2012, 12:37 PM
g_lux is offline
Joined Aug 2012
Good news EPbuddy hooked it up. I just sent the unit out to him.
Great service
Old Aug 08, 2012, 05:40 PM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Guys,
I am unable to figure out how many mah's I am putting back into my Genesis 3cell 1600 55c lipos. Using the I-Charger 306b. Suggestions??
It was my understanding not to run the lipo's below 3.7v per cell. Now I am reading about the 80% rule. 1600 mah lipo, should be putting back a max of 1200 mah.
Just trying to figure out why I'm getting 3.5 minutes fly time & others with the same setup are getting 5-6 minutes.
Bill B.
wjb111 is offline Find More Posts by wjb111
Old Aug 08, 2012, 05:47 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
What does the charger say its putting back into the battery? Are others not as careful as you regarding running it down too far? Or do you have a heavy left thumb?
Bigster is offline Find More Posts by Bigster
Old Aug 09, 2012, 05:00 AM
robs is offline
Find More Posts by robs
robs's Avatar
United States, NY, Dutchess
Joined Jun 2002
I just got my icharger 106B+ and am excited to try out its capabilities, especially the IR tests. However, I have run into some issues with power supplies shutting off when I tried to use it for the first time.
First attempt was using a converted IBM server >30A power supply (purchased from feathermerchant approximately 2yrs ago). I've been using this to power a CellPro4s, HK quatro and rarely an original Triton. Never had any issues even when powering all three. The power supply shut itself off as soon I plugged the 106B+ in.
The same thing happened when I tried my converted PC 24A power supply.
The third power source I attempted was a 5A laptop brick. With this the 106B+ powered up and I got to play with the IR test.
What could be causing my converted server and PC power supplies to shut off when plugging the 106B+ in, while the brick works?
robs is offline Find More Posts by robs
Old Aug 09, 2012, 05:26 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Connect charger to PSU, then power up the PSU.
Fred
flarssen is online now Find More Posts by flarssen
Old Aug 09, 2012, 08:27 AM
robs is offline
robs's Avatar
Joined Jun 2002
Thanks Fred, changing the power up order fixed my issue.
I've not run into this order dependence before with any other charger. Now of course, I'd like to understand "why?". Is there some protection circuitry in the PS's that the initial draw of the icharger trigger's? If so what is different with the other chargers that don't cause the same effect?
Rob
Old Aug 09, 2012, 08:45 AM
Southern Pride
When used in a computer itgoes thru a series of test while computer is booting up. After the power supp;yu and computer are running the power supply will sense any unusaul loads which may be signs of shorts and shut down. Some chargers have fairly large surge currents during start up and some power supplies see these as shorts or the start up surges exceed the amps. capabilities of the power supply.
Rule of thumb which few follow is that a swither type power supply should always have a load attached befor it is powered up.
From first post of this thread
Recommended connecting way:
1. Connect iCharger's input power supply, and turn on it.
2. Connect Li batteries' balance port
3. Connect the main charging port's positive pole to cells' positive pole, and then connect negative pole to cells' negative pole (this will avoid striking fire while connecting Li cells).
4. Start charging and discharging...
5. After finishing charging and discharging, pls disconnect the cell and charger, and then turn off the charger's power supply.
Charles
Old Aug 09, 2012, 01:06 PM
robs is offline
robs's Avatar
Joined Jun 2002
Doh
Thanks Charles, I embarrassed that I missed that In red even.
Rob
Old Aug 09, 2012, 07:48 PM
madmaxed is offline
Find More Posts by madmaxed
United States, MI, Grand Rapids
Joined Jul 2011
Failing 206B?
Hello,
My iCharger 206B started giving me a "Reverse Polarity Check Connection" message today. I just used it yesterday with no incident. I have now tried it with three parallel boards as well as straight connections and multiple power supplies.
If I leave the unit sit for about 30 seconds and reapply power with no battery connected it appears fine. However as soon as I put a battery on the output side the message appears and will only clear after disconnecting the battery, removing input power and letting reset for 30+ seconds.
I have tried 2s, 3S and 6S batteries all with the same result. I hopefully someone can shed some light on the subject. I have been considering getting a 3010B as an upgrade since I have been impressed up to this point. However, I am having second thoughts since I purchased this unit 7/31/2011 and have less than 100 cycles on it (mostly 3S 2200mAH and 1S 500Mah).
madmaxed is offline Find More Posts by madmaxed
Old Aug 10, 2012, 03:41 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by madmaxed View Post
Hello,
According to our engineer, this message won't affect the use of the charger. But you can try to short circuit the output, check if this message still appear.
Junsi
junsi is offline Find More Posts by junsi
Old Aug 10, 2012, 06:11 AM
madmaxed is offline
Joined Jul 2011
The unit is non-responsive with this message. It is continuously beeping and none of the buttons respond. When you say short the output, do you mean connect the positive to negative output terminals when the message appears?
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
