Old Aug 06, 2012, 06:09 PM
g_lux is offline
Find More Posts by g_lux
Joined Aug 2012
Im having an issue with my icharger 208b. It does not want to "turn on". I could hear the unit power on and energize the lcd board but that is all.
I know its not the power supply as it is getting the appropriate voltage. i've also confirmed by connecting to a 12v battery.
Please help.
g_lux is offline Find More Posts by g_lux
Old Aug 06, 2012, 06:15 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
How long have you had it?
Has it worked in the past?
What have you done differently?
Old Aug 06, 2012, 06:30 PM
g_lux is offline
Joined Aug 2012
it is about 8 months old. It has worked flawlessly in the past. I had bought it brand new from hobby king.
As far as i know there is nothing i had done differently. I double checked my powersupply and im getting the correct output. To confirm I hooked the unit up to a 12v battery.
Old Aug 06, 2012, 07:46 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Please help.
If it is still under warranty then don't touch it. Otherwise you could try and re-flash it, maybe it just lost its mind.
BGR is offline Find More Posts by BGR
Old Aug 06, 2012, 08:22 PM
g_lux is offline
Joined Aug 2012
So i just looked up my receipt, I missed the one year warrenty by exactly 3 days!!
I'll try updating the firmware. I cant find the usb cable that was included with the unit. I know it says explicitly to use the one that came in the box.
What can I use as a replacement?
Old Aug 06, 2012, 08:45 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
The 3 days shouldn't matter.
loNslo is offline Find More Posts by loNslo
Old Aug 06, 2012, 08:53 PM
g_lux is offline
Joined Aug 2012
ill contact hobbyking. ill see what they say
Old Aug 06, 2012, 09:03 PM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
I looked at my ICharger USB cable and it has a small connector that goes to the ICharger USB port and a normal USB connector for the PC. One would think that if you found a similar cable you could use it but then I found this quote.
The USB cable we use is a little bit different from normal USB cables. When using normal USB cable, the metal shell will go through laptop's GND and the input power supply's GND via USB's SGND. At this time, when users connect the batteries' positive pole, and touch the charger's metal shell unconsciously, it will occur short circuit, which may damage the charger or laptop. To avoid this case, the SGND of our USB cable is disconnected. Of course, you can use normal USB cable, too.
Regards,
Junsi
Old Aug 06, 2012, 10:48 PM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
Looks like Value Hobby dropped the price on the 3010B down to $149.99
http://www.valuehobby.com/icharger-3...e-charger.html
keyman923 is offline Find More Posts by keyman923
Old Aug 06, 2012, 10:57 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Now that is one heck of a deal.
Others are selling the 306B for $159.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Aug 06, 2012, 10:59 PM
RC Helicopter Pilot
Joined Mar 2010
Originally Posted by evltoy View Post
Mark -I never thought about the fix voltage on the PRC500! Sounds like this may not suit me.
If anyone has the time can they comment on this PSU and tell me if this would fit my needs.
http://www.radioparts.com.au/ProdVie...C+POWER+SUPPLY
That ad does not say how many watts it puts out but at 40AMPS at 15V I think it will do what you want.
But $300?
WOW, expensive.
Also, watch out for the input voltage.
It says 230V 50Hz.
Old Aug 06, 2012, 11:12 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Thanks WoodCrafter.
I might go down to the shop and see how many watts it puts out, but like you said.. at 40A on 15v seems very safe for me.
The price is a fair amount. I "think" it come down to the unit being very low RFI and high quality with a adjustable voltage and safety features... who knows.
input voltage is no issue as this is what we use in Australia.
evltoy is offline Find More Posts by evltoy
Old Aug 06, 2012, 11:13 PM
RC Helicopter Pilot
Joined Mar 2010
Yes, you guys have that funny power down there.
Old Aug 06, 2012, 11:19 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
hehehe. I guess we do look a little funny pending on where your standing.
Old Aug 07, 2012, 08:33 AM
MarkEHansen is offline
Find More Posts by MarkEHansen
United States, CA, Sacramento
Joined Jun 2012
I found the following in the User Manual for the 3010B:
Note: You must only ever use the supplied USB cable provided with your iCharger as this is a custom cable
with internal differences from other USB cables.
It doesn't seem to leave an option of using another cable.
MarkEHansen is offline Find More Posts by MarkEHansen
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
