Old Jul 30, 2012, 09:52 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by dendenyc View Post
The problem is that on the 206b the q22 and q24 solder points are under the LCD which is also soldered. (the photo in the FAQ is not the same charger i have. Are there any points n 206b I can break to get it to work?
Sorry to hear that, please check the PM we have sent to you. Thanks.
Junsi
junsi is offline Find More Posts by junsi
Old Jul 30, 2012, 10:07 PM
dendenyc is offline
Find More Posts by dendenyc
dendenyc's Avatar
Joined Apr 2012
Hello Junsi, PM replied
dendenyc is offline Find More Posts by dendenyc
Old Jul 31, 2012, 05:21 PM
JohnRB is online now
Find More Posts by JohnRB
United States, NC, Raleigh
Joined Oct 2011
Problems with X10 Power Control System
I have an iCharger 3010B and a Junsi 350W DC Power supply that I am very happy with. My house is also loaded with X10 Power Control Modules (lamp and appliance modules).
I have noticed that whenever the Junsi Power Supply is turned on and the 3010B is connected, any X10 device connected to the same power phase is no longer functional because of line noise (X10 operates at 100kHz at the 60Hz zero crossing). If I disconnect the 3010B from the power supply, X10 works fine. It appears noise is being generated in the 3010B even when it is not charging batteries.
Any one else have this problem?
JohnRB is online now Find More Posts by JohnRB
Old Jul 31, 2012, 07:10 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps visit the X 10 Forum
http://www.x10.com/news/mssgBd.htm
I have numerious of thier Eagle Eyes,Motion Sensor FloodLights, Security Console ,door / window sensors etc. and yes they are very subject to line noises. Switching power supplies are just one of many sources.,
Old Jul 31, 2012, 09:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
It is not the charger, it is the power supply.
When you add a load to the power supply, your charger, it will send some harmonics up the line.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Aug 01, 2012, 05:40 AM
Joined Oct 2011
Thanks for the reply.
I suspected it might be the switcher under load. I had planned to scope it today as well as try a linear PS. I was just curious if anyone else had noticed the same problem.
Old Aug 01, 2012, 05:15 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Can this be done?
I have a iCharger 106b and a paraboard. For those rare days where you don't get to fly all of your packs the 106 with it's 10w discharger takes for ever. This bulb is a 50w 12v bulb and is soldered to my XT60 connector. Can I run the bulb while using the storage/discharge mode? I know it won't turn off at the set level. I may just add a second bulb and connect the balance voltage cell reader to get discharged in the ball park and finish off on the charger.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 01, 2012, 05:23 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I also have X10 throughout my house have noticed that a number of switching power supplies give the X10 grief. The solution is to put an X10 filter between the switching supply and the AC line.
I have a bunch if these
http://www.smarthome.com/4845/Levito...-Filter/p.aspx
There are higher current versions and that is what you would need.
Gregor99 is offline Find More Posts by Gregor99
Old Aug 01, 2012, 05:50 PM
Joined Oct 2011
Today I measured the current consumption of the charger while it is idle, about 80mA. Putting a 180 ohm resistor across the power supply output produces about the same load and the noise from the power supply kills all X-10 signals.
I have those filters on hand as well. Even with only an 80mA load, It did not help with this power supply.
I looked at the power line using a scope and Scope-Test2 and the small bursts of noise are always there, but narrow enough to not completely block X-10. As the load on the power supply increases the bursts get more frequent and higher in amplitude. Minimal testing so far indicates the frequency contained in the bursts is constant, only the width and amplitude change. All of this testing with very light loads.
Tomorrow and will try to spend some additional time on this.
John
Old Aug 02, 2012, 12:21 PM
Joined Oct 2011
P350 67kHz noise.
Did some scoping today and I now understand why filter did not help. The filters attenuate signals between 80kHz - 200kHz. The offending signals from the P350 are around 67kHz.
I have attached to scope captures. The scope is being double triggered, first by the 0 crossing of the 60Hz line voltage on channel 3 followed by the first transition on the data line on channel 4. I am using an ACT Scope-Test2 to make the signals viewable on the scope.
The first capture shows a normal 120kHz X10 signal and it's time placement and amplitude after the 0 crossing.
The second capture shows the 65.3kHz noise being generated by the P350. Note it's placement is right where any X10 signal would appear and it's amplitude is greater than a normal X10 signal. I suspect the problem gets worse as a greater load is placed on the power supply.
X and Y scales are the same in both scope captures.
Looks like a good 65kHz filter is required between the wall outlet and the P350.
Old Aug 02, 2012, 12:33 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Thanks John. That may explain why my X10 reliability is still not great dispite having a filters on all my TVs, computers and other switching power supplies. I have found they definitely help. But its still not perfect. I have a lot of switches as well as an Ocelot controller. So it would be expensive to convert to a different technology. But i think its inevitable.
Old Aug 02, 2012, 12:52 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by Ohio AV8TOR View Post
Can this be done?
I recall reading the 3010b has instructions on how to put a load in series for speedier discharge.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Aug 02, 2012, 03:26 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Can this be done?
Look up the "external expanding discharge mode". As was said the load should be in series, then it will get turned off as soon as it disengages the discharge.
grimbeaver is offline Find More Posts by grimbeaver
Old Aug 02, 2012, 04:30 PM
On loan to Texas
Joined Oct 2005
okay thanks will do.
Old Aug 02, 2012, 08:42 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Unless it is a particularly crappy PSU it should actually get better with more load. SMPS dont really like having next to no load on them and unless designed for it can do weird things (as you have seen).
desertstalker is offline Find More Posts by desertstalker
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
