San Diego
Joined Dec 2003
At this point I think I would try to monitor the time, voltage and amperage of the other chargers that charge these batteries to 4.2 volts and compare it to what the ICharger does. |
Not that I have not posted this less than 500 times but once more.
Charged to 4.15 to 4.2V per cell is fine, most chargers and LiPolys settle to around 4.17 to 4.18 afer a few hours anyway. Storage is 3.85 Nonimal. I am the one who came up with that boltage many tears ago. Lipoys use to ship at 3.7 per cell now for the past 4 years or so most ship at around 3.8 to 3.85. Storage at between 3.7 and 4.0 per cell is fine. Packs I fly frequently I used to store at around 4.0 per cell so they would charge faster. Past several years I rarely charge at less than 3C so time difference between starting at 3.7 or 4.0 per cell is no big deal. I vcan have multi LiPolys charged and ready to fly in under 20 minutes. |
United States, CA, Sacramento
Joined Jun 2012
![]() Seriously, though, Thanks. I've been reading about LiPo battery care and feeding for weeks and I think I'm finally getting it. Thanks for your patience. |
San Diego
Joined Dec 2003
I respect your opinion and I am fully aware that you posses much more knowledge on this subject than I do. However while you post does bear repeating from time to time it misses the point in this particular case. Both Mark and I have similar experiences with the ICharger and these little cells. It shows that the ICharger is not always able to meet its final voltage set point and according to Mark his other chargers do. While I agree that .02 volts is insignificant and do understand that no charger is perfect, the behavior during storage charging is far from what one would expect to see. So to me the subject matter is about what is happening here rather than whether the results are within tolerable limits. The conclusions that I posted in response to this subject come from my own experience with this charger and these little batteries. I have mentioned this behavior before but stirred little interest. But now I had confirmation that this is not isolated to my charger or my batteries. I had hoped that this subject would generate more interest now.
So. Cal.
It's not the fault of the iCharger that the battery is 'not meeting its the set point', it's the voltage drop in the leads and batteries that is responsible. Charge the same cells with another charger at the same charge rate and with the same length and gauge charge lead and the termination voltage will likely be identical, provided voltage calibration is the same.
One cannot expect the same termination voltage when charging at 3X charge rate. For this to be the case requires charge leads and cells with zero resistance, which is impossible. If you want higher termination voltage, lower your charge rate or increase the termination voltage within the user setting in the charger. However, as has been clearly stated by many others, a few millivolts amounts to a few seconds of flight time at the expense of fewer useful cycles. Mark |
Thanks in very large part to those who have contributed, here, I've just ordered the 206B/P350 combo "the ticket" from ProgressiveRC. This, and a parallel board, seems way good for handling a set of (4) 14.8V 4S 2200mAh 30C Li-Po batteries. This will be my first adventure into both R/C and electric. So thanks for the great help.
| Thread Tools | |
| Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 02:52 PM |
| Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM |
| NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM |
| WTB Good charger/discharger 10 + cells | khen | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
